Note
Click here to download the full example code
Media Stream API - Pt. 2¶
This tutorial is the continuation of Media Stream API - Pt.1.
This shows how to use StreamReader for
Device inputs, such as microphone, webcam and screen recording
Generating synthetic audio / video
Applying preprocessing with custom filter expressions
import torch
import torchaudio
print(torch.__version__)
print(torchaudio.__version__)
Out:
1.12.0
0.12.0
try:
from torchaudio.io import StreamReader
except ModuleNotFoundError:
try:
import google.colab
print(
To enable running this notebook in Google Colab, install nightly
torch and torchaudio builds and the requisite third party libraries by
adding the following code block to the top of the notebook before running it:
!pip3 uninstall -y torch torchvision torchaudio
!pip3 install --pre torch torchaudio --extra-index-url https://download.pytorch.org/whl/nightly/cpu
!add-apt-repository -y ppa:savoury1/ffmpeg4
!apt-get -qq install -y ffmpeg
pass
raise
import IPython
base_url = "https://download.pytorch.org/torchaudio/tutorial-assets"
AUDIO_URL = f"{base_url}/Lab41-SRI-VOiCES-src-sp0307-ch127535-sg0042.wav"
VIDEO_URL = f"{base_url}/stream-api/NASAs_Most_Scientifically_Complex_Space_Observatory_Requires_Precision-MP4.mp4"
Audio / Video device input¶
See also
Given that the system has proper media devices and libavdevice is configured to use the devices, the streaming API can pull media streams from these devices.
To do this, we pass additional parameters format
and option
to the constructor. format
specifies the device component and
option
dictionary is specific to the specified component.
The exact arguments to be passed depend on the system configuration. Please refer to https://ffmpeg.org/ffmpeg-devices.html for the detail.
The following example illustrates how one can do this on MacBook Pro.
First, we need to check the available devices.
$ ffmpeg -f avfoundation -list_devices true -i ""
[AVFoundation indev @ 0x143f04e50] AVFoundation video devices:
[AVFoundation indev @ 0x143f04e50] [0] FaceTime HD Camera
[AVFoundation indev @ 0x143f04e50] [1] Capture screen 0
[AVFoundation indev @ 0x143f04e50] AVFoundation audio devices:
[AVFoundation indev @ 0x143f04e50] [0] MacBook Pro Microphone
We use FaceTime HD Camera as video device (index 0) and MacBook Pro Microphone as audio device (index 0).
If we do not pass any option
, the device uses its default
configuration. The decoder might not support the configuration.
>>> StreamReader(
... src="0:0", # The first 0 means `FaceTime HD Camera`, and
... # the second 0 indicates `MacBook Pro Microphone`.
... format="avfoundation",
[avfoundation @ 0x125d4fe00] Selected framerate (29.970030) is not supported by the device.
[avfoundation @ 0x125d4fe00] Supported modes:
[avfoundation @ 0x125d4fe00] 1280x720@[1.000000 30.000000]fps
[avfoundation @ 0x125d4fe00] 640x480@[1.000000 30.000000]fps
Traceback (most recent call last):
File "<stdin>", line 1, in <module>
RuntimeError: Failed to open the input: 0:0
By providing option
, we can change the format that the device
streams to a format supported by decoder.
>>> streamer = StreamReader(
... src="0:0",
... option={"framerate": "30", "pixel_format": "bgr0"},
>>> for i in range(streamer.num_src_streams):
... print(streamer.get_src_stream_info(i))
SourceVideoStream(media_type='video', codec='rawvideo', codec_long_name='raw video', format='bgr0', bit_rate=0, width=640, height=480, frame_rate=30.0)
SourceAudioStream(media_type='audio', codec='pcm_f32le', codec_long_name='PCM 32-bit floating point little-endian', format='flt', bit_rate=3072000, sample_rate=48000.0, num_channels=2)
Synthetic source streams¶
As a part of device integration, ffmpeg provides a “virtual device” interface. This interface provides synthetic audio / video data generation using libavfilter.
To use this, we set format=lavfi
and provide a filter description
to src
The detail of filter description can be found at https://ffmpeg.org/ffmpeg-filters.html
Audio Examples¶
Sine wave¶
https://ffmpeg.org/ffmpeg-filters.html#sine
StreamReader(src="sine=sample_rate=8000:frequency=360", format="lavfi")
Signal with arbitral expression¶
https://ffmpeg.org/ffmpeg-filters.html#aevalsrc
# 5 Hz binaural beats on a 360 Hz carrier
StreamReader(
src=(
'aevalsrc='
'sample_rate=8000:'
'exprs=0.1*sin(2*PI*(360-5/2)*t)|0.1*sin(2*PI*(360+5/2)*t)'
format='lavfi',
Noise¶
https://ffmpeg.org/ffmpeg-filters.html#anoisesrc
StreamReader(src="anoisesrc=color=pink:sample_rate=8000:amplitude=0.5", format="lavfi")
Video Examples¶
Cellular automaton¶
https://ffmpeg.org/ffmpeg-filters.html#cellauto
StreamReader(src=f"cellauto", format="lavfi")
Mandelbrot¶
StreamReader(src=f"mandelbrot", format="lavfi")
MPlayer Test patterns¶
https://ffmpeg.org/ffmpeg-filters.html#mptestsrc
StreamReader(src=f"mptestsrc", format="lavfi")
John Conway’s life game¶
https://ffmpeg.org/ffmpeg-filters.html#life
StreamReader(src=f"life", format="lavfi")
Sierpinski carpet/triangle fractal¶
https://ffmpeg.org/ffmpeg-filters.html#sierpinski
StreamReader(src=f"sierpinski", format="lavfi")
Custom filters¶
When defining an output stream, you can use
add_audio_stream()
and
add_video_stream()
methods.
