目录
Audio Resampling
This tutorial shows how to use torchaudio’s resampling API.
import torch
import torchaudio
import torchaudio.functional as F
import torchaudio.transforms as T
print(torch.__version__)
print(torchaudio.__version__)
Out:
1.12.0
0.12.0
Preparation
First, we import the modules and define the helper functions.
Note
When running this tutorial in Google Colab, install the required packages with the following.
!pip install librosa
import math
import time
import librosa
import pandas as pd
from IPython.display import Audio, display
pd.set_option('display.max_rows', None)
pd.set_option('display.max_columns', None)
DEFAULT_OFFSET = 201
def _get_log_freq(sample_rate, max_sweep_rate, offset):
    """Get freqs evenly spaced out in log-scale, between [0, max_sweep_rate // 2]
    offset is used to avoid negative infinity `log(offset + x)`.
    start, stop = math.log(offset), math.log(offset + max_sweep_rate // 2)
    return torch.exp(torch.linspace(start, stop, sample_rate, dtype=torch.double)) - offset
def _get_inverse_log_freq(freq, sample_rate, offset):
    """Find the time where the given frequency is given by _get_log_freq"""
    half = sample_rate // 2
    return sample_rate * (math.log(1 + freq / offset) / math.log(1 + half / offset))
def _get_freq_ticks(sample_rate, offset, f_max):
    # Given the original sample rate used for generating the sweep,
    # find the x-axis value where the log-scale major frequency values fall in
    time, freq = [], []
    for exp in range(2, 5):
        for v in range(1, 10):
            f = v * 10**exp
            if f < sample_rate // 2:
                t = _get_inverse_log_freq(f, sample_rate, offset) / sample_rate
                time.append(t)
                freq.append(f)
    t_max = _get_inverse_log_freq(f_max, sample_rate, offset) / sample_rate
    time.append(t_max)
    freq.append(f_max)
    return time, freq
def get_sine_sweep(sample_rate, offset=DEFAULT_OFFSET):
    max_sweep_rate = sample_rate
    freq = _get_log_freq(sample_rate, max_sweep_rate, offset)
    delta = 2 * math.pi * freq / sample_rate
    cummulative = torch.cumsum(delta, dim=0)
    signal = torch.sin(cummulative).unsqueeze(dim=0)
    return signal
def plot_sweep(
    waveform,
    sample_rate,
    title,
    max_sweep_rate=48000,
    offset=DEFAULT_OFFSET,
    x_ticks = [100, 500, 1000, 5000, 10000, 20000, max_sweep_rate // 2]
    y_ticks = [1000, 5000, 10000, 20000, sample_rate // 2]
    time, freq = _get_freq_ticks(max_sweep_rate, offset, sample_rate // 2)
    freq_x = [f if f in x_ticks and f <= max_sweep_rate // 2 else None for f in freq]
    freq_y = [f for f in freq if f in y_ticks and 1000 <= f <= sample_rate // 2]
    figure, axis = plt.subplots(1, 1)
    _, _, _, cax = axis.specgram(waveform[0].numpy(), Fs=sample_rate)
    plt.xticks(time, freq_x)
    plt.yticks(freq_y, freq_y)
    axis.set_xlabel("Original Signal Frequency (Hz, log scale)")
    axis.set_ylabel("Waveform Frequency (Hz)")
    axis.xaxis.grid(True, alpha=0.67)
    axis.yaxis.grid(True, alpha=0.67)
    figure.suptitle(f"{title} (sample rate: {sample_rate} Hz)")
    plt.colorbar(cax)
    plt.show(block=True)
Resampling Overview
To resample an audio waveform from one freqeuncy to another, you can use torchaudio.transforms.Resample() or torchaudio.functional.resample(). transforms.Resample precomputes and caches the kernel used for resampling, while functional.resample computes it on the fly, so using torchaudio.transforms.Resample will result in a speedup when resampling multiple waveforms using the same parameters (see Benchmarking section).
