目录
Hardware-Accelerated Video Decoding and Encoding
Author: Moto Hira
This tutorial shows how to use NVIDIA’s hardware video decoder (NVDEC) and encoder (NVENC) with TorchAudio.
Using hardware encoder/decoder improves the speed of loading and saving certain types of videos. Using them in TorchAduio requires additional FFmpeg configuration. This tutorial goes over how to compile FFmpeg, and compare the speed it takes to process video.
WARNING
This tutorial instsalls FFmpeg in system directory. If you run this tutorial on your system, please adjust the build configuration accordingly.
NOTE
This tutorial was authored in Google Colab, and is tailored to Google Colab’s specifications. Please check out this tutorial in Google Colab.
To use NVENC/NVDEC with TorchAudio, the following items are required.
  1. NVIDIA GPU with hardware video decoder/encoder.
  2. FFmpeg libraries compiled with NVDEC/NVENC support. †
  3. PyTorch / TorchAudio with CUDA support.
TorchAudio’s official binary distributions are compiled with FFmpeg 4 libraries, and they contain the logic required for hardware-based decoding/encoding.
In the following sections, we build FFmpeg 4 libraries with NVDEC/NVENC support, then we demonstrate the performance imrovement using TorchAudio’s StreamReader/StreamWriter.
† For details on NVDEC/NVENC and FFmpeg, please refer to the following articles.
Check the available GPU
[1]:
!nvidia-smi
Fri Oct  7 13:01:26 2022
| NVIDIA-SMI 460.32.03    Driver Version: 460.32.03    CUDA Version: 11.2     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  Tesla T4            Off  | 00000000:00:04.0 Off |                    0 |
| N/A   56C    P8    10W /  70W |      0MiB / 15109MiB |      0%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|  No running processes found                                                 |
Update PyTorch and TorchAudio with nightly builds
Until TorchAudio 0.13 is released, we need to use the nightly builds of PyTorch and TorchAudio.
[2]:
!pip uninstall -y -q torch torchaudio torchvision torchtext
!pip install --progress-bar off --pre torch torchaudio --extra-index-url https://download.pytorch.org/whl/nightly/cu116 2> /dev/null
Looking in indexes: https://pypi.org/simple, https://us-python.pkg.dev/colab-wheels/public/simple/, https://download.pytorch.org/whl/nightly/cu116
Collecting torch
  Downloading https://download.pytorch.org/whl/nightly/cu116/torch-1.14.0.dev20221007%2Bcu116-cp37-cp37m-linux_x86_64.whl (2286.1 MB)
Collecting torchaudio
  Downloading https://download.pytorch.org/whl/nightly/cu116/torchaudio-0.13.0.dev20221006%2Bcu116-cp37-cp37m-linux_x86_64.whl (4.2 MB)
Requirement already satisfied: typing-extensions in /usr/local/lib/python3.7/dist-packages (from torch) (4.1.1)
Collecting torch
  Downloading https://download.pytorch.org/whl/nightly/cu116/torch-1.13.0.dev20221006%2Bcu116-cp37-cp37m-linux_x86_64.whl (1983.0 MB)
Installing collected packages: torch, torchaudio
Successfully installed torch-1.13.0.dev20221006+cu116 torchaudio-0.13.0.dev20221006+cu116
Build FFmpeg libraries with Nvidia NVDEC/NVENC support
Install NVIDIA Video Codec Headers
To build FFmpeg with NVDEC/NVENC, we first install the headers that FFmpeg uses to interact with Video Codec SDK.
[3]:
!git clone https://git.videolan.org/git/ffmpeg/nv-codec-headers.git
# Note: Google Colab's GPU has NVENC API ver 11.0, so we checkout 11.0 tag.
!cd nv-codec-headers && git checkout n11.0.10.1 && sudo make install
Cloning into 'nv-codec-headers'...
remote: Enumerating objects: 819, done.
remote: Counting objects: 100% (819/819), done.
remote: Compressing objects: 100% (697/697), done.
remote: Total 819 (delta 439), reused 0 (delta 0)
Receiving objects: 100% (819/819), 156.42 KiB | 410.00 KiB/s, done.
Resolving deltas: 100% (439/439), done.
