目录
MVDR with torchaudio
Author Zhaoheng Ni
Overview
This is a tutorial on how to apply MVDR beamforming with torchaudio.transforms.MVDR().
Steps
  • Ideal Ratio Mask (IRM) is generated by dividing the clean/noise magnitude by the mixture magnitude.
  • We test all three solutions (ref_channel, stv_evd, stv_power) of torchaudio’s MVDR module.
  • We test the single-channel and multi-channel masks for MVDR beamforming. The multi-channel mask is averaged along channel dimension when computing the covariance matrices of speech and noise, respectively.
Preparation
First, we import the necessary packages and retrieve the data.
The multi-channel audio example is selected from ConferencingSpeech dataset.
The original filename is
SSB07200001\#noise-sound-bible-0038\#7.86_6.16_3.00_3.14_4.84_134.5285_191.7899_0.4735\#15217\#25.16333303751458\#0.2101221178590021.wav
which was generated with;
  • SSB07200001.wav from AISHELL-3 (Apache License v.2.0)
  • noise-sound-bible-0038.wav from MUSAN (Attribution 4.0 International — CC BY 4.0) # noqa: E501
import os
import IPython.display as ipd
import requests
import torch
import torchaudio
torch.random.manual_seed(0)
device = torch.device("cuda" if torch.cuda.is_available() else "cpu")
print(torch.__version__)
print(torchaudio.__version__)
print(device)
filenames = [
    "mix.wav",
    "reverb_clean.wav",
    "clean.wav",
base_url = "https://download.pytorch.org/torchaudio/tutorial-assets/mvdr"
for filename in filenames:
    os.makedirs("_assets", exist_ok=True)
    if not os.path.exists(filename):
        with open(f"_assets/{filename}", "wb") as file:
            file.write(requests.get(f"{base_url}/{filename}").content)
Out:
1.11.0+cpu
0.11.0+cpu
cpu
Generate the Ideal Ratio Mask (IRM)
Loading audio data
mix, sr = torchaudio.load("_assets/mix.wav")
reverb_clean, sr2 = torchaudio.load("_assets/reverb_clean.wav")
clean, sr3 = torchaudio.load("_assets/clean.wav")
assert sr == sr2
noise = mix - reverb_clean
Note
The MVDR Module requires torch.cdouble dtype for noisy STFT. We need to convert the dtype of the waveforms to torch.double
mix = mix.to(torch.double)
noise = noise.to(torch.double)
clean = clean.to(torch.double)
reverb_clean = reverb_clean.to(torch.double)
Compute STFT
stft = torchaudio.transforms.Spectrogram(
    n_fft=1024,
    hop_length=256,
    power=None,
istft = torchaudio.transforms.InverseSpectrogram(n_fft=1024, hop_length=256)
spec_mix = stft(mix)
spec_clean = stft(clean)
spec_reverb_clean = stft(reverb_clean)
spec_noise = stft(noise)
Note
We found using the mask directly peforms better than using the square root of it. This is slightly different from the definition of IRM.
def get_irms(spec_clean, spec_noise):
    mag_clean = spec_clean.abs() ** 2
    mag_noise = spec_noise.abs() ** 2
    irm_speech = mag_clean / (mag_clean + mag_noise)
    irm_noise = mag_noise / (mag_clean + mag_noise)
    return irm_speech, irm_noise
Note
We use reverberant clean speech as the target here, you can also set it to dry clean speech.
Apply MVDR
Apply MVDR beamforming by using multi-channel masks
results_multi = {}
for solution in ["ref_channel", "stv_evd", "stv_power"]:
    mvdr = torchaudio.transforms.MVDR(ref_channel=0, solution=solution, multi_mask=True)
    stft_est = mvdr(spec_mix, irm_speech, irm_noise)
    est = istft(stft_est, length=mix.shape[-1])
    results_multi[solution] = est
Apply MVDR beamforming by using single-channel masks
We use the 1st channel as an example. The channel selection may depend on the design of the microphone array
results_single = {}
    mvdr = torchaudio.transforms.MVDR(ref_channel=0, solution=solution, multi_mask=False)
    stft_est = mvdr(spec_mix, irm_speech[0], irm_noise[0])
    results_single[solution] = est
Compute Si-SDR scores
def si_sdr(estimate, reference, epsilon=1e-8):
    estimate = estimate - estimate.mean()
    reference = reference - reference.mean()
    reference_pow = reference.pow(2).mean(axis=1, keepdim=True)
    mix_pow = (estimate * reference).mean(axis=1, keepdim=True)
    scale = mix_pow / (reference_pow + epsilon)
    reference = scale * reference
    error = estimate - reference
    error_pow = error.pow(2)
    reference_pow = reference_pow.mean(axis=1)
    error_pow = error_pow.mean(axis=1)
    sisdr = 10 * torch.log10(reference_pow) - 10 * torch.log10(error_pow)
    return sisdr.item()
Results
Single-channel mask results
for solution in results_single:
    print(solution + ": ", si_sdr(results_single[solution][None, ...], reverb_clean[0:1]))
Out:
ref_channel:  15.035907456985868
stv_evd:  16.56373467383255
stv_power:  17.820481909929903
Multi-channel mask results
for solution in results_multi:
    print(solution + ": ", si_sdr(results_multi[solution][None, ...], reverb_clean[0:1]))
Out:
ref_channel:  13.177373866143256
stv_evd:  12.433610809532858
stv_power:  12.897505397104673
Original audio
Mixture speech
ipd.Audio(mix[0], rate=16000)
Noise
ipd.Audio(noise[0], rate=16000)
Clean speech
ipd.Audio(clean[0], rate=16000)
Enhanced audio
Multi-channel mask, ref_channel solution
ipd.Audio(results_multi["ref_channel"], rate=16000)
Multi-channel mask, stv_evd solution
ipd.Audio(results_multi["stv_evd"], rate=16000)
Multi-channel mask, stv_power solution
ipd.Audio(results_multi["stv_power"], rate=16000)
Single-channel mask, ref_channel solution
ipd.Audio(results_single["ref_channel"], rate=16000)
Single-channel mask, stv_evd solution
ipd.Audio(results_single["stv_evd"], rate=16000)
Single-channel mask, stv_power solution
ipd.Audio(results_single["stv_power"], rate=16000)
Total running time of the script: ( 0 minutes 0.790 seconds)
Gallery generated by Sphinx-Gallery
文档
访问 PyTorch 的全面开发人员文档
查看文档
教程
获取面向初学者和高级开发人员的深入教程
查看教程
资源
查找开发资源并解答您的问题
查看资源
