Note
Click here to download the full example code
Audio Data Augmentation
Author: Moto Hira
torchaudio
provides a variety of ways to augment audio data.
In this tutorial, we look into a way to apply effects, filters, RIR (room impulse response) and codecs.
At the end, we synthesize noisy speech over phone from clean speech.
import torch
import torchaudio
import torchaudio.functional as F
print(torch.__version__)
print(torchaudio.__version__)
1.13.1
0.13.1
Preparation
First, we import the modules and download the audio assets we use in this tutorial.
import math
from IPython.display import Audio
from torchaudio.utils import download_asset
SAMPLE_WAV = download_asset("tutorial-assets/steam-train-whistle-daniel_simon.wav")
SAMPLE_RIR = download_asset("tutorial-assets/Lab41-SRI-VOiCES-rm1-impulse-mc01-stu-clo-8000hz.wav")
SAMPLE_SPEECH = download_asset("tutorial-assets/Lab41-SRI-VOiCES-src-sp0307-ch127535-sg0042-8000hz.wav")
SAMPLE_NOISE = download_asset("tutorial-assets/Lab41-SRI-VOiCES-rm1-babb-mc01-stu-clo-8000hz.wav")
0%| | 0.00/427k [00:00<?, ?B/s]
100%|##########| 427k/427k [00:00<00:00, 37.9MB/s]
0%| | 0.00/31.3k [00:00<?, ?B/s]
100%|##########| 31.3k/31.3k [00:00<00:00, 12.3MB/s]
0%| | 0.00/78.2k [00:00<?, ?B/s]
100%|##########| 78.2k/78.2k [00:00<00:00, 18.4MB/s]
Applying effects and filtering
torchaudio.sox_effects()
allows for directly applying filters similar to
those available in sox
to Tensor objects and file object audio sources.
There are two functions for this:
torchaudio.sox_effects.apply_effects_tensor()
for applying effects to Tensor.torchaudio.sox_effects.apply_effects_file()
for applying effects to other audio sources.
Both functions accept effect definitions in the form
List[List[str]]
This is mostly consistent with how sox
command works, but one caveat is
that sox
adds some effects automatically, whereas torchaudio
’s
implementation does not.
For the list of available effects, please refer to the sox documentation.
Tip If you need to load and resample your audio data on the fly,
then you can use torchaudio.sox_effects.apply_effects_file()
with effect "rate"
Note torchaudio.sox_effects.apply_effects_file()
accepts a
file-like object or path-like object.
Similar to torchaudio.load()
, when the audio format cannot be
inferred from either the file extension or header, you can provide
argument format
to specify the format of the audio source.
Note This process is not differentiable.
# Load the data
waveform1, sample_rate1 = torchaudio.load(SAMPLE_WAV)
# Define effects
effects = [
["lowpass", "-1", "300"], # apply single-pole lowpass filter
["speed", "0.8"], # reduce the speed
# This only changes sample rate, so it is necessary to
# add `rate` effect with original sample rate after this.
["rate", f"{sample_rate1}"],
["reverb", "-w"], # Reverbration gives some dramatic feeling
# Apply effects
waveform2, sample_rate2 = torchaudio.sox_effects.apply_effects_tensor(waveform1, sample_rate1, effects)
print(waveform1.shape, sample_rate1)
print(waveform2.shape, sample_rate2)
torch.Size([2, 109368]) 44100
torch.Size([2, 136710]) 44100
Note that the number of frames and number of channels are different from those of the original after the effects are applied. Let’s listen to the audio.