Note: checking out 'n11.0.10.1'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by performing another checkout.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -b with the checkout command again. Example:
  git checkout -b <new-branch-name>
HEAD is now at 315ad74 add cuMemcpy
sed 's#@@PREFIX@@#/usr/local#' ffnvcodec.pc.in > ffnvcodec.pc
install -m 0755 -d '/usr/local/include/ffnvcodec'
install -m 0644 include/ffnvcodec/*.h '/usr/local/include/ffnvcodec'
install -m 0755 -d '/usr/local/lib/pkgconfig'
install -m 0644 ffnvcodec.pc '/usr/local/lib/pkgconfig'
Download FFmpeg source code
Next we download the source code of FFmpeg 4. Any version later than 4.1 should work. We use 4.4.2 here.
[4]:
!wget -q https://github.com/FFmpeg/FFmpeg/archive/refs/tags/n4.4.2.tar.gz
!tar -xf n4.4.2.tar.gz
!mv FFmpeg-n4.4.2 ffmpeg
Install FFmpeg build and runtime dependencies
In the later test, we use H264 video codec and HTTPS protocol, so we install the libraries for them here.
[5]:
!apt -qq update
!apt -qq install -y yasm libx264-dev libgnutls28-dev
STRIP   install-libavutil-shared
... Omitted for brevity ...
Setting up libx264-dev:amd64 (2:0.152.2854+gite9a5903-2) ...
Setting up yasm (1.3.0-2build1) ...
Setting up libunbound2:amd64 (1.6.7-1ubuntu2.5) ...
Setting up libp11-kit-dev:amd64 (0.23.9-2ubuntu0.1) ...
Setting up libtasn1-6-dev:amd64 (4.13-2) ...
Setting up libtasn1-doc (4.13-2) ...
Setting up libgnutlsxx28:amd64 (3.5.18-1ubuntu1.6) ...
Setting up libgnutls-dane0:amd64 (3.5.18-1ubuntu1.6) ...
Setting up libgnutls-openssl27:amd64 (3.5.18-1ubuntu1.6) ...
Setting up libgmpxx4ldbl:amd64 (2:6.1.2+dfsg-2) ...
Setting up libidn2-dev:amd64 (2.0.4-1.1ubuntu0.2) ...
Setting up libidn2-0-dev (2.0.4-1.1ubuntu0.2) ...
Setting up libgmp-dev:amd64 (2:6.1.2+dfsg-2) ...
Setting up nettle-dev:amd64 (3.4.1-0ubuntu0.18.04.1) ...
Setting up libgnutls28-dev:amd64 (3.5.18-1ubuntu1.6) ...
Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
Processing triggers for libc-bin (2.27-3ubuntu1.6) ...
Configure FFmpeg build with Nvidia CUDA hardware support
Next we configure FFmpeg build. Note the following:
  1. We provide flags like -I/usr/local/cuda/include, -L/usr/local/cuda/lib64 to let the build process know where the CUDA libraries are found.
  2. We provide flags like --enable-nvdec and --enable-nvenc to enable NVDEC/NVENC. Please check out the Transcoding Guide† for the detail.
  3. We also provide NVCC flags with compute capability 37. This is because by default the configuration script verifies NVCC by compiling sample code targeting compute capability 30, which is too old for CUDA 11.
  4. Many features are disabled to reduce the compilation time.
  5. We install the library in /usr/lib/, which is one of the active search path of the dynamic loader. Doing so allows the resulting libraries to be found without requiring a restart of the current session. This might be an undesirable location, e.g. when one isn’t using a disposable VM.
† NVIDIA FFmpeg Transcoding Guide https://developer.nvidia.com/blog/nvidia-ffmpeg-transcoding-guide/
[6]:
