Note
Click here to download the full example code
Forced Alignment with Wav2Vec2
Author Moto Hira
This tutorial shows how to align transcript to speech with
torchaudio
, using CTC segmentation algorithm described in
CTC-Segmentation of Large Corpora for German End-to-end Speech
Recognition.
Overview
The process of alignment looks like the following.
Estimate the frame-wise label probability from audio waveform
Generate the trellis matrix which represents the probability of labels aligned at time step.
Find the most likely path from the trellis matrix.
In this example, we use torchaudio
’s Wav2Vec2
model for
acoustic feature extraction.
Preparation
First we import the necessary packages, and fetch data that we work on.
# %matplotlib inline
import os
from dataclasses import dataclass
import torch
import torchaudio
import requests
import matplotlib
import IPython
matplotlib.rcParams['figure.figsize'] = [16.0, 4.8]
torch.random.manual_seed(0)
device = torch.device('cuda' if torch.cuda.is_available() else 'cpu')
print(torch.__version__)
print(torchaudio.__version__)
print(device)
SPEECH_URL = 'https://download.pytorch.org/torchaudio/tutorial-assets/Lab41-SRI-VOiCES-src-sp0307-ch127535-sg0042.wav'
SPEECH_FILE = '_assets/speech.wav'
if not os.path.exists(SPEECH_FILE):
os.makedirs('_assets', exist_ok=True)
with open(SPEECH_FILE, 'wb') as file:
file.write(requests.get(SPEECH_URL).content)
Out:
1.10.0+cpu
0.10.0+cpu
cpu
Generate frame-wise label probability
The first step is to generate the label class porbability of each aduio
frame. We can use a Wav2Vec2 model that is trained for ASR. Here we use
torchaudio.pipelines.WAV2VEC2_ASR_BASE_960H()
torchaudio
provides easy access to pretrained models with associated
labels.
Note
In the subsequent sections, we will compute the probability in
log-domain to avoid numerical instability. For this purpose, we
normalize the emission
with torch.log_softmax()
bundle = torchaudio.pipelines.WAV2VEC2_ASR_BASE_960H
model = bundle.get_model().to(device)
labels = bundle.get_labels()
with torch.inference_mode():
waveform, _ = torchaudio.load(SPEECH_FILE)
emissions, _ = model(waveform.to(device))
emissions = torch.log_softmax(emissions, dim=-1)
emission = emissions[0].cpu().detach()
Visualization
print(labels)
plt.imshow(emission.T)
plt.colorbar()
plt.title("Frame-wise class probability")
plt.xlabel("Time")
plt.ylabel("Labels")
plt.show()
Out:
('<s>', '<pad>', '</s>', '<unk>', '|', 'E', 'T', 'A', 'O', 'N', 'I', 'H', 'S', 'R', 'D', 'L', 'U', 'M', 'W', 'C', 'F', 'G', 'Y', 'P', 'B', 'V', 'K', "'", 'X', 'J', 'Q', 'Z')
Generate alignment probability (trellis)
From the emission matrix, next we generate the trellis which represents the probability of transcript labels occur at each time frame.
Trellis is 2D matrix with time axis and label axis. The label axis represents the transcript that we are aligning. In the following, we use \(t\) to denote the index in time axis and \(j\) to denote the index in label axis. \(c_j\) represents the label at label index \(j\).
To generate, the probability of time step \(t+1\), we look at the trellis from time step \(t\) and emission at time step \(t+1\). There are two path to reach to time step \(t+1\) with label \(c_{j+1}\). The first one is the case where the label was \(c_{j+1}\) at \(t\) and there was no label change from \(t\) to \(t+1\). The other case is where the label was \(c_j\) at \(t\) and it transitioned to the next label \(c_{j+1}\) at \(t+1\).
The follwoing diagram illustrates this transition.
