目录
Audio Feature Augmentation
Author: Moto Hira
# When running this tutorial in Google Colab, install the required packages
# with the following.
# !pip install torchaudio librosa
import torch
import torchaudio
import torchaudio.transforms as T
print(torch.__version__)
print(torchaudio.__version__)
1.13.1
0.13.1
Preparing data and utility functions (skip this section)
# @title Prepare data and utility functions. {display-mode: "form"}
# @markdown
# @markdown You do not need to look into this cell.
# @markdown Just execute once and you are good to go.
# @markdown
# @markdown In this tutorial, we will use a speech data from [VOiCES dataset](https://iqtlabs.github.io/voices/),
# @markdown which is licensed under Creative Commos BY 4.0.
# Preparation of data and helper functions.
import librosa
from torchaudio.utils import download_asset
SAMPLE_WAV_SPEECH_PATH = download_asset("tutorial-assets/Lab41-SRI-VOiCES-src-sp0307-ch127535-sg0042.wav")
def _get_sample(path, resample=None):
    effects = [["remix", "1"]]
    if resample:
        effects.extend(
                ["lowpass", f"{resample // 2}"],
                ["rate", f"{resample}"],
    return torchaudio.sox_effects.apply_effects_file(path, effects=effects)
def get_speech_sample(*, resample=None):
    return _get_sample(SAMPLE_WAV_SPEECH_PATH, resample=resample)
def get_spectrogram(
    n_fft=400,
    win_len=None,
    hop_len=None,
    power=2.0,
    waveform, _ = get_speech_sample()
    spectrogram = T.Spectrogram(
        n_fft=n_fft,
        win_length=win_len,
        hop_length=hop_len,
        center=True,
        pad_mode="reflect",
        power=power,
    return spectrogram(waveform)
def plot_spectrogram(spec, title=None, ylabel="freq_bin", aspect="auto", xmax=None):
    fig, axs = plt.subplots(1, 1)
    axs.set_title(title or "Spectrogram (db)")
    axs.set_ylabel(ylabel)
    axs.set_xlabel("frame")
    im = axs.imshow(librosa.power_to_db(spec), origin="lower", aspect=aspect)
    if xmax:
        axs.set_xlim((0, xmax))
    fig.colorbar(im, ax=axs)
    plt.show(block=False)
SpecAugment
SpecAugment is a popular spectrogram augmentation technique.
torchaudio implements torchaudio.transforms.TimeStretch(), torchaudio.transforms.TimeMasking() and torchaudio.transforms.FrequencyMasking().
TimeStretch
spec = get_spectrogram(power=None)
stretch = T.TimeStretch()
rate = 1.2
spec_ = stretch(spec, rate)
plot_spectrogram(torch.abs(spec_[0]), title=f"Stretched x{rate}", aspect="equal", xmax=304)
plot_spectrogram(torch.abs(spec[0]), title="Original", aspect="equal", xmax=304)
rate = 0.9
  • Stretched x1.2
  • Original
  • Stretched x0.9
TimeMasking
torch.random.manual_seed(4)
spec = get_spectrogram()
plot_spectrogram(spec[0], title="Original")
masking = T.TimeMasking(time_mask_param=80)
spec = masking(spec)
plot_spectrogram(spec[0], title="Masked along time axis")
  • Original
  • Masked along time axis
FrequencyMasking
masking = T.FrequencyMasking(freq_mask_param=80)
plot_spectrogram(spec[0], title="Masked along frequency axis")
  • Original
  • Masked along frequency axis
Total running time of the script: ( 0 minutes 2.027 seconds)
Gallery generated by Sphinx-Gallery
文档
访问 PyTorch 的全面开发人员文档
查看文档
教程
获取面向初学者和高级开发人员的深入教程
查看教程
资源
查找开发资源并解答您的问题
查看资源