# NOTE:
# When the configure script of FFmpeg 4 checks nvcc, it uses compute
# capability of 30 (3.0) by default. CUDA 11, however, does not support
# compute capability 30.
# Here, we use 37, which is supported by CUDA 11 and both K80 and T4.
# Tesla K80: 37
# NVIDIA T4: 75
%env ccap=37
# NOTE:
# We disable most of the features to speed up compilation
# The necessary components are
# - demuxer: mov, aac
# - decoder: h264, h264_nvdec
# - muxer: mp4
# - encoder: libx264, h264_nvenc
# - gnutls (HTTPS)
# Additionally, we use FFmpeg's virtual input device to generate
# test video data. This requires
# - input device: lavfi
# - filter: testsrc2
# - decoder: rawvideo
!cd ffmpeg && ./configure \
  --prefix='/usr/' \
  --extra-cflags='-I/usr/local/cuda/include' \
  --extra-ldflags='-L/usr/local/cuda/lib64' \
  --nvccflags="-gencode arch=compute_${ccap},code=sm_${ccap} -O2" \
  --disable-doc \
  --disable-static \
  --disable-bsfs \
  --disable-decoders \
  --disable-encoders \
  --disable-filters \
  --disable-demuxers \
  --disable-devices \
  --disable-muxers \
  --disable-parsers \
  --disable-postproc \
  --disable-protocols \
  --enable-decoder=aac \
  --enable-decoder=h264 \
  --enable-decoder=h264_cuvid \
  --enable-decoder=rawvideo \
  --enable-indev=lavfi \
  --enable-encoder=libx264 \
  --enable-encoder=h264_nvenc \
  --enable-demuxer=mov \
  --enable-muxer=mp4 \
  --enable-filter=scale \
  --enable-filter=testsrc2 \
  --enable-protocol=file \
  --enable-protocol=https \
  --enable-gnutls \
  --enable-shared \
  --enable-gpl \
  --enable-nonfree \
  --enable-cuda-nvcc \
  --enable-libx264 \
  --enable-nvenc \
  --enable-cuvid \
  --enable-nvdec
env: ccap=37
install prefix            /usr/
source path               .
C compiler                gcc
C library                 glibc
ARCH                      x86 (generic)
big-endian                no
runtime cpu detection     yes
standalone assembly       yes
x86 assembler             yasm
MMX enabled               yes
MMXEXT enabled            yes
3DNow! enabled            yes
3DNow! extended enabled   yes
SSE enabled               yes
SSSE3 enabled             yes
AESNI enabled             yes
AVX enabled               yes
AVX2 enabled              yes
AVX-512 enabled           yes
XOP enabled               yes
FMA3 enabled              yes
FMA4 enabled              yes
i686 features enabled     yes
CMOV is fast              yes
EBX available             yes
EBP available             yes
debug symbols             yes
strip symbols             yes
optimize for size         no
optimizations             yes
static                    no
shared                    yes
postprocessing support    no
network support           yes
threading support         pthreads
safe bitstream reader     yes
texi2html enabled         no
perl enabled              yes
pod2man enabled           yes
makeinfo enabled          no
makeinfo supports HTML    no
External libraries:
alsa                    libx264                 lzma
bzlib                   libxcb                  zlib
gnutls                  libxcb_shape
iconv                   libxcb_xfixes
External libraries providing hardware acceleration:
cuda                    cuvid                   nvenc
cuda_llvm               ffnvcodec               v4l2_m2m
cuda_nvcc               nvdec
Libraries:
avcodec                 avformat                swscale
avdevice                avutil
avfilter                swresample
Programs:
ffmpeg                  ffprobe
Enabled decoders:
aac                     hevc                    rawvideo
av1                     mjpeg                   vc1
h263                    mpeg1video              vp8
h264                    mpeg2video              vp9
h264_cuvid              mpeg4
Enabled encoders:
h264_nvenc              libx264
Enabled hwaccels:
av1_nvdec               mpeg1_nvdec             vp8_nvdec
h264_nvdec              mpeg2_nvdec             vp9_nvdec
hevc_nvdec              mpeg4_nvdec             wmv3_nvdec
mjpeg_nvdec             vc1_nvdec
Enabled parsers:
h263                    mpeg4video              vp9
Enabled demuxers:
mov
Enabled muxers:
mov                     mp4
Enabled protocols:
file                    tcp
https                   tls
Enabled filters:
aformat                 hflip                   transpose
anull                   null                    trim
atrim                   scale                   vflip
format                  testsrc2
Enabled bsfs:
aac_adtstoasc           null                    vp9_superframe_split
h264_mp4toannexb        vp9_superframe
Enabled indevs:
lavfi
Enabled outdevs:
License: nonfree and unredistributable
Build and install FFmpeg
[7]:
!cd ffmpeg && make clean && make -j > /dev/null 2>&1
!cd ffmpeg && make install
INSTALL libavdevice/libavdevice.so
INSTALL libavfilter/libavfilter.so
INSTALL libavformat/libavformat.so
INSTALL libavcodec/libavcodec.so
INSTALL libswresample/libswresample.so
INSTALL libswscale/libswscale.so
INSTALL libavutil/libavutil.so
INSTALL install-progs-yes
INSTALL ffmpeg
INSTALL ffprobe
Check FFmpeg installation
Let’s do a quick sanity check to confirm that the FFmpeg we built works.
