目录
Speech Enhancement with MVDR Beamforming
Author Zhaoheng Ni
1. Overview
This is a tutorial on applying Minimum Variance Distortionless Response (MVDR) beamforming to estimate enhanced speech with TorchAudio.
Steps:
import torch
import torchaudio
import torchaudio.functional as F
print(torch.__version__)
print(torchaudio.__version__)
Out:
1.12.0
0.12.0
2. Preparation
First, we import the necessary packages and retrieve the data.
The multi-channel audio example is selected from ConferencingSpeech dataset.
The original filename is
SSB07200001\#noise-sound-bible-0038\#7.86_6.16_3.00_3.14_4.84_134.5285_191.7899_0.4735\#15217\#25.16333303751458\#0.2101221178590021.wav
which was generated with:
  • SSB07200001.wav from AISHELL-3 (Apache License v.2.0)
  • noise-sound-bible-0038.wav from MUSAN (Attribution 4.0 International — CC BY 4.0)
from IPython.display import Audio
from torchaudio.utils import download_asset
SAMPLE_RATE = 16000
SAMPLE_CLEAN = download_asset("tutorial-assets/mvdr/clean_speech.wav")
SAMPLE_NOISE = download_asset("tutorial-assets/mvdr/noise.wav")
Out:
  0%|          | 0.00/0.98M [00:00<?, ?B/s]
100%|##########| 0.98M/0.98M [00:00<00:00, 81.9MB/s]
  0%|          | 0.00/1.95M [00:00<?, ?B/s]
100%|##########| 1.95M/1.95M [00:00<00:00, 44.2MB/s]
2.1. Helper functions
def plot_spectrogram(stft, title="Spectrogram", xlim=None):
    magnitude = stft.abs()
    spectrogram = 20 * torch.log10(magnitude + 1e-8).numpy()
    figure, axis = plt.subplots(1, 1)
    img = axis.imshow(spectrogram, cmap="viridis", vmin=-100, vmax=0, origin="lower", aspect="auto")
    figure.suptitle(title)
    plt.colorbar(img, ax=axis)
    plt.show()
def plot_mask(mask, title="Mask", xlim=None):
    mask = mask.numpy()
    img = axis.imshow(mask, cmap="viridis", origin="lower", aspect="auto")
    plt.show()
def si_snr(estimate, reference, epsilon=1e-8):
    estimate = estimate - estimate.mean()
    reference = reference - reference.mean()
    reference_pow = reference.pow(2).mean(axis=1, keepdim=True)
    mix_pow = (estimate * reference).mean(axis=1, keepdim=True)
    scale = mix_pow / (reference_pow + epsilon)
    reference = scale * reference
    error = estimate - reference
    error_pow = error.pow(2)
    reference_pow = reference_pow.mean(axis=1)
    error_pow = error_pow.mean(axis=1)
    si_snr = 10 * torch.log10(reference_pow) - 10 * torch.log10(error_pow)
    return si_snr.item()
3. Generate Ideal Ratio Masks (IRMs)
3.1. Load audio data
waveform_clean, sr = torchaudio.load(SAMPLE_CLEAN)
waveform_noise, sr2 = torchaudio.load(SAMPLE_NOISE)
assert sr == sr2 == SAMPLE_RATE
# The mixture waveform is a combination of clean and noise waveforms
waveform_mix = waveform_clean + waveform_noise
Note: To improve computational robustness, it is recommended to represent the waveforms as double-precision floating point (torch.float64 or torch.double) values.
waveform_mix = waveform_mix.to(torch.double)
waveform_clean = waveform_clean.to(torch.double)
waveform_noise = waveform_noise.to(torch.double)
3.2. Compute STFT coefficients
N_FFT = 1024
N_HOP = 256
stft = torchaudio.transforms.Spectrogram(
    n_fft=N_FFT,
    hop_length=N_HOP,
    power=None,
istft = torchaudio.transforms.InverseSpectrogram(n_fft=N_FFT, hop_length=N_HOP)
stft_mix = stft(waveform_mix)
stft_clean = stft(waveform_clean)
stft_noise = stft(waveform_noise)
3.2.1. Visualize mixture speech
plot_spectrogram(stft_mix[0], "Spectrogram of Mixture Speech (dB)")
Audio(waveform_mix[0], rate=SAMPLE_RATE)
3.2.2. Visualize clean speech
plot_spectrogram(stft_clean[0], "Spectrogram of Clean Speech (dB)")
Audio(waveform_clean[0], rate=SAMPLE_RATE)
3.2.3. Visualize noise
plot_spectrogram(stft_noise[0], "Spectrogram of Noise (dB)")
Audio(waveform_noise[0], rate=SAMPLE_RATE)
3.3. Define the reference microphone
We choose the first microphone in the array as the reference channel for demonstration. The selection of the reference channel may depend on the design of the microphone array.