Since we are looking for the most likely transitions, we take the more likely path for the value of \(k_{(t+1, j+1)}\), that is
\(k_{(t+1, j+1)} = max( k_{(t, j)} p(t+1, c_{j+1}), k_{(t, j+1)} p(t+1, repeat) )\)
where \(k\) represents is trellis matrix, and \(p(t, c_j)\) represents the probability of label \(c_j\) at time step \(t\). \(repeat\) represents the blank token from CTC formulation. (For the detail of CTC algorithm, please refer to the Sequence Modeling with CTC [distill.pub])
transcript = 'I|HAD|THAT|CURIOSITY|BESIDE|ME|AT|THIS|MOMENT'
dictionary = {c: i for i, c in enumerate(labels)}
tokens = [dictionary[c] for c in transcript]
print(list(zip(transcript, tokens)))
def get_trellis(emission, tokens, blank_id=0):
num_frame = emission.size(0)
num_tokens = len(tokens)
# Trellis has extra diemsions for both time axis and tokens.
# The extra dim for tokens represents <SoS> (start-of-sentence)
# The extra dim for time axis is for simplification of the code.
trellis = torch.full((num_frame+1, num_tokens+1), -float('inf'))
trellis[:, 0] = 0
for t in range(num_frame):
trellis[t+1, 1:] = torch.maximum(
# Score for staying at the same token
trellis[t, 1:] + emission[t, blank_id],
# Score for changing to the next token
trellis[t, :-1] + emission[t, tokens],
return trellis
trellis = get_trellis(emission, tokens)
Out:
[('I', 10), ('|', 4), ('H', 11), ('A', 7), ('D', 14), ('|', 4), ('T', 6), ('H', 11), ('A', 7), ('T', 6), ('|', 4), ('C', 19), ('U', 16), ('R', 13), ('I', 10), ('O', 8), ('S', 12), ('I', 10), ('T', 6), ('Y', 22), ('|', 4), ('B', 24), ('E', 5), ('S', 12), ('I', 10), ('D', 14), ('E', 5), ('|', 4), ('M', 17), ('E', 5), ('|', 4), ('A', 7), ('T', 6), ('|', 4), ('T', 6), ('H', 11), ('I', 10), ('S', 12), ('|', 4), ('M', 17), ('O', 8), ('M', 17), ('E', 5), ('N', 9), ('T', 6)]
Find the most likely path (backtracking)
Once the trellis is generated, we will traverse it following the elements with high probability.
We will start from the last label index with the time step of highest probability, then, we traverse back in time, picking stay (\(c_j \rightarrow c_j\)) or transition (\(c_j \rightarrow c_{j+1}\)), based on the post-transition probability \(k_{t, j} p(t+1, c_{j+1})\) or \(k_{t, j+1} p(t+1, repeat)\).
Transition is done once the label reaches the beginning.
The trellis matrix is used for path-finding, but for the final probability of each segment, we take the frame-wise probability from emission matrix.
@dataclass
class Point:
token_index: int
time_index: int
score: float
def backtrack(trellis, emission, tokens, blank_id=0):
# Note:
# j and t are indices for trellis, which has extra dimensions
# for time and tokens at the beginning.
# When refering to time frame index `T` in trellis,
# the corresponding index in emission is `T-1`.
# Similarly, when refering to token index `J` in trellis,
# the corresponding index in transcript is `J-1`.
j = trellis.size(1) - 1
t_start = torch.argmax(trellis[:, j]).item()
path = []
for t in range(t_start, 0, -1):
# 1. Figure out if the current position was stay or change
# Note (again):
# `emission[J-1]` is the emission at time frame `J` of trellis dimension.
# Score for token staying the same from time frame J-1 to T.
stayed = trellis[t-1, j] + emission[t-1, blank_id]
# Score for token changing from C-1 at T-1 to J at T.
changed = trellis[t-1, j-1] + emission[t-1, tokens[j-1]]
# 2. Store the path with frame-wise probability.
prob = emission[t-1, tokens[j-1] if changed > stayed else 0].exp().item()