[8]:
!ffprobe -hide_banner -decoders | grep h264
 VFS..D h264                 H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
 V..... h264_cuvid           Nvidia CUVID H264 decoder (codec h264)
[9]:
!ffmpeg -hide_banner -encoders | grep 264
 V..... libx264              libx264 H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 (codec h264)
 V....D h264_nvenc           NVIDIA NVENC H.264 encoder (codec h264)
The following command fetches video from remote server, decode with NVDEC (cuvid) and re-encode with NVENC. If this command does not work, then there is an issue with FFmpeg installation, and TorchAudio would not be able to use them either.
[10]:
!ffmpeg -hide_banner -y -vsync 0 -hwaccel cuvid -hwaccel_output_format cuda -c:v h264_cuvid -resize 360x240 -i "https://download.pytorch.org/torchaudio/tutorial-assets/stream-api/NASAs_Most_Scientifically_Complex_Space_Observatory_Requires_Precision-MP4_small.mp4" -c:a copy -c:v h264_nvenc -b:v 5M test.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'https://download.pytorch.org/torchaudio/tutorial-assets/stream-api/NASAs_Most_Scientifically_Complex_Space_Observatory_Requires_Precision-MP4_small.mp4':
  Metadata:
    major_brand     : mp42
    minor_version   : 512
    compatible_brands: mp42iso2avc1mp41
    encoder         : Lavf58.76.100
  Duration: 00:03:26.04, start: 0.000000, bitrate: 1294 kb/s
  Stream #0:0(eng): Video: h264 (High) (avc1 / 0x31637661), yuv420p(tv, bt709), 960x540 [SAR 1:1 DAR 16:9], 1156 kb/s, 29.97 fps, 29.97 tbr, 30k tbn, 59.94 tbc (default)
    Metadata:
      handler_name    : ?Mainconcept Video Media Handler
      vendor_id       : [0][0][0][0]
  Stream #0:1(eng): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 128 kb/s (default)
    Metadata:
      handler_name    : #Mainconcept MP4 Sound Media Handler
Stream mapping:
  Stream #0:0 -> #0:0 (h264 (h264_cuvid) -> h264 (h264_nvenc))
  Stream #0:1 -> #0:1 (copy)
Press [q] to stop, [?] for help
Output #0, mp4, to 'test.mp4':
  Metadata:
    major_brand     : mp42
    minor_version   : 512
  Stream #0:0(eng): Video: h264 (Main) (avc1 / 0x31637661), cuda(tv, bt709, progressive), 360x240 [SAR 1:1 DAR 3:2], q=2-31, 5000 kb/s, 29.97 fps, 30k tbn (default)
    Metadata:
      encoder         : Lavc58.134.100 h264_nvenc
    Side data:
      cpb: bitrate max/min/avg: 0/0/5000000 buffer size: 10000000 vbv_delay: N/A
    Metadata:
frame= 6175 fps=1712 q=11.0 Lsize=   37935kB time=00:03:26.01 bitrate=1508.5kbits/s speed=57.1x
video:34502kB audio:3234kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.526932%
Benchmarking GPU Encoding and Decoding
Now that FFmpeg and the resulting libraries are ready to use, we test NVDEC/NVENC with TorchAudio. For the basics of TorchAudio’s streaming APIs, please refer to Media I/O tutorials.
Note
If you rebuild FFmpeg after importing torchaudio, you’ll need to restart the session to activate the newly built FFmpeg libraries.
[11]:
import torch
import torchaudio
print(torch.__version__)
print(torchaudio.__version__)
from torchaudio.io import StreamReader, StreamWriter
[12]:
import time
import pandas as pd
pd.set_option('display.max_rows', None)
pd.set_option('display.max_columns', None)
Benchmark NVDEC with StreamReader
First we test hardware decoding, and we fetch video from multiple locations (local file, network file, AWS S3) and use NVDEC to decod them.