def plot_waveform(waveform, sample_rate, title="Waveform", xlim=None):
waveform = waveform.numpy()
num_channels, num_frames = waveform.shape
time_axis = torch.arange(0, num_frames) / sample_rate
figure, axes = plt.subplots(num_channels, 1)
if num_channels == 1:
axes = [axes]
for c in range(num_channels):
axes[c].plot(time_axis, waveform[c], linewidth=1)
axes[c].grid(True)
if num_channels > 1:
axes[c].set_ylabel(f"Channel {c+1}")
if xlim:
axes[c].set_xlim(xlim)
figure.suptitle(title)
plt.show(block=False)
def plot_specgram(waveform, sample_rate, title="Spectrogram", xlim=None):
num_channels, _ = waveform.shape
axes = [axes]
axes[c].specgram(waveform[c], Fs=sample_rate)
if xlim:
Original:
plot_waveform(waveform1, sample_rate1, title="Original", xlim=(-0.1, 3.2))
plot_specgram(waveform1, sample_rate1, title="Original", xlim=(0, 3.04))
Audio(waveform1, rate=sample_rate1)
Effects applied:
plot_waveform(waveform2, sample_rate2, title="Effects Applied", xlim=(-0.1, 3.2))
plot_specgram(waveform2, sample_rate2, title="Effects Applied", xlim=(0, 3.04))
Audio(waveform2, rate=sample_rate2)
Doesn’t it sound more dramatic?
Simulating room reverberation
Convolution reverb is a technique that’s used to make clean audio sound as though it has been produced in a different environment.
Using Room Impulse Response (RIR), for instance, we can make clean speech sound as though it has been uttered in a conference room.
For this process, we need RIR data. The following data are from the VOiCES dataset, but you can record your own — just turn on your microphone and clap your hands.
rir_raw, sample_rate = torchaudio.load(SAMPLE_RIR)
plot_waveform(rir_raw, sample_rate, title="Room Impulse Response (raw)")
plot_specgram(rir_raw, sample_rate, title="Room Impulse Response (raw)")
Audio(rir_raw, rate=sample_rate)
First, we need to clean up the RIR. We extract the main impulse, normalize the signal power, then flip along the time axis.
rir = rir_raw[:, int(sample_rate * 1.01) : int(sample_rate * 1.3)]
rir = rir / torch.norm(rir, p=2)
RIR = torch.flip(rir, [1])
plot_waveform(rir, sample_rate, title="Room Impulse Response")
Then, we convolve the speech signal with the RIR filter.
speech, _ = torchaudio.load(SAMPLE_SPEECH)
speech_ = torch.nn.functional.pad(speech, (RIR.shape[1] - 1, 0))
augmented = torch.nn.functional.conv1d(speech_[None, ...], RIR[None, ...])[0]
Original:
plot_waveform(speech, sample_rate, title="Original")
plot_specgram(speech, sample_rate, title="Original")
Audio(speech, rate=sample_rate)
RIR applied:
plot_waveform(augmented, sample_rate, title="RIR Applied")
plot_specgram(augmented, sample_rate, title="RIR Applied")
Audio(augmented, rate=sample_rate)
Adding background noise
To add background noise to audio data, you can simply add a noise Tensor to the Tensor representing the audio data. A common method to adjust the intensity of noise is changing the Signal-to-Noise Ratio (SNR). [wikipedia]
$$ \mathrm{SNR} = \frac{P_{signal}}{P_{noise}} $$
$$ \mathrm{SNR_{dB}} = 10 \log _{{10}} \mathrm {SNR} $$
noise, _ = torchaudio.load(SAMPLE_NOISE)
noise = noise[:, : speech.shape[1]]
speech_rms = speech.norm(p=2)
noise_rms = noise.norm(p=2)
snr_dbs = [20, 10, 3]
noisy_speeches = []
for snr_db in snr_dbs:
snr = 10 ** (snr_db / 20)
scale = snr * noise_rms / speech_rms
noisy_speeches.append((scale * speech + noise) / 2)
Background noise:
plot_waveform(noise, sample_rate, title="Background noise")
plot_specgram(noise, sample_rate, title="Background noise")
Audio(noise, rate=sample_rate)
SNR 20 dB:
snr_db, noisy_speech = snr_dbs[0], noisy_speeches[0]
plot_waveform(noisy_speech, sample_rate, title=f"SNR: {snr_db} [dB]")
plot_specgram(noisy_speech, sample_rate, title=f"SNR: {snr_db} [dB]")
Audio(noisy_speech, rate=sample_rate)
SNR 10 dB:
snr_db, noisy_speech = snr_dbs[1], noisy_speeches[1]
SNR 3 dB:
snr_db, noisy_speech = snr_dbs[2], noisy_speeches[2]
Applying codec to Tensor object
torchaudio.functional.apply_codec()
can apply codecs to
a Tensor object.