# Return token index and time index in non-trellis coordinate.
path.append(Point(j-1, t-1, prob))
# 3. Update the token
if changed > stayed:
j -= 1
if j == 0:
break
else:
raise ValueError('Failed to align')
return path[::-1]
path = backtrack(trellis, emission, tokens)
print(path)
Out:
[Point(token_index=0, time_index=30, score=0.9999842643737793), Point(token_index=0, time_index=31, score=0.9846950173377991), Point(token_index=0, time_index=32, score=0.9999707937240601), Point(token_index=0, time_index=33, score=0.1540004163980484), Point(token_index=1, time_index=34, score=0.9999173879623413), Point(token_index=1, time_index=35, score=0.6080269813537598), Point(token_index=2, time_index=36, score=0.9997720122337341), Point(token_index=2, time_index=37, score=0.9997130036354065), Point(token_index=3, time_index=38, score=0.9999357461929321), Point(token_index=3, time_index=39, score=0.9861581325531006), Point(token_index=4, time_index=40, score=0.9238582253456116), Point(token_index=4, time_index=41, score=0.9257349967956543), Point(token_index=4, time_index=42, score=0.015662744641304016), Point(token_index=5, time_index=43, score=0.9998378753662109), Point(token_index=6, time_index=44, score=0.9988442659378052), Point(token_index=6, time_index=45, score=0.10144233703613281), Point(token_index=7, time_index=46, score=0.9999426603317261), Point(token_index=7, time_index=47, score=0.9999946355819702), Point(token_index=8, time_index=48, score=0.9979603290557861), Point(token_index=8, time_index=49, score=0.036036331206560135), Point(token_index=8, time_index=50, score=0.06162545830011368), Point(token_index=9, time_index=51, score=4.3326534068910405e-05), Point(token_index=10, time_index=52, score=0.999980092048645), Point(token_index=10, time_index=53, score=0.9967095851898193), Point(token_index=10, time_index=54, score=0.9999257326126099), Point(token_index=11, time_index=55, score=0.9999982118606567), Point(token_index=11, time_index=56, score=0.9990689158439636), Point(token_index=11, time_index=57, score=0.9999996423721313), Point(token_index=11, time_index=58, score=0.9999996423721313), Point(token_index=11, time_index=59, score=0.8457557559013367), Point(token_index=12, time_index=60, score=0.9999995231628418), Point(token_index=12, time_index=61, score=0.999601423740387), Point(token_index=13, time_index=62, score=0.999998927116394), Point(token_index=13, time_index=63, score=0.0035246757324784994), Point(token_index=13, time_index=64, score=1.0), Point(token_index=13, time_index=65, score=1.0), Point(token_index=14, time_index=66, score=0.9999916553497314), Point(token_index=14, time_index=67, score=0.9971591234207153), Point(token_index=14, time_index=68, score=0.9999990463256836), Point(token_index=14, time_index=69, score=0.9999991655349731), Point(token_index=14, time_index=70, score=0.9999998807907104), Point(token_index=14, time_index=71, score=0.9999998807907104), Point(token_index=14, time_index=72, score=0.9999881982803345), Point(token_index=14, time_index=73, score=0.011426654644310474), Point(token_index=15, time_index=74, score=0.9999978542327881), Point(token_index=15, time_index=75, score=0.9996134042739868), Point(token_index=15, time_index=76, score=0.999998927116394), Point(token_index=15, time_index=77, score=0.9727553129196167), Point(token_index=16, time_index=78, score=0.999998927116394), Point(token_index=16, time_index=79, score=0.9949328303337097), Point(token_index=16, time_index=80, score=0.999998927116394), Point(token_index=16, time_index=81, score=0.9999121427536011), Point(token_index=17, time_index=82, score=0.9999775886535645), Point(token_index=17, time_index=83, score=0.6576985716819763), Point(token_index=17, time_index=84, score=0.9984292387962341), Point(token_index=18, time_index=85, score=0.9999874830245972), Point(token_index=18, time_index=86, score=0.9993745684623718), Point(token_index=18, time_index=87, score=0.9999988079071045), Point(token_index=18, time_index=88, score=0.10424679517745972), Point(token_index=19, time_index=89, score=0.9999969005584717), Point(token_index=19, time_index=90, score=0.3978584110736847), Point(token_index=20, time_index=91, score=0.9999933242797852), Point(token_index=20, time_index=92, score=1.6990968561003683e-06), Point(token_index=20, time_index=93, score=0.9861307740211487), Point(token_index=21