[13]:
!pip3 install --progress-bar off boto3 2> /dev/null
Collecting boto3
  Downloading boto3-1.24.88-py3-none-any.whl (132 kB)
Collecting s3transfer<0.7.0,>=0.6.0
  Downloading s3transfer-0.6.0-py3-none-any.whl (79 kB)
Collecting jmespath<2.0.0,>=0.7.1
  Downloading jmespath-1.0.1-py3-none-any.whl (20 kB)
Collecting botocore<1.28.0,>=1.27.88
  Downloading botocore-1.27.88-py3-none-any.whl (9.2 MB)
Collecting urllib3<1.27,>=1.25.4
  Downloading urllib3-1.26.12-py2.py3-none-any.whl (140 kB)
Requirement already satisfied: python-dateutil<3.0.0,>=2.1 in /usr/local/lib/python3.7/dist-packages (from botocore<1.28.0,>=1.27.88->boto3) (2.8.2)
Requirement already satisfied: six>=1.5 in /usr/local/lib/python3.7/dist-packages (from python-dateutil<3.0.0,>=2.1->botocore<1.28.0,>=1.27.88->boto3) (1.15.0)
Installing collected packages: urllib3, jmespath, botocore, s3transfer, boto3
  Attempting uninstall: urllib3
    Found existing installation: urllib3 1.24.3
    Uninstalling urllib3-1.24.3:
      Successfully uninstalled urllib3-1.24.3
Successfully installed boto3-1.24.88 botocore-1.27.88 jmespath-1.0.1 s3transfer-0.6.0 urllib3-1.26.12
[14]:
import boto3
from botocore import UNSIGNED
from botocore.config import Config
print(boto3.__version__)
1.24.88
[15]:
!wget -q -O input.mp4 "https://download.pytorch.org/torchaudio/tutorial-assets/stream-api/NASAs_Most_Scientifically_Complex_Space_Observatory_Requires_Precision-MP4_small.mp4"
First, we define the functions we’ll use for testing.
Funcion test_decode decodes the given source from start to end, and it reports the elapsed time, and returns one image frmae as a sample.
[16]:
result = torch.zeros((4, 2))
samples = [[None, None] for _ in range(4)]
def test_decode(src, config, i_sample):
  print("=" * 40)
  print("* Configuration:", config)
  print("* Source:", src)
  print("=" * 40)
  s = StreamReader(src)
  s.add_video_stream(5, **config)
  t0 = time.monotonic()
  num_frames = 0
  for i, (chunk, ) in enumerate(s.stream()):
    if i == 0:
      print(' - Chunk:', chunk.shape, chunk.device, chunk.dtype)
    if i == i_sample:
      sample = chunk[0]
    num_frames += chunk.shape[0]
  elapsed = time.monotonic() - t0
  print()
  print(f" - Processed {num_frames} frames.")
  print(f" - Elapsed: {elapsed} seconds.")
  print()
  return elapsed, sample
Decode MP4 from local file
For the first test, we compare the time it takes for CPU and NVDEC to decode 250MB of MP4 video.
[17]:
local_src = "input.mp4"
i_sample = 520
CPU
[18]:
cpu_conf = {
    "decoder": "h264",  # CPU decoding
elapsed, sample = test_decode(local_src, cpu_conf, i_sample)
* Configuration: {'decoder': 'h264'}
* Source: input.mp4
 - Chunk: torch.Size([5, 3, 540, 960]) cpu torch.uint8
 - Processed 6175 frames.
 - Elapsed: 46.691246449000005 seconds.
[19]:
result[0, 0] = elapsed
samples[0][0] = sample
CUDA
[20]:
cuda_conf = {
    "decoder": "h264_cuvid",  # Use CUDA HW decoder
    "hw_accel": "cuda:0",  # Then keep the memory on CUDA:0
elapsed, sample = test_decode(local_src, cuda_conf, i_sample)
* Configuration: {'decoder': 'h264_cuvid', 'hw_accel': 'cuda:0'}
* Source: input.mp4
 - Chunk: torch.Size([5, 3, 540, 960]) cuda:0 torch.uint8
 - Elapsed: 6.117441406000012 seconds.
[21]:
result[0, 1] = elapsed
samples[0][1] = sample
Decode MP4 from network
Let’s run the same test on the source retrieved via network on-the-fly.
[22]:
network_src = "https://download.pytorch.org/torchaudio/tutorial-assets/stream-api/NASAs_Most_Scientifically_Complex_Space_Observatory_Requires_Precision-MP4_small.mp4"
i_sample = 750
CPU
[23]:
elapsed, sample = test_decode(network_src, cpu_conf, i_sample)
* Source: https://download.pytorch.org/torchaudio/tutorial-assets/stream-api/NASAs_Most_Scientifically_Complex_Space_Observatory_Requires_Precision-MP4_small.mp4
 - Elapsed: 46.460909987000036 seconds.
[24]:
result[1, 0] = elapsed
samples[1][0] = sample
CUDA
[25]:
elapsed, sample = test_decode(network_src, cuda_conf, i_sample)
 - Elapsed: 4.23164078800005 seconds.
