目录
Audio I/O
torchaudio integrates libsox and provides a rich set of audio I/O.
# When running this tutorial in Google Colab, install the required packages
# with the following.
# !pip install torchaudio boto3
import torch
import torchaudio
print(torch.__version__)
print(torchaudio.__version__)
Out:
1.11.0+cpu
0.11.0+cpu
Preparing data and utility functions (skip this section)
# @title Prepare data and utility functions. {display-mode: "form"}
# @markdown
# @markdown You do not need to look into this cell.
# @markdown Just execute once and you are good to go.
# @markdown
# @markdown In this tutorial, we will use a speech data from [VOiCES dataset](https://iqtlabs.github.io/voices/),
# @markdown which is licensed under Creative Commos BY 4.0.
import io
import os
import tarfile
import boto3
import requests
from botocore import UNSIGNED
from botocore.config import Config
from IPython.display import Audio, display
_SAMPLE_DIR = "_assets"
SAMPLE_WAV_URL = "https://pytorch-tutorial-assets.s3.amazonaws.com/steam-train-whistle-daniel_simon.wav"
SAMPLE_WAV_PATH = os.path.join(_SAMPLE_DIR, "steam.wav")
SAMPLE_MP3_URL = "https://pytorch-tutorial-assets.s3.amazonaws.com/steam-train-whistle-daniel_simon.mp3"
SAMPLE_MP3_PATH = os.path.join(_SAMPLE_DIR, "steam.mp3")
SAMPLE_GSM_URL = "https://pytorch-tutorial-assets.s3.amazonaws.com/steam-train-whistle-daniel_simon.gsm"
SAMPLE_GSM_PATH = os.path.join(_SAMPLE_DIR, "steam.gsm")
SAMPLE_WAV_SPEECH_URL = "https://pytorch-tutorial-assets.s3.amazonaws.com/VOiCES_devkit/source-16k/train/sp0307/Lab41-SRI-VOiCES-src-sp0307-ch127535-sg0042.wav"  # noqa: E501
SAMPLE_WAV_SPEECH_PATH = os.path.join(_SAMPLE_DIR, "speech.wav")
SAMPLE_TAR_URL = "https://pytorch-tutorial-assets.s3.amazonaws.com/VOiCES_devkit.tar.gz"
SAMPLE_TAR_PATH = os.path.join(_SAMPLE_DIR, "sample.tar.gz")
SAMPLE_TAR_ITEM = "VOiCES_devkit/source-16k/train/sp0307/Lab41-SRI-VOiCES-src-sp0307-ch127535-sg0042.wav"
S3_BUCKET = "pytorch-tutorial-assets"
S3_KEY = "VOiCES_devkit/source-16k/train/sp0307/Lab41-SRI-VOiCES-src-sp0307-ch127535-sg0042.wav"
def _fetch_data():
    os.makedirs(_SAMPLE_DIR, exist_ok=True)
    uri = [
        (SAMPLE_WAV_URL, SAMPLE_WAV_PATH),
        (SAMPLE_MP3_URL, SAMPLE_MP3_PATH),
        (SAMPLE_GSM_URL, SAMPLE_GSM_PATH),
        (SAMPLE_WAV_SPEECH_URL, SAMPLE_WAV_SPEECH_PATH),
        (SAMPLE_TAR_URL, SAMPLE_TAR_PATH),
    for url, path in uri:
        with open(path, "wb") as file_:
            file_.write(requests.get(url).content)
_fetch_data()
def print_stats(waveform, sample_rate=None, src=None):
    if src:
        print("-" * 10)
        print("Source:", src)
        print("-" * 10)
    if sample_rate:
        print("Sample Rate:", sample_rate)
    print("Shape:", tuple(waveform.shape))
    print("Dtype:", waveform.dtype)
    print(f" - Max:     {waveform.max().item():6.3f}")
    print(f" - Min:     {waveform.min().item():6.3f}")
    print(f" - Mean:    {waveform.mean().item():6.3f}")
    print(f" - Std Dev: {waveform.std().item():6.3f}")
    print()
    print(waveform)
    print()
def plot_waveform(waveform, sample_rate, title="Waveform", xlim=None, ylim=None):
    waveform = waveform.numpy()
    num_channels, num_frames = waveform.shape
    time_axis = torch.arange(0, num_frames) / sample_rate
    figure, axes = plt.subplots(num_channels, 1)
    if num_channels == 1:
        axes = [axes]
    for c in range(num_channels):
        axes[c].plot(time_axis, waveform[c], linewidth=1)
        axes[c].grid(True)
        if num_channels > 1:
            axes[c].set_ylabel(f"Channel {c+1}")
        if xlim:
            axes[c].set_xlim(xlim)
        if ylim:
            axes[c].set_ylim(ylim)
    figure.suptitle(title)
    plt.show(block=False)
def plot_specgram(waveform, sample_rate, title="Spectrogram", xlim=None):
        axes = [axes]
        axes[c].specgram(waveform[c], Fs=sample_rate)
        if xlim:
def play_audio(waveform, sample_rate):
        display(Audio(waveform[0], rate=sample_rate))
    elif num_channels == 2:
        display(Audio((waveform[0], waveform[1]), rate=sample_rate))
    else:
        raise ValueError("Waveform with more than 2 channels are not supported.")