, time_index=94, score=0.9999960660934448), Point(token_index=21, time_index=95, score=0.9992727637290955), Point(token_index=21, time_index=96, score=0.9993411898612976), Point(token_index=22, time_index=97, score=0.9999983310699463), Point(token_index=22, time_index=98, score=0.9999971389770508), Point(token_index=22, time_index=99, score=0.9999997615814209), Point(token_index=22, time_index=100, score=0.9999995231628418), Point(token_index=23, time_index=101, score=0.9999732971191406), Point(token_index=23, time_index=102, score=0.9983227849006653), Point(token_index=23, time_index=103, score=0.9999992847442627), Point(token_index=23, time_index=104, score=0.9999997615814209), Point(token_index=23, time_index=105, score=1.0), Point(token_index=23, time_index=106, score=1.0), Point(token_index=23, time_index=107, score=0.9998630285263062), Point(token_index=24, time_index=108, score=0.9999982118606567), Point(token_index=24, time_index=109, score=0.9988579750061035), Point(token_index=25, time_index=110, score=0.9999798536300659), Point(token_index=25, time_index=111, score=0.8572984933853149), Point(token_index=26, time_index=112, score=0.9999847412109375), Point(token_index=26, time_index=113, score=0.9870278835296631), Point(token_index=26, time_index=114, score=1.904349664982874e-05), Point(token_index=27, time_index=115, score=0.9999794960021973), Point(token_index=27, time_index=116, score=0.9998253583908081), Point(token_index=28, time_index=117, score=0.9999991655349731), Point(token_index=28, time_index=118, score=0.9999734163284302), Point(token_index=28, time_index=119, score=0.0009004566818475723), Point(token_index=29, time_index=120, score=0.9993478655815125), Point(token_index=29, time_index=121, score=0.9975456595420837), Point(token_index=29, time_index=122, score=0.00030501981382258236), Point(token_index=30, time_index=123, score=0.9999344348907471), Point(token_index=30, time_index=124, score=6.0791257965320256e-06), Point(token_index=31, time_index=125, score=0.9833147525787354), Point(token_index=32, time_index=126, score=0.9974580407142639), Point(token_index=32, time_index=127, score=0.0008236187277361751), Point(token_index=33, time_index=128, score=0.9965153932571411), Point(token_index=33, time_index=129, score=0.0174646507948637), Point(token_index=34, time_index=130, score=0.9989169836044312), Point(token_index=35, time_index=131, score=0.9999698400497437), Point(token_index=35, time_index=132, score=0.9999842643737793), Point(token_index=36, time_index=133, score=0.9997640252113342), Point(token_index=36, time_index=134, score=0.5096558928489685), Point(token_index=37, time_index=135, score=0.9998302459716797), Point(token_index=37, time_index=136, score=0.08524401485919952), Point(token_index=37, time_index=137, score=0.0040728189051151276), Point(token_index=38, time_index=138, score=0.9999814033508301), Point(token_index=38, time_index=139, score=0.012057782150804996), Point(token_index=38, time_index=140, score=0.9999979734420776), Point(token_index=38, time_index=141, score=0.0005778099875897169), Point(token_index=39, time_index=142, score=0.9999068975448608), Point(token_index=39, time_index=143, score=0.9999960660934448), Point(token_index=39, time_index=144, score=0.9999980926513672), Point(token_index=40, time_index=145, score=0.9999915361404419), Point(token_index=40, time_index=146, score=0.9971170425415039), Point(token_index=40, time_index=147, score=0.9981803894042969), Point(token_index=41, time_index=148, score=0.9999310970306396), Point(token_index=41, time_index=149, score=0.9879505634307861), Point(token_index=41, time_index=150, score=0.9997628331184387), Point(token_index=42, time_index=151, score=0.9999535083770752), Point(token_index=43, time_index=152, score=0.9999716281890869), Point(token_index=44, time_index=153, score=0.6811745762825012)]
Visualization
def plot_trellis_with_path(trellis, path):
# To plot trellis with path, we take advantage of 'nan' value
trellis_with_path = trellis.clone()
for i, p in enumerate(path):
trellis_with_path[p.time_index, p.token_index] = float('nan')
plt.imshow(trellis_with_path[1:, 1:].T, origin='lower')
plt.title("The path found by backtracking")
plt.show()
Looking good. Now this path contains repetations for the same labels, so let’s merge them to make it close to the original transcript.
