目录
Speech Recognition with Wav2Vec2
Author: Moto Hira
This tutorial shows how to perform speech recognition using using pre-trained models from wav2vec 2.0 [paper].
Overview
The process of speech recognition looks like the following.
  1. Extract the acoustic features from audio waveform
  2. Estimate the class of the acoustic features frame-by-frame
  3. Generate hypothesis from the sequence of the class probabilities
Torchaudio provides easy access to the pre-trained weights and associated information, such as the expected sample rate and class labels. They are bundled together and available under torchaudio.pipelines module.
Preparation
First we import the necessary packages, and fetch data that we work on.
# %matplotlib inline
import os
import torch
import torchaudio
import requests
import matplotlib
import IPython
matplotlib.rcParams['figure.figsize'] = [16.0, 4.8]
torch.random.manual_seed(0)
device = torch.device('cuda' if torch.cuda.is_available() else 'cpu')
print(torch.__version__)
print(torchaudio.__version__)
print(device)
SPEECH_URL = "https://pytorch-tutorial-assets.s3.amazonaws.com/VOiCES_devkit/source-16k/train/sp0307/Lab41-SRI-VOiCES-src-sp0307-ch127535-sg0042.wav"
SPEECH_FILE = "_assets/speech.wav"
if not os.path.exists(SPEECH_FILE):
  os.makedirs('_assets', exist_ok=True)
  with open(SPEECH_FILE, 'wb') as file:
    file.write(requests.get(SPEECH_URL).content)
Out:
1.10.0+cpu
0.10.0+cpu
cpu
Creating a pipeline
First, we will create a Wav2Vec2 model that performs the feature extraction and the classification.
There are two types of Wav2Vec2 pre-trained weights available in torchaudio. The ones fine-tuned for ASR task, and the ones not fine-tuned.
Wav2Vec2 (and HuBERT) models are trained in self-supervised manner. They are firstly trained with audio only for representation learning, then fine-tuned for a specific task with additional labels.
The pre-trained weights without fine-tuning can be fine-tuned for other downstream tasks as well, but this tutorial does not cover that.
We will use torchaudio.pipelines.WAV2VEC2_ASR_BASE_960H() here.
There are multiple models available as torchaudio.pipelines. Please check the documentation for the detail of how they are trained.
The bundle object provides the interface to instantiate model and other information. Sampling rate and the class labels are found as follow.
bundle = torchaudio.pipelines.WAV2VEC2_ASR_BASE_960H
print("Sample Rate:", bundle.sample_rate)
print("Labels:", bundle.get_labels())
Out:
Sample Rate: 16000
Labels: ('<s>', '<pad>', '</s>', '<unk>', '|', 'E', 'T', 'A', 'O', 'N', 'I', 'H', 'S', 'R', 'D', 'L', 'U', 'M', 'W', 'C', 'F', 'G', 'Y', 'P', 'B', 'V', 'K', "'", 'X', 'J', 'Q', 'Z')
Model can be constructed as following. This process will automatically fetch the pre-trained weights and load it into the model.