You can also apply an end-to-end neural network which estimates both the reference channel and the PSD matrices, then obtains the enhanced STFT coefficients by the MVDR module.
3.4. Compute IRMs
def get_irms(stft_clean, stft_noise):
    mag_clean = stft_clean.abs() ** 2
    mag_noise = stft_noise.abs() ** 2
    irm_speech = mag_clean / (mag_clean + mag_noise)
    irm_noise = mag_noise / (mag_clean + mag_noise)
    return irm_speech[REFERENCE_CHANNEL], irm_noise[REFERENCE_CHANNEL]
irm_speech, irm_noise = get_irms(stft_clean, stft_noise)
3.4.1. Visualize IRM of target speech
plot_mask(irm_speech, "IRM of the Target Speech")
3.4.2. Visualize IRM of noise
plot_mask(irm_noise, "IRM of the Noise")
IRM of the Noise
4. Compute PSD matrices
torchaudio.transforms.PSD() computes the time-invariant PSD matrix given the multi-channel complex-valued STFT coefficients of the mixture speech and the time-frequency mask.
The shape of the PSD matrix is (…, freq, channel, channel).
psd_transform = torchaudio.transforms.PSD()
psd_speech = psd_transform(stft_mix, irm_speech)
psd_noise = psd_transform(stft_mix, irm_noise)
5. Beamforming using SoudenMVDR
5.1. Apply beamforming
torchaudio.transforms.SoudenMVDR() takes the multi-channel complexed-valued STFT coefficients of the mixture speech, PSD matrices of target speech and noise, and the reference channel inputs.
The output is a single-channel complex-valued STFT coefficients of the enhanced speech. We can then obtain the enhanced waveform by passing this output to the torchaudio.transforms.InverseSpectrogram() module.
mvdr_transform = torchaudio.transforms.SoudenMVDR()
stft_souden = mvdr_transform(stft_mix, psd_speech, psd_noise, reference_channel=REFERENCE_CHANNEL)
waveform_souden = istft(stft_souden, length=waveform_mix.shape[-1])
5.2. Result for SoudenMVDR
plot_spectrogram(stft_souden, "Enhanced Spectrogram by SoudenMVDR (dB)")
waveform_souden = waveform_souden.reshape(1, -1)
print(f"Si-SNR score: {si_snr(waveform_souden, waveform_clean[0:1])}")
Audio(waveform_souden, rate=SAMPLE_RATE)
Out:
Si-SNR score: 15.035907456979267
6. Beamforming using RTFMVDR
6.1. Compute RTF
TorchAudio offers two methods for computing the RTF matrix of a target speech:
6.2. Apply beamforming
torchaudio.transforms.RTFMVDR() takes the multi-channel complexed-valued STFT coefficients of the mixture speech, RTF matrix of target speech, PSD matrix of noise, and the reference channel inputs.
mvdr_transform = torchaudio.transforms.RTFMVDR()
# compute the enhanced speech based on F.rtf_evd
stft_rtf_evd = mvdr_transform(stft_mix, rtf_evd, psd_noise, reference_channel=REFERENCE_CHANNEL)
waveform_rtf_evd = istft(stft_rtf_evd, length=waveform_mix.shape[-1])
# compute the enhanced speech based on F.rtf_power
stft_rtf_power = mvdr_transform(stft_mix, rtf_power, psd_noise, reference_channel=REFERENCE_CHANNEL)
waveform_rtf_power = istft(stft_rtf_power, length=waveform_mix.shape[-1])
6.3. Result for RTFMVDR with rtf_evd
plot_spectrogram(stft_rtf_evd, "Enhanced Spectrogram by RTFMVDR and F.rtf_evd (dB)")
waveform_rtf_evd = waveform_rtf_evd.reshape(1, -1)
print(f"Si-SNR score: {si_snr(waveform_rtf_evd, waveform_clean[0:1])}")
Audio(waveform_rtf_evd, rate=SAMPLE_RATE)
Out:
Si-SNR score: 16.563734673832403
6.4. Result for RTFMVDR with rtf_power
plot_spectrogram(stft_rtf_power, "Enhanced Spectrogram by RTFMVDR and F.rtf_evd (dB)")
waveform_rtf_power = waveform_rtf_power.reshape(1, -1)
print(f"Si-SNR score: {si_snr(waveform_rtf_power, waveform_clean[0:1])}")
Audio(waveform_rtf_power, rate=SAMPLE_RATE)
Out:
Si-SNR score: 17.820481909930376
Total running time of the script: ( 0 minutes 1.695 seconds)
Gallery generated by Sphinx-Gallery
文档
访问 PyTorch 的全面开发人员文档
查看文档
教程
获取面向初学者和高级开发人员的深入教程
查看教程
资源
查找开发资源并解答您的问题
查看资源