When merging the multiple path points, we simply take the average probability for the merged segments.
# Merge the labels
@dataclass
class Segment:
label: str
start: int
end: int
score: float
def __repr__(self):
return f"{self.label}\t({self.score:4.2f}): [{self.start:5d}, {self.end:5d})"
@property
def length(self):
return self.end - self.start
def merge_repeats(path):
i1, i2 = 0, 0
segments = []
while i1 < len(path):
while i2 < len(path) and path[i1].token_index == path[i2].token_index:
i2 += 1
score = sum(path[k].score for k in range(i1, i2)) / (i2 - i1)
segments.append(Segment(transcript[path[i1].token_index], path[i1].time_index, path[i2-1].time_index + 1, score))
i1 = i2
return segments
segments = merge_repeats(path)
for seg in segments:
print(seg)
Out:
I (0.78): [ 30, 34)
| (0.80): [ 34, 36)
H (1.00): [ 36, 38)
A (0.99): [ 38, 40)
D (0.62): [ 40, 43)
| (1.00): [ 43, 44)
T (0.55): [ 44, 46)
H (1.00): [ 46, 48)
A (0.37): [ 48, 51)
T (0.00): [ 51, 52)
| (1.00): [ 52, 55)
C (0.97): [ 55, 60)
U (1.00): [ 60, 62)
R (0.75): [ 62, 66)
I (0.88): [ 66, 74)
O (0.99): [ 74, 78)
S (1.00): [ 78, 82)
I (0.89): [ 82, 85)
T (0.78): [ 85, 89)
Y (0.70): [ 89, 91)
| (0.66): [ 91, 94)
B (1.00): [ 94, 97)
E (1.00): [ 97, 101)
S (1.00): [ 101, 108)
I (1.00): [ 108, 110)
D (0.93): [ 110, 112)
E (0.66): [ 112, 115)
| (1.00): [ 115, 117)
M (0.67): [ 117, 120)
E (0.67): [ 120, 123)
| (0.50): [ 123, 125)
A (0.98): [ 125, 126)
T (0.50): [ 126, 128)
| (0.51): [ 128, 130)
T (1.00): [ 130, 131)
H (1.00): [ 131, 133)
I (0.75): [ 133, 135)
S (0.36): [ 135, 138)
| (0.50): [ 138, 142)
M (1.00): [ 142, 145)
O (1.00): [ 145, 148)
M (1.00): [ 148, 151)
E (1.00): [ 151, 152)
N (1.00): [ 152, 153)
T (0.68): [ 153, 154)
Visualization
def plot_trellis_with_segments(trellis, segments, transcript):
for i, seg in enumerate(segments):
if seg.label != '|':
trellis_with_path[seg.start+1:seg.end+1, i+1] = float('nan')
fig, [ax1, ax2] = plt.subplots(2, 1, figsize=(16, 9.5))
ax1.set_title("Path, label and probability for each label")
ax1.imshow(trellis_with_path.T, origin='lower')
ax1.set_xticks([])
ax1.annotate(seg.label, (seg.start + .7, i + 0.3), weight='bold')
ax1.annotate(f'{seg.score:.2f}', (seg.start - .3, i + 4.3))
ax2.set_title("Label probability with and without repetation")
xs, hs, ws = [], [], []
xs.append((seg.end + seg.start) / 2 + .4)
hs.append(seg.score)
ws.append(seg.end - seg.start)
ax2.annotate(seg.label, (seg.start + .8, -0.07), weight='bold')
ax2.bar(xs, hs, width=ws, color='gray', alpha=0.5, edgecolor='black')
xs, hs = [], []
for p in path:
label = transcript[p.token_index]
if label != '|':
xs.append(p.time_index + 1)
hs.append(p.score)
ax2.bar(xs, hs, width=0.5, alpha=0.5)
ax2.axhline(0, color='black')
ax2.set_xlim(ax1.get_xlim())
ax2.set_ylim(-0.1, 1.1)
plt.tight_layout()
plt.show()
Looks good. Now let’s merge the words. The Wav2Vec2 model uses '|'
as the word boundary, so we merge the segments before each occurance of
Then, finally, we segment the original audio into segmented audio and listen to them to see if the segmentation is correct.