model = bundle.get_model().to(device)
print(model.__class__)
Out:
Downloading: "https://download.pytorch.org/torchaudio/models/wav2vec2_fairseq_base_ls960_asr_ls960.pth" to /root/.cache/torch/hub/checkpoints/wav2vec2_fairseq_base_ls960_asr_ls960.pth
  0%|          | 0.00/360M [00:00<?, ?B/s]
  1%|1         | 4.09M/360M [00:00<00:09, 38.0MB/s]
  3%|2         | 9.09M/360M [00:00<00:08, 41.6MB/s]
  4%|3         | 14.1M/360M [00:00<00:07, 45.8MB/s]
  7%|6         | 24.3M/360M [00:00<00:05, 68.6MB/s]
  9%|9         | 34.1M/360M [00:00<00:05, 62.3MB/s]
 11%|#1        | 40.3M/360M [00:00<00:07, 43.6MB/s]
 13%|#2        | 45.2M/360M [00:01<00:09, 34.5MB/s]
 14%|#3        | 49.1M/360M [00:01<00:11, 28.2MB/s]
 15%|#5        | 55.6M/360M [00:01<00:09, 34.5MB/s]
 17%|#6        | 60.2M/360M [00:01<00:08, 37.3MB/s]
 20%|##        | 73.0M/360M [00:01<00:05, 58.6MB/s]
 23%|##2       | 82.8M/360M [00:01<00:04, 68.8MB/s]
 25%|##5       | 90.5M/360M [00:01<00:04, 66.8MB/s]
 27%|##7       | 97.6M/360M [00:02<00:04, 58.5MB/s]
 29%|##8       | 104M/360M [00:02<00:04, 57.3MB/s]
 30%|###       | 110M/360M [00:02<00:05, 49.5MB/s]
 32%|###1      | 115M/360M [00:02<00:05, 45.9MB/s]
 35%|###5      | 128M/360M [00:02<00:03, 62.9MB/s]
 37%|###7      | 134M/360M [00:02<00:04, 55.6MB/s]
 40%|###9      | 144M/360M [00:02<00:03, 65.3MB/s]
 42%|####2     | 152M/360M [00:03<00:03, 71.0MB/s]
 44%|####4     | 160M/360M [00:03<00:03, 61.1MB/s]
 46%|####6     | 166M/360M [00:03<00:05, 40.1MB/s]
 50%|#####     | 181M/360M [00:03<00:03, 61.7MB/s]
 53%|#####3    | 192M/360M [00:03<00:02, 66.4MB/s]
 57%|#####6    | 205M/360M [00:03<00:02, 80.2MB/s]
 59%|#####9    | 214M/360M [00:04<00:02, 61.2MB/s]
 62%|######1   | 223M/360M [00:04<00:02, 56.8MB/s]
 64%|######3   | 229M/360M [00:04<00:03, 42.7MB/s]
 67%|######6   | 240M/360M [00:04<00:02, 50.5MB/s]
 71%|#######   | 255M/360M [00:04<00:01, 57.6MB/s]
 72%|#######2  | 261M/360M [00:05<00:02, 47.0MB/s]
 75%|#######4  | 269M/360M [00:05<00:01, 52.8MB/s]
 76%|#######6  | 275M/360M [00:05<00:01, 49.3MB/s]
 80%|#######9  | 288M/360M [00:05<00:01, 62.7MB/s]
 82%|########1 | 294M/360M [00:05<00:01, 55.5MB/s]
 83%|########3 | 300M/360M [00:05<00:01, 46.0MB/s]
 85%|########4 | 305M/360M [00:06<00:01, 45.1MB/s]
 89%|########8 | 320M/360M [00:06<00:00, 67.2MB/s]
 91%|######### | 327M/360M [00:06<00:00, 68.3MB/s]
 93%|#########3| 336M/360M [00:06<00:00, 71.6MB/s]
 96%|#########6| 347M/360M [00:06<00:00, 83.0MB/s]
 99%|#########8| 356M/360M [00:06<00:00, 67.2MB/s]
100%|##########| 360M/360M [00:06<00:00, 55.7MB/s]
<class 'torchaudio.models.wav2vec2.model.Wav2Vec2Model'>
Loading data
We will use the speech data from VOiCES dataset, which is licensed under Creative Commos BY 4.0.
IPython.display.Audio(SPEECH_FILE)
To load data, we use torchaudio.load().
If the sampling rate is different from what the pipeline expects, then we can use torchaudio.functional.resample() for resampling.
Note
waveform, sample_rate = torchaudio.load(SPEECH_FILE)
waveform = waveform.to(device)
if sample_rate != bundle.sample_rate:
  waveform = torchaudio.functional.resample(waveform, sample_rate, bundle.sample_rate)
Extracting acoustic features
The next step is to extract acoustic features from the audio.
