目录
Supported Features
Each TorchAudio API supports a subset of PyTorch features, such as devices and data types. Supported features are indicated in API references like the following:
This feature supports the following devices: CPU, CUDA This API supports the following properties: Autograd, TorchScript
These icons mean that they are verified through automated testing.
Note
Missing feature icons mean that they are not tested, and this can mean different things, depending on the API.
  1. The API is compatible with the feature but not tested.
  2. The API is not compatible with the feature.
In case of 2, the API might explicitly raise an error, but that is not guaranteed. For example, APIs without an Autograd badge might throw an error during backpropagation, or silently return a wrong gradient.
If you use an API that hasn’t been labeled as supporting a feature, you might want to first verify that the feature works fine.
Devices
CPU
TorchAudio APIs that support CPU can perform their computation on CPU tensors.
CUDA
This feature supports the following devices: CUDA
TorchAudio APIs that support CUDA can perform their computation on CUDA devices.
In case of functions, move the tensor arguments to CUDA device before passing them to a function.
For example:
cuda = torch.device("cuda")
waveform = waveform.to(cuda)
spectrogram = torchaudio.functional.spectrogram(waveform)
Classes with CUDA support are implemented with torch.nn.Module(). It is also necessary to move the instance to CUDA device, before passing CUDA tensors.
For example:
resampler = torchaudio.transforms.Resample(8000, 16000)
resampler.to(cuda)
waveform.to(cuda)
resampled = resampler(waveform)
Properties
Autograd
TorchAudio APIs with autograd support can correctly backpropagate gradients.
For the basics of autograd, please refer to this tutorial.
Note
APIs without this mark may or may not raise an error during backpropagation. The absence of an error raised during backpropagation does not necessarily mean the gradient is correct.
TorchScript
This API supports the following properties: TorchScript
TorchAudio APIs with TorchScript support can be serialized and executed in non-Python environments.
For details on TorchScript, please refer to the documentation.
文档
访问 PyTorch 的全面开发人员文档
查看文档
教程
获取面向初学者和高级开发人员的深入教程
查看教程
资源
查找开发资源并解答您的问题
查看资源
