目录
Audio Datasets
torchaudio provides easy access to common, publicly accessible datasets. Please refer to the official documentation for the list of available datasets.
# When running this tutorial in Google Colab, install the required packages
# with the following.
# !pip install torchaudio
import torch
import torchaudio
print(torch.__version__)
print(torchaudio.__version__)
Out:
1.10.0+cpu
0.10.0+cpu
Preparing data and utility functions (skip this section)
#@title Prepare data and utility functions. {display-mode: "form"}
#@markdown
#@markdown You do not need to look into this cell.
#@markdown Just execute once and you are good to go.
# Preparation of data and helper functions.
import multiprocessing
import os
from IPython.display import Audio, display
_SAMPLE_DIR = "_assets"
YESNO_DATASET_PATH = os.path.join(_SAMPLE_DIR, "yes_no")
os.makedirs(YESNO_DATASET_PATH, exist_ok=True)
def _download_yesno():
  if os.path.exists(os.path.join(YESNO_DATASET_PATH, "waves_yesno.tar.gz")):
    return
  torchaudio.datasets.YESNO(root=YESNO_DATASET_PATH, download=True)
YESNO_DOWNLOAD_PROCESS = multiprocessing.Process(target=_download_yesno)
YESNO_DOWNLOAD_PROCESS.start()
def plot_specgram(waveform, sample_rate, title="Spectrogram", xlim=None):
  waveform = waveform.numpy()
  num_channels, num_frames = waveform.shape
  time_axis = torch.arange(0, num_frames) / sample_rate
  figure, axes = plt.subplots(num_channels, 1)
  if num_channels == 1:
    axes = [axes]
  for c in range(num_channels):
    axes[c].specgram(waveform[c], Fs=sample_rate)
    if num_channels > 1:
      axes[c].set_ylabel(f'Channel {c+1}')
    if xlim:
      axes[c].set_xlim(xlim)
  figure.suptitle(title)
  plt.show(block=False)
def play_audio(waveform, sample_rate):
    display(Audio(waveform[0], rate=sample_rate))
  elif num_channels == 2:
    display(Audio((waveform[0], waveform[1]), rate=sample_rate))
  else:
    raise ValueError("Waveform with more than 2 channels are not supported.")
Here, we show how to use the YESNO dataset.
YESNO_DOWNLOAD_PROCESS.join()
dataset = torchaudio.datasets.YESNO(YESNO_DATASET_PATH, download=True)
for i in [1, 3, 5]:
  waveform, sample_rate, label = dataset[i]
  plot_specgram(waveform, sample_rate, title=f"Sample {i}: {label}")
  • Sample 1: [0, 0, 0, 1, 0, 0, 0, 1]
  • Sample 3: [0, 0, 1, 0, 0, 0, 1, 0]
  • Sample 5: [0, 0, 1, 0, 0, 1, 1, 1]
Out:
<IPython.lib.display.Audio object>
Total running time of the script: ( 0 minutes 3.559 seconds)
Gallery generated by Sphinx-Gallery
文档
访问 PyTorch 的全面开发人员文档
查看文档
教程
获取面向初学者和高级开发人员的深入教程
查看教程
资源
查找开发资源并解答您的问题
查看资源
APP信息