# Merge words
def merge_words(segments, separator='|'):
words = []
i1, i2 = 0, 0
while i1 < len(segments):
if i2 >= len(segments) or segments[i2].label == separator:
if i1 != i2:
segs = segments[i1:i2]
word = ''.join([seg.label for seg in segs])
score = sum(seg.score * seg.length for seg in segs) / sum(seg.length for seg in segs)
words.append(Segment(word, segments[i1].start, segments[i2-1].end, score))
i1 = i2 + 1
i2 = i1
else:
i2 += 1
return words
word_segments = merge_words(segments)
for word in word_segments:
print(word)
Out:
I (0.78): [ 30, 34)
HAD (0.84): [ 36, 43)
THAT (0.52): [ 44, 52)
CURIOSITY (0.89): [ 55, 91)
BESIDE (0.94): [ 94, 115)
ME (0.67): [ 117, 123)
AT (0.66): [ 125, 128)
THIS (0.70): [ 130, 138)
MOMENT (0.97): [ 142, 154)
Visualization
def plot_alignments(trellis, segments, word_segments, waveform):
ax1.imshow(trellis_with_path[1:, 1:].T, origin='lower')
ax1.set_xticks([])
ax1.set_yticks([])
ax1.axvline(word.start - 0.5)
ax1.axvline(word.end - 0.5)
ax1.annotate(seg.label, (seg.start, i + 0.3))
ax1.annotate(f'{seg.score:.2f}', (seg.start , i + 4), fontsize=8)
# The original waveform
ratio = waveform.size(0) / (trellis.size(0) - 1)
ax2.plot(waveform)
x0 = ratio * word.start
x1 = ratio * word.end
ax2.axvspan(x0, x1, alpha=0.1, color='red')
ax2.annotate(f'{word.score:.2f}', (x0, 0.8))
ax2.annotate(seg.label, (seg.start * ratio, 0.9))
xticks = ax2.get_xticks()
plt.xticks(xticks, xticks / bundle.sample_rate)
ax2.set_xlabel('time [second]')
ax2.set_yticks([])
ax2.set_ylim(-1.0, 1.0)
ax2.set_xlim(0, waveform.size(-1))
plot_alignments(trellis, segments, word_segments, waveform[0],)
plt.show()
# A trick to embed the resulting audio to the generated file.
# `IPython.display.Audio` has to be the last call in a cell,
# and there should be only one call par cell.
def display_segment(i):
ratio = waveform.size(1) / (trellis.size(0) - 1)
word = word_segments[i]
x0 = int(ratio * word.start)
x1 = int(ratio * word.end)
filename = f"_assets/{i}_{word.label}.wav"
torchaudio.save(filename, waveform[:, x0:x1], bundle.sample_rate)
print(f"{word.label} ({word.score:.2f}): {x0 / bundle.sample_rate:.3f} - {x1 / bundle.sample_rate:.3f} sec")
return IPython.display.Audio(filename)
# Generate the audio for each segment
print(transcript)
IPython.display.Audio(SPEECH_FILE)
Out:
display_segment(0)
Out:
I (0.78): 0.604 - 0.684 sec
display_segment(1)
Out:
HAD (0.84): 0.724 - 0.865 sec
display_segment(2)
Out:
THAT (0.52): 0.885 - 1.046 sec
display_segment(3)
Out:
CURIOSITY (0.89): 1.107 - 1.831 sec
display_segment(4)
Out:
BESIDE (0.94): 1.891 - 2.314 sec
display_segment(5)
Out:
ME (0.67): 2.354 - 2.474 sec
display_segment(6)
Out:
AT (0.66): 2.515 - 2.575 sec
display_segment(7)
Out:
THIS (0.70): 2.615 - 2.776 sec
display_segment(8)
Out:
MOMENT (0.97): 2.857 - 3.098 sec