Both resampling methods use bandlimited sinc interpolation to compute signal values at arbitrary time steps. The implementation involves convolution, so we can take advantage of GPU / multithreading for performance improvements.
Note
When using resampling in multiple subprocesses, such as data loading with multiple worker processes, your application might create more threads than your system can handle efficiently. Setting torch.set_num_threads(1) might help in this case.
Because a finite number of samples can only represent a finite number of frequencies, resampling does not produce perfect results, and a variety of parameters can be used to control for its quality and computational speed. We demonstrate these properties through resampling a logarithmic sine sweep, which is a sine wave that increases exponentially in frequency over time.
The spectrograms below show the frequency representation of the signal, where the x-axis corresponds to the frequency of the original waveform (in log scale), y-axis the frequency of the plotted waveform, and color intensity the amplitude.
sample_rate = 48000
waveform = get_sine_sweep(sample_rate)
plot_sweep(waveform, sample_rate, title="Original Waveform")
Audio(waveform.numpy()[0], rate=sample_rate)
Original Waveform (sample rate: 48000 Hz)
Now we resample (downsample) it.
We see that in the spectrogram of the resampled waveform, there is an artifact, which was not present in the original waveform.
resample_rate = 32000
resampler = T.Resample(sample_rate, resample_rate, dtype=waveform.dtype)
resampled_waveform = resampler(waveform)
plot_sweep(resampled_waveform, resample_rate, title="Resampled Waveform")
Audio(resampled_waveform.numpy()[0], rate=resample_rate)
Resampled Waveform (sample rate: 32000 Hz)
Controling resampling quality with parameters
Lowpass filter width
Because the filter used for interpolation extends infinitely, the lowpass_filter_width parameter is used to control for the width of the filter to use to window the interpolation. It is also referred to as the number of zero crossings, since the interpolation passes through zero at every time unit. Using a larger lowpass_filter_width provides a sharper, more precise filter, but is more computationally expensive.
sample_rate = 48000
resampled_waveform = F.resample(waveform, sample_rate, resample_rate, lowpass_filter_width=6)
plot_sweep(resampled_waveform, resample_rate, title="lowpass_filter_width=6")
lowpass_filter_width=6 (sample rate: 32000 Hz)
resampled_waveform = F.resample(waveform, sample_rate, resample_rate, lowpass_filter_width=128)
plot_sweep(resampled_waveform, resample_rate, title="lowpass_filter_width=128")
lowpass_filter_width=128 (sample rate: 32000 Hz)
Rolloff
The rolloff parameter is represented as a fraction of the Nyquist frequency, which is the maximal frequency representable by a given finite sample rate. rolloff determines the lowpass filter cutoff and controls the degree of aliasing, which takes place when frequencies higher than the Nyquist are mapped to lower frequencies. A lower rolloff will therefore reduce the amount of aliasing, but it will also reduce some of the higher frequencies.
sample_rate = 48000
resampled_waveform = F.resample(waveform, sample_rate, resample_rate, rolloff=0.99)
plot_sweep(resampled_waveform, resample_rate, title="rolloff=0.99")
rolloff=0.99 (sample rate: 32000 Hz)
resampled_waveform = F.resample(waveform, sample_rate, resample_rate, rolloff=0.8)
plot_sweep(resampled_waveform, resample_rate, title="rolloff=0.8")
rolloff=0.8 (sample rate: 32000 Hz)
Window function
By default, torchaudio’s resample uses the Hann window filter, which is a weighted cosine function. It additionally supports the Kaiser window, which is a near optimal window function that contains an additional beta parameter that allows for the design of the smoothness of the filter and width of impulse. This can be controlled using the resampling_method parameter.