Note
Wav2Vec2 models fine-tuned for ASR task can perform feature extraction and classification with one step, but for the sake of the tutorial, we also show how to perform feature extraction here.
with torch.inference_mode():
  features, _ = model.extract_features(waveform)
The returned features is a list of tensors. Each tensor is the output of a transformer layer.
fig, ax = plt.subplots(len(features), 1, figsize=(16, 4.3 * len(features)))
for i, feats in enumerate(features):
  ax[i].imshow(feats[0].cpu())
  ax[i].set_title(f"Feature from transformer layer {i+1}")
  ax[i].set_xlabel("Feature dimension")
  ax[i].set_ylabel("Frame (time-axis)")
plt.tight_layout()
plt.show()
Feature from transformer layer 1, Feature from transformer layer 2, Feature from transformer layer 3, Feature from transformer layer 4, Feature from transformer layer 5, Feature from transformer layer 6, Feature from transformer layer 7, Feature from transformer layer 8, Feature from transformer layer 9, Feature from transformer layer 10, Feature from transformer layer 11, Feature from transformer layer 12
Feature classification
Once the acoustic features are extracted, the next step is to classify them into a set of categories.
Wav2Vec2 model provides method to perform the feature extraction and classification in one step.
The output is in the form of logits. It is not in the form of probability.
Let’s visualize this.
plt.imshow(emission[0].cpu().T)
plt.title("Classification result")
plt.xlabel("Frame (time-axis)")
plt.ylabel("Class")
plt.show()
print("Class labels:", bundle.get_labels())
Out:
Class labels: ('<s>', '<pad>', '</s>', '<unk>', '|', 'E', 'T', 'A', 'O', 'N', 'I', 'H', 'S', 'R', 'D', 'L', 'U', 'M', 'W', 'C', 'F', 'G', 'Y', 'P', 'B', 'V', 'K', "'", 'X', 'J', 'Q', 'Z')
We can see that there are strong indications to certain labels across the time line.
Generating transcripts
From the sequence of label probabilities, now we want to generate transcripts. The process to generate hypotheses is often called “decoding”.
Decoding is more elaborate than simple classification because decoding at certain time step can be affected by surrounding observations.
For example, take a word like night and knight. Even if their prior probability distribution are differnt (in typical conversations, night would occur way more often than knight), to accurately generate transcripts with knight, such as a knight with a sword, the decoding process has to postpone the final decision until it sees enough context.
There are many decoding techniques proposed, and they require external resources, such as word dictionary and language models.
In this tutorial, for the sake of simplicity, we will perform greedy decoding which does not depend on such external components, and simply pick up the best hypothesis at each time step. Therefore, the context information are not used, and only one transcript can be generated.
We start by defining greedy decoding algorithm.
class GreedyCTCDecoder(torch.nn.Module):
  def __init__(self, labels, blank=0):
    super().__init__()
    self.labels = labels
    self.blank = blank
  def forward(self, emission: torch.Tensor) -> str:
    """Given a sequence emission over labels, get the best path string
    Args:
      emission (Tensor): Logit tensors. Shape `[num_seq, num_label]`.
    Returns:
      str: The resulting transcript
    indices = torch.argmax(emission, dim=-1)  # [num_seq,]
    indices = torch.unique_consecutive(indices, dim=-1)
    indices = [i for i in indices if i != self.blank]
    return ''.join([self.labels[i] for i in indices])
Now create the decoder object and decode the transcript.
decoder = GreedyCTCDecoder(labels=bundle.get_labels())
transcript = decoder(emission[0])
Let’s check the result and listen again to the audio.
print(transcript)
Out:
I|HAD|THAT|CURIOSITY|BESIDE|ME|AT|THIS|MOMENT|
The ASR model is fine-tuned using a loss function called Connectionist Temporal Classification (CTC). The detail of CTC loss is explained here. In CTC a blank token (ϵ) is a special token which represents a repetition of the previous symbol. In decoding, these are simply ignored.
Conclusion
In this tutorial, we looked at how to use torchaudio.pipelines to perform acoustic feature extraction and speech recognition. Constructing a model and getting the emission is as short as two lines.
model = torchaudio.pipelines.WAV2VEC2_ASR_BASE_960H.get_model()
emission = model(waveforms, ...)
Total running time of the script: ( 0 minutes 14.667 seconds)
Gallery generated by Sphinx-Gallery
文档
访问 PyTorch 的全面开发人员文档
查看文档
教程
获取面向初学者和高级开发人员的深入教程
查看教程
资源
查找开发资源并解答您的问题
查看资源