[26]:
result[1, 1] = elapsed
samples[1][1] = sample
Decode MP4 directly from S3
Using file-like object input, we can fetch a video stored on AWS S3 and decode it without saving it on local file system.
[27]:
bucket = "pytorch"
key = "torchaudio/tutorial-assets/stream-api/NASAs_Most_Scientifically_Complex_Space_Observatory_Requires_Precision-MP4_small.mp4"
s3_client = boto3.client("s3", config=Config(signature_version=UNSIGNED))
i_sample = 115
Defining Helper class
StreamReader supports file-like objects with read method. In addition to this, if the file-like object has seek method, StreamReader attempts to use it for more reliable detection of media formats.
However, the seek method of boto3’s S3 client response object only raises errors to let users know that seek operation is not supported. Therefore we wrap it with a class that does not have seek method. This way, StreamReader won’t try to use the seek method.
Note
Due to the nature of streaming, when using file-like object without seek method, some formats are not supported. For example, MP4 formats contain metadata at the beginning of file or at the end. If metadata is located at the end, without seek method, StreamReader cannot decode streams.
[28]:
# Wrapper to hide the native `seek` method of boto3, which
# only raises an error.
class UnseekableWrapper:
  def __init__(self, obj):
    self.obj = obj
  def read(self, n):
    return self.obj.read(n)
  def __str__(self):
    return str(self.obj)
CPU
[29]:
response = s3_client.get_object(Bucket=bucket, Key=key)
src = UnseekableWrapper(response["Body"])
elapsed, sample = test_decode(src, cpu_conf, i_sample)
* Source: <botocore.response.StreamingBody object at 0x7fb991dddfd0>
 - Elapsed: 40.758733775999985 seconds.
[30]:
result[2, 0] = elapsed
samples[2][0] = sample
CUDA
[31]:
elapsed, sample = test_decode(src, cuda_conf, i_sample)
* Source: <botocore.response.StreamingBody object at 0x7fb991d390d0>
 - Elapsed: 4.620101478000038 seconds.
[32]:
result[2, 1] = elapsed
samples[2][1] = sample
Decoding and resizing
In the next test, we add preprocessing. NVDEC supports several preprocessing schemes, which are also performed on the chosen hardware. For CPU, we apply the same kind of software preprocessing through FFmpeg’s filter graph.
[33]:
i_sample = 1085
CPU
[34]:
cpu_conf = {
    "filter_desc": "scale=360:240",  # Software filter
* Configuration: {'decoder': 'h264', 'filter_desc': 'scale=360:240'}
* Source: input.mp4
 - Chunk: torch.Size([5, 3, 240, 360]) cpu torch.uint8
 - Elapsed: 19.082725973000038 seconds.
[35]:
result[3, 0] = elapsed
samples[3][0] = sample
CUDA
[36]:
cuda_conf = {
    "decoder_option": {
        "resize": "360x240",  # Then apply HW preprocessing (resize)
* Configuration: {'decoder': 'h264_cuvid', 'decoder_option': {'resize': '360x240'}, 'hw_accel': 'cuda:0'}
* Source: input.mp4
 - Chunk: torch.Size([5, 3, 240, 360]) cuda:0 torch.uint8
 - Elapsed: 4.157032522999998 seconds.
[37]:
result[3, 1] = elapsed
samples[3][1] = sample
Results
The following table summarizes the time it took to decode the same media with CPU and NVDEC. We see significant speedup with NVDEC.
[38]:
res = pd.DataFrame(
    result.numpy(),
    index=["Decoding (local file)", "Decoding (network file)", "Decoding (file-like object, S3)", "Decoding + Resize"],
    columns=["CPU", "NVDEC"],
print(res)
                                       CPU     NVDEC
Decoding (local file)            46.691246  6.117441
Decoding (network file)          46.460911  4.231641
Decoding (file-like object, S3)  40.758736  4.620101
Decoding + Resize                19.082726  4.157032
The following code shows some frames generated by CPU decoding and NVDEC. They produce seemingly identical results.