sample_rate = 48000
resampled_waveform = F.resample(waveform, sample_rate, resample_rate, resampling_method="sinc_interpolation")
plot_sweep(resampled_waveform, resample_rate, title="Hann Window Default")
Hann Window Default (sample rate: 32000 Hz)
resampled_waveform = F.resample(waveform, sample_rate, resample_rate, resampling_method="kaiser_window")
plot_sweep(resampled_waveform, resample_rate, title="Kaiser Window Default")
Kaiser Window Default (sample rate: 32000 Hz)
Comparison against librosa
torchaudio’s resample function can be used to produce results similar to that of librosa (resampy)’s kaiser window resampling, with some noise
sample_rate = 48000
kaiser_best
    waveform,
    sample_rate,
    resample_rate,
    lowpass_filter_width=64,
    rolloff=0.9475937167399596,
    resampling_method="kaiser_window",
    beta=14.769656459379492,
plot_sweep(resampled_waveform, resample_rate, title="Kaiser Window Best (torchaudio)")
Kaiser Window Best (torchaudio) (sample rate: 32000 Hz)
librosa_resampled_waveform = torch.from_numpy(
    librosa.resample(waveform.squeeze().numpy(), orig_sr=sample_rate, target_sr=resample_rate, res_type="kaiser_best")
).unsqueeze(0)
plot_sweep(librosa_resampled_waveform, resample_rate, title="Kaiser Window Best (librosa)")
Kaiser Window Best (librosa) (sample rate: 32000 Hz)
mse = torch.square(resampled_waveform - librosa_resampled_waveform).mean().item()
print("torchaudio and librosa kaiser best MSE:", mse)
Out:
torchaudio and librosa kaiser best MSE: 2.08069011536601e-06
kaiser_fast
    waveform,
    sample_rate,
    resample_rate,
    lowpass_filter_width=16,
    rolloff=0.85,
    beta=8.555504641634386,
plot_sweep(resampled_waveform, resample_rate, title="Kaiser Window Fast (torchaudio)")
Kaiser Window Fast (torchaudio) (sample rate: 32000 Hz)
    librosa.resample(waveform.squeeze().numpy(), orig_sr=sample_rate, target_sr=resample_rate, res_type="kaiser_fast")
).unsqueeze(0)
plot_sweep(librosa_resampled_waveform, resample_rate, title="Kaiser Window Fast (librosa)")
Kaiser Window Fast (librosa) (sample rate: 32000 Hz)
print("torchaudio and librosa kaiser fast MSE:", mse)
Out:
torchaudio and librosa kaiser fast MSE: 2.5200744248600685e-05
Performance Benchmarking
Below are benchmarks for downsampling and upsampling waveforms between two pairs of sampling rates. We demonstrate the performance implications that the lowpass_filter_wdith, window type, and sample rates can have. Additionally, we provide a comparison against librosa’s kaiser_best and kaiser_fast using their corresponding parameters in torchaudio.
To elaborate on the results:
  • a larger lowpass_filter_width results in a larger resampling kernel, and therefore increases computation time for both the kernel computation and convolution
  • using kaiser_window results in longer computation times than the default sinc_interpolation because it is more complex to compute the intermediate window values - a large GCD between the sample and resample rate will result in a simplification that allows for a smaller kernel and faster kernel computation.