These methods take filter_desc
argument, which is a string
formatted according to ffmpeg’s
filter expression.
The difference between add_basic_(audio|video)_stream
and
add_(audio|video)_stream
is that add_basic_(audio|video)_stream
constructs the filter expression and passes it to the same underlying
implementation. Everything add_basic_(audio|video)_stream
can be
achieved with add_(audio|video)_stream
Note
When applying custom filters, the client code must convert the audio/video stream to one of the formats that torchaudio can convert to tensor format. This can be achieved, for example, by applying
format=pix_fmts=rgb24
to video stream andaformat=sample_fmts=fltp
to audio stream.Each output stream has separate filter graph. Therefore, it is not possible to use different input/output streams for a filter expression. However, it is possible to split one input stream into multiple of them, and merge them later.
Audio Examples¶
# fmt: off
descs = [
# No filtering
"anull",
# Apply a highpass filter then a lowpass filter
"highpass=f=200,lowpass=f=1000",
# Manipulate spectrogram
"afftfilt="
"real='hypot(re,im)*sin(0)':"
"imag='hypot(re,im)*cos(0)':"
"win_size=512:"
"overlap=0.75"
"afftfilt="
"real='hypot(re,im)*cos((random(0)*2-1)*2*3.14)':"
"imag='hypot(re,im)*sin((random(1)*2-1)*2*3.14)':"
"win_size=128:"
"overlap=0.8"
# fmt: on
sample_rate = 8000
streamer = StreamReader(AUDIO_URL)
for desc in descs:
streamer.add_audio_stream(
frames_per_chunk=40000,
filter_desc=f"aresample={sample_rate},{desc},aformat=sample_fmts=fltp",
chunks = next(streamer.stream())
def _display(i):
print("filter_desc:", streamer.get_out_stream_info(i).filter_description)
_, axs = plt.subplots(2, 1)
waveform = chunks[i][:, 0]
axs[0].plot(waveform)
axs[0].grid(True)
axs[0].set_ylim([-1, 1])
plt.setp(axs[0].get_xticklabels(), visible=False)
axs[1].specgram(waveform, Fs=sample_rate)
return IPython.display.Audio(chunks[i].T, rate=sample_rate)
Highpass / lowpass filter¶
_display(1)
Out:
filter_desc: aresample=8000,highpass=f=200,lowpass=f=1000,aformat=sample_fmts=fltp
FFT filter - Robot 🤖¶
_display(2)
Out:
filter_desc: aresample=8000,afftfilt=real='hypot(re,im)*sin(0)':imag='hypot(re,im)*cos(0)':win_size=512:overlap=0.75,aformat=sample_fmts=fltp
FFT filter - Whisper¶
_display(3)
Out:
filter_desc: aresample=8000,afftfilt=real='hypot(re,im)*cos((random(0)*2-1)*2*3.14)':imag='hypot(re,im)*sin((random(1)*2-1)*2*3.14)':win_size=128:overlap=0.8,aformat=sample_fmts=fltp
Video Examples¶
# fmt: off
descs = [
# No effect
"null",
# Split the input stream and apply horizontal flip to the right half.
"split [main][tmp];"
"[tmp] crop=iw/2:ih:0:0, hflip [flip];"
"[main][flip] overlay=W/2:0"
# Edge detection
"edgedetect=mode=canny",
# Rotate image by randomly and fill the background with brown
"rotate=angle=-random(1)*PI:fillcolor=brown",
# Manipulate pixel values based on the coordinate
"geq=r='X/W*r(X,Y)':g='(1-X/W)*g(X,Y)':b='(H-Y)/H*b(X,Y)'"
# fmt: on
streamer = StreamReader(VIDEO_URL)
for desc in descs:
streamer.add_video_stream(
frames_per_chunk=30,
filter_desc=f"fps=10,{desc},format=pix_fmts=rgb24",
streamer.seek(12)
def _display(i):
_, axs = plt.subplots(1, 3, figsize=(8, 1.9))
chunk = chunks[i]
for j in range(3):
axs[j].imshow(chunk[10 * j + 1].permute(1, 2, 0))
axs[j].set_axis_off()
plt.tight_layout()
plt.show(block=False)
Mirror¶
_display(1)
Out:
filter_desc: fps=10,split [main][tmp];[tmp] crop=iw/2:ih:0:0, hflip [flip];[main][flip] overlay=W/2:0,format=pix_fmts=rgb24
Random rotation¶
_display(3)
Out:
filter_desc: fps=10,rotate=angle=-random(1)*PI:fillcolor=brown,format=pix_fmts=rgb24
Pixel manipulation¶
_display(4)
Out:
filter_desc: fps=10,geq=r='X/W*r(X,Y)':g='(1-X/W)*g(X,Y)':b='(H-Y)/H*b(X,Y)',format=pix_fmts=rgb24
Total running time of the script: ( 0 minutes 10.591 seconds)