[39]:
def yuv_to_rgb(img):
  img = img.cpu().to(torch.float)
  y = img[..., 0, :, :]
  u = img[..., 1, :, :]
  v = img[..., 2, :, :]
  y /= 255
  u = u / 255 - 0.5
  v = v / 255 - 0.5
  r = y + 1.14 * v
  g = y + -0.396 * u - 0.581 * v
  b = y + 2.029 * u
  rgb = torch.stack([r, g, b], -1)
  rgb = (rgb * 255).clamp(0, 255).to(torch.uint8)
  return rgb.numpy()
[40]:
f, axs = plt.subplots(4, 2, figsize=[12.8, 19.2])
for i in range(4):
  for j in range(2):
    axs[i][j].imshow(yuv_to_rgb(samples[i][j]))
    axs[i][j].set_title(
        f"{'CPU' if j == 0 else 'NVDEC'}{' with resize' if i == 3 else ''}")
plt.plot(block=False)
[40]:
_images/hw_acceleration_tutorial_68_1.png
Benchmark NVENC with StreamWriter
Next, we benchmark encoding speed with StreamWriter and NVENC.
[41]:
def test_encode(data, dst, **config):
  print("=" * 40)
  print("* Destination:", dst)
  print("=" * 40)
  s = StreamWriter(dst)
  s.add_video_stream(**config)
  with s.open():
    s.write_video_chunk(0, data)
  print()
  print(f" - Processed {len(data)} frames.")
  print()
  return elapsed
result = torch.zeros((3, 3))
We use StreamReader to generate test data.
[42]:
def get_data(frame_rate, height, width, format, duration=15):
  src = f"testsrc2=rate={frame_rate}:size={width}x{height}:duration={duration}"
  s = StreamReader(src=src, format="lavfi")
  s.add_basic_video_stream(-1, format=format)
  s.process_all_packets()
  video, = s.pop_chunks()
  return video
Encode MP4 - 360P
For the first test, we compare the time it takes for CPU and NVENC to encode 15 seconds of video with small resolution.
[43]:
pict_config = {
    "height": 360,
    "width": 640,
    "frame_rate": 30000/1001,
    "format": "yuv444p",
video = get_data(**pict_config)
CPU
[44]:
encode_config = {
    "encoder": "libx264",
    "encoder_format": "yuv444p",
result[0, 0] = test_encode(video, "360p_cpu.mp4", **pict_config, **encode_config)
* Configuration: {'height': 360, 'width': 640, 'frame_rate': 29.97002997002997, 'format': 'yuv444p', 'encoder': 'libx264', 'encoder_format': 'yuv444p'}
* Destination: 360p_cpu.mp4
 - Processed 450 frames.
 - Elapsed: 3.280829835000077 seconds.
CUDA (from CPU Tensor)
Now we test NVENC. This time, the data is sent from CPU memory to GPU memory as part of encoding.
[45]:
encode_config = {
    "encoder": "h264_nvenc",  # Use NVENC
    "encoder_option": {"gpu": "0"},  # Run encoding on the cuda:0 device
result[1, 0] = test_encode(video, "360p_cuda.mp4", **pict_config, **encode_config)
* Configuration: {'height': 360, 'width': 640, 'frame_rate': 29.97002997002997, 'format': 'yuv444p', 'encoder': 'h264_nvenc', 'encoder_format': 'yuv444p', 'encoder_option': {'gpu': '0'}}
* Destination: 360p_cuda.mp4
 - Elapsed: 0.34294435300000714 seconds.
CUDA (from CUDA Tensor)
If the data is already present on CUDA, then we can pass it to GPU encoder directly.
[46]:
device = "cuda:0"
encode_config = {
    "encoder": "h264_nvenc",  # GPU Encoder
    "hw_accel": device,  # Data comes from cuda:0 device
result[2, 0] = test_encode(video.to(torch.device(device)), "360p_cuda_hw.mp4", **pict_config, **encode_config)
* Configuration: {'height': 360, 'width': 640, 'frame_rate': 29.97002997002997, 'format': 'yuv444p', 'encoder': 'h264_nvenc', 'encoder_format': 'yuv444p', 'encoder_option': {'gpu': '0'}, 'hw_accel': 'cuda:0'}
* Destination: 360p_cuda_hw.mp4
 - Elapsed: 0.2424524550000342 seconds.
Encode MP4 - 720P
Let’s run the same tests on video with larger resolution.
[47]:
pict_config = {
    "height": 720,
    "width": 1280,
CPU
[48]:
encode_config = {
result[0, 1] = test_encode(video, "720p_cpu.mp4", **pict_config, **encode_config)
* Configuration: {'height': 720, 'width': 1280, 'frame_rate': 29.97002997002997, 'format': 'yuv444p', 'encoder': 'libx264', 'encoder_format': 'yuv444p'}
* Destination: 720p_cpu.mp4
 - Elapsed: 11.638768525999922 seconds.