waveform, sample_rate = torchaudio.load(SAMPLE_SPEECH)
configs = [
{"format": "wav", "encoding": "ULAW", "bits_per_sample": 8},
{"format": "gsm"},
{"format": "vorbis", "compression": -1},
waveforms = []
for param in configs:
augmented = F.apply_codec(waveform, sample_rate, **param)
waveforms.append(augmented)
Original:
plot_waveform(waveform, sample_rate, title="Original")
plot_specgram(waveform, sample_rate, title="Original")
Audio(waveform, rate=sample_rate)
8 bit mu-law:
plot_waveform(waveforms[0], sample_rate, title="8 bit mu-law")
plot_specgram(waveforms[0], sample_rate, title="8 bit mu-law")
Audio(waveforms[0], rate=sample_rate)
GSM-FR:
plot_waveform(waveforms[1], sample_rate, title="GSM-FR")
plot_specgram(waveforms[1], sample_rate, title="GSM-FR")
Audio(waveforms[1], rate=sample_rate)
Vorbis:
plot_waveform(waveforms[2], sample_rate, title="Vorbis")
plot_specgram(waveforms[2], sample_rate, title="Vorbis")
Audio(waveforms[2], rate=sample_rate)
Simulating a phone recoding
Combining the previous techniques, we can simulate audio that sounds like a person talking over a phone in a echoey room with people talking in the background.
sample_rate = 16000
original_speech, sample_rate = torchaudio.load(SAMPLE_SPEECH)
plot_specgram(original_speech, sample_rate, title="Original")
# Apply RIR
speech_ = torch.nn.functional.pad(original_speech, (RIR.shape[1] - 1, 0))
rir_applied = torch.nn.functional.conv1d(speech_[None, ...], RIR[None, ...])[0]
plot_specgram(rir_applied, sample_rate, title="RIR Applied")
# Add background noise
# Because the noise is recorded in the actual environment, we consider that
# the noise contains the acoustic feature of the environment. Therefore, we add
# the noise after RIR application.
noise = noise[:, : rir_applied.shape[1]]
snr_db = 8
scale = (10 ** (snr_db / 20)) * noise.norm(p=2) / rir_applied.norm(p=2)
bg_added = (scale * rir_applied + noise) / 2
plot_specgram(bg_added, sample_rate, title="BG noise added")
# Apply filtering and change sample rate
filtered, sample_rate2 = torchaudio.sox_effects.apply_effects_tensor(
bg_added,
sample_rate,
effects=[
["lowpass", "4000"],
"compand",
"0.02,0.05",
"-60,-60,-30,-10,-20,-8,-5,-8,-2,-8",
"-8",
"-7",
"0.05",
["rate", "8000"],
plot_specgram(filtered, sample_rate2, title="Filtered")
# Apply telephony codec
codec_applied = F.apply_codec(filtered, sample_rate2, format="gsm")
plot_specgram(codec_applied, sample_rate2, title="GSM Codec Applied")
Original speech:
Audio(original_speech, rate=sample_rate)
RIR applied:
Audio(rir_applied, rate=sample_rate)
Background noise added:
Audio(bg_added, rate=sample_rate)
Filtered:
Audio(filtered, rate=sample_rate2)
Codec applied:
Audio(codec_applied, rate=sample_rate2)
Total running time of the script: ( 0 minutes 13.079 seconds)