def benchmark_resample(
    method,
    waveform,
    sample_rate,
    resample_rate,
    lowpass_filter_width=6,
    rolloff=0.99,
    resampling_method="sinc_interpolation",
    beta=None,
    librosa_type=None,
    iters=5,
    if method == "functional":
        begin = time.monotonic()
        for _ in range(iters):
            F.resample(
                waveform,
                sample_rate,
                resample_rate,
                lowpass_filter_width=lowpass_filter_width,
                rolloff=rolloff,
                resampling_method=resampling_method,
        elapsed = time.monotonic() - begin
        return elapsed / iters
    elif method == "transforms":
            sample_rate,
            resample_rate,
            rolloff=rolloff,
            dtype=waveform.dtype,
            resampler(waveform)
    elif method == "librosa":
        waveform_np = waveform.squeeze().numpy()
            librosa.resample(waveform_np, orig_sr=sample_rate, target_sr=resample_rate, res_type=librosa_type)
configs = {
    "downsample (48 -> 44.1 kHz)": [48000, 44100],
    "downsample (16 -> 8 kHz)": [16000, 8000],
    "upsample (44.1 -> 48 kHz)": [44100, 48000],
    "upsample (8 -> 16 kHz)": [8000, 16000],
for label in configs:
    times, rows = [], []
    sample_rate = configs[label][0]
    resample_rate = configs[label][1]
    # sinc 64 zero-crossings
    f_time = benchmark_resample("functional", waveform, sample_rate, resample_rate, lowpass_filter_width=64)
    t_time = benchmark_resample("transforms", waveform, sample_rate, resample_rate, lowpass_filter_width=64)
    times.append([None, 1000 * f_time, 1000 * t_time])
    rows.append("sinc (width 64)")
    # sinc 6 zero-crossings
    f_time = benchmark_resample("functional", waveform, sample_rate, resample_rate, lowpass_filter_width=16)
    t_time = benchmark_resample("transforms", waveform, sample_rate, resample_rate, lowpass_filter_width=16)
    rows.append("sinc (width 16)")
    # kaiser best
    lib_time = benchmark_resample("librosa", waveform, sample_rate, resample_rate, librosa_type="kaiser_best")
        "functional",
        waveform,
        sample_rate,
        resample_rate,
        "transforms",
        waveform,
        sample_rate,
        resample_rate,
    times.append([1000 * lib_time, 1000 * f_time, 1000 * t_time])
    rows.append("kaiser_best")
    # kaiser fast
    lib_time = benchmark_resample("librosa", waveform, sample_rate, resample_rate, librosa_type="kaiser_fast")
        "functional",
        waveform,
        sample_rate,
        resample_rate,
        rolloff=0.85,
        "transforms",
        waveform,
        sample_rate,
        resample_rate,
        rolloff=0.85,
    rows.append("kaiser_fast")
    df = pd.DataFrame(times, columns=["librosa", "functional", "transforms"], index=rows)
    df.columns = pd.MultiIndex.from_product([[f"{label} time (ms)"], df.columns])
    print(f"torchaudio: {torchaudio.__version__}")
    print(f"librosa: {librosa.__version__}")
    display(df.round(2))
Out:
torchaudio: 0.12.0
librosa: 0.9.1
                downsample (48 -> 44.1 kHz) time (ms)
                                              librosa functional transforms
sinc (width 64)                                   NaN      15.23       0.44
sinc (width 16)                                   NaN      24.25       0.40
kaiser_best                                     34.52      27.59       0.42
kaiser_fast                                     17.58      21.90       0.38
torchaudio: 0.12.0
librosa: 0.9.1
                downsample (16 -> 8 kHz) time (ms)
sinc (width 64)                                NaN       1.21       0.73
sinc (width 16)                                NaN       0.59       0.34
kaiser_best                                  12.36       2.03       0.82
kaiser_fast                                   4.39       0.73       0.36
torchaudio: 0.12.0
librosa: 0.9.1
                upsample (44.1 -> 48 kHz) time (ms)
sinc (width 64)                                 NaN      32.91       0.44
sinc (width 16)                                 NaN      35.77       0.37
kaiser_best                                   35.07      29.64       0.46
kaiser_fast                                   12.37      22.09       0.40
torchaudio: 0.12.0
librosa: 0.9.1
                upsample (8 -> 16 kHz) time (ms)
sinc (width 64)                              NaN       0.78       0.35
sinc (width 16)                              NaN       0.50       0.19
kaiser_best                                12.69       0.90       0.39
kaiser_fast                                 5.28       0.66       0.22
Total running time of the script: ( 0 minutes 5.492 seconds)
Gallery generated by Sphinx-Gallery
文档
访问 PyTorch 的全面开发人员文档
查看文档
教程
获取面向初学者和高级开发人员的深入教程
查看教程
资源
查找开发资源并解答您的问题
查看资源