[49]:
encode_config = {
result[1, 1] = test_encode(video, "720p_cuda.mp4", **pict_config, **encode_config)
* Configuration: {'height': 720, 'width': 1280, 'frame_rate': 29.97002997002997, 'format': 'yuv444p', 'encoder': 'h264_nvenc', 'encoder_format': 'yuv444p'}
* Destination: 720p_cuda.mp4
 - Elapsed: 0.8508033889999069 seconds.
[50]:
device = "cuda:0"
encode_config = {
    "hw_accel": device,
result[2, 1] = test_encode(video.to(torch.device(device)), "720p_cuda_hw.mp4", **pict_config, **encode_config)
* Configuration: {'height': 720, 'width': 1280, 'frame_rate': 29.97002997002997, 'format': 'yuv444p', 'encoder': 'h264_nvenc', 'encoder_format': 'yuv444p', 'encoder_option': {'gpu': '0'}, 'hw_accel': 'cuda:0'}
* Destination: 720p_cuda_hw.mp4
 - Elapsed: 0.6384492569999338 seconds.
Encode MP4 - 1080P
We make the video with even larger.
[51]:
pict_config = {
    "height": 1080,
    "width": 1920,
CPU
[52]:
encode_config = {
result[0, 2] = test_encode(video, "1080p_cpu.mp4", **pict_config, **encode_config)
* Configuration: {'height': 1080, 'width': 1920, 'frame_rate': 29.97002997002997, 'format': 'yuv444p', 'encoder': 'libx264', 'encoder_format': 'yuv444p'}
* Destination: 1080p_cpu.mp4
 - Elapsed: 27.020421489 seconds.
[53]:
encode_config = {
result[1, 2] = test_encode(video, "1080p_cuda.mp4", **pict_config, **encode_config)
* Configuration: {'height': 1080, 'width': 1920, 'frame_rate': 29.97002997002997, 'format': 'yuv444p', 'encoder': 'h264_nvenc', 'encoder_format': 'yuv444p'}
* Destination: 1080p_cuda.mp4
 - Elapsed: 1.60377999800005 seconds.
[54]:
device = "cuda:0"
encode_config = {
    "hw_accel": device,
result[2, 2] = test_encode(video.to(torch.device(device)), "1080p_cuda_hw.mp4", **pict_config, **encode_config)
* Configuration: {'height': 1080, 'width': 1920, 'frame_rate': 29.97002997002997, 'format': 'yuv444p', 'encoder': 'h264_nvenc', 'encoder_format': 'yuv444p', 'encoder_option': {'gpu': '0'}, 'hw_accel': 'cuda:0'}
* Destination: 1080p_cuda_hw.mp4
 - Elapsed: 1.4101193979998925 seconds.
Result
Here is the result.
[55]:
labels = ["CPU", "CUDA (from CPU Tensor)", "CUDA (from CUDA Tensor)"]
columns = ["360P", "720P", "1080P"]
res = pd.DataFrame(
    result.numpy(),
    index=labels,
    columns=columns,
print(res)
                             360P       720P      1080P
CPU                      3.280830  11.638768  27.020422
CUDA (from CPU Tensor)   0.342944   0.850803   1.603780
CUDA (from CUDA Tensor)  0.242452   0.638449   1.410119
[56]:
plt.plot(result.T)
plt.legend(labels)
plt.xticks([i for i in range(3)], columns)
plt.grid(visible=True, axis='y')
_images/hw_acceleration_tutorial_99_0.png
The resulting videos look like the following.
[61]:
from IPython.display import HTML
HTML('''
<div>
  <video width=360 controls autoplay>
    <source src="https://download.pytorch.org/torchaudio/tutorial-assets/streamwriter_360p_cpu.mp4" type="video/mp4">
  </video>
    <source src="https://download.pytorch.org/torchaudio/tutorial-assets/streamwriter_360p_cuda.mp4" type="video/mp4">
  </video>
    <source src="https://download.pytorch.org/torchaudio/tutorial-assets/streamwriter_360p_cuda_hw.mp4" type="video/mp4">
  </video>
</div>
[61]:
Conclusion
We looked at how to build FFmpeg libraries with NVDEC/NVENC support and use them from TorchAudio. NVDEC/NVENC provide significant speed up when saving/loading a video.
文档
访问 PyTorch 的全面开发人员文档
查看文档
教程
获取面向初学者和高级开发人员的深入教程
查看教程
资源
查找开发资源并解答您的问题
查看资源