def _get_sample(path, resample=None):
    effects = [["remix", "1"]]
    if resample:
        effects.extend(
                ["lowpass", f"{resample // 2}"],
                ["rate", f"{resample}"],
    return torchaudio.sox_effects.apply_effects_file(path, effects=effects)
def get_sample(*, resample=None):
    return _get_sample(SAMPLE_WAV_PATH, resample=resample)
def inspect_file(path):
    print("-" * 10)
    print("Source:", path)
    print("-" * 10)
    print(f" - File size: {os.path.getsize(path)} bytes")
    print(f" - {torchaudio.info(path)}")
Querying audio metadata
Function torchaudio.info() fetches audio metadata. You can provide a path-like object or file-like object.
metadata = torchaudio.info(SAMPLE_WAV_PATH)
print(metadata)
Out:
AudioMetaData(sample_rate=44100, num_frames=109368, num_channels=2, bits_per_sample=16, encoding=PCM_S)
Where
  • sample_rate is the sampling rate of the audio
  • num_channels is the number of channels
  • num_frames is the number of frames per channel
  • bits_per_sample is bit depth
  • encoding is the sample coding format
encoding can take on one of the following values:
Note
  • bits_per_sample can be 0 for formats with compression and/or variable bit rate (such as MP3).
  • num_frames can be 0 for GSM-FR format.
metadata = torchaudio.info(SAMPLE_MP3_PATH)
print(metadata)
metadata = torchaudio.info(SAMPLE_GSM_PATH)
print(metadata)
Out:
AudioMetaData(sample_rate=44100, num_frames=110559, num_channels=2, bits_per_sample=0, encoding=MP3)
AudioMetaData(sample_rate=8000, num_frames=0, num_channels=1, bits_per_sample=0, encoding=GSM)
Querying file-like object
torchaudio.info() works on file-like objects.
print("Source:", SAMPLE_WAV_URL)
with requests.get(SAMPLE_WAV_URL, stream=True) as response:
    metadata = torchaudio.info(response.raw)
print(metadata)
Out:
Source: https://pytorch-tutorial-assets.s3.amazonaws.com/steam-train-whistle-daniel_simon.wav
Note When passing a file-like object, info does not read all of the underlying data; rather, it reads only a portion of the data from the beginning. Therefore, for a given audio format, it may not be able to retrieve the correct metadata, including the format itself. The following example illustrates this.
  • Use argument format to specify the audio format of the input.
  • The returned metadata has num_frames = 0
print("Source:", SAMPLE_MP3_URL)
with requests.get(SAMPLE_MP3_URL, stream=True) as response:
    metadata = torchaudio.info(response.raw, format="mp3")
    print(f"Fetched {response.raw.tell()} bytes.")
print(metadata)
Out:
Source: https://pytorch-tutorial-assets.s3.amazonaws.com/steam-train-whistle-daniel_simon.mp3
Fetched 8192 bytes.
AudioMetaData(sample_rate=44100, num_frames=0, num_channels=2, bits_per_sample=0, encoding=MP3)
Loading audio data into Tensor
To load audio data, you can use torchaudio.load().
This function accepts a path-like object or file-like object as input.
The returned value is a tuple of waveform (Tensor) and sample rate (int).
By default, the resulting tensor object has dtype=torch.float32 and its value range is normalized within [-1.0, 1.0].
For the list of supported format, please refer to the torchaudio documentation.
waveform, sample_rate = torchaudio.load(SAMPLE_WAV_SPEECH_PATH)
print_stats(waveform, sample_rate=sample_rate)
plot_waveform(waveform, sample_rate)
plot_specgram(waveform, sample_rate)
  • Waveform
  • Spectrogram
Out:
Sample Rate: 16000
Shape: (1, 54400)
Dtype: torch.float32
 - Max:      0.668
 - Min:     -1.000
 - Mean:     0.000
 - Std Dev:  0.122
tensor([[0.0183, 0.0180, 0.0180,  ..., 0.0018, 0.0019, 0.0032]])
<IPython.lib.display.Audio object>
Loading from file-like object
torchaudio’s I/O functions now support file-like objects. This allows for fetching and decoding audio data from locations within and beyond the local file system. The following examples illustrate this.
# Load audio data as HTTP request
with requests.get(SAMPLE_WAV_SPEECH_URL, stream=True) as response:
    waveform, sample_rate = torchaudio.load(response.raw)
plot_specgram(waveform, sample_rate, title="HTTP datasource")
# Load audio from tar file
with tarfile.open(SAMPLE_TAR_PATH, mode="r") as tarfile_:
    fileobj = tarfile_.extractfile(SAMPLE_TAR_ITEM)
    waveform, sample_rate = torchaudio.load(fileobj)
plot_specgram(waveform, sample_rate, title="TAR file")
# Load audio from S3
client = boto3.client("s3", config=Config(signature_version=UNSIGNED))
response = client.get_object(Bucket=S3_BUCKET, Key=S3_KEY)
waveform, sample_rate = torchaudio.load(response["Body"])
plot_specgram(waveform, sample_rate, title="From S3")
  • HTTP datasource
  • TAR file
  • From S3
Tips on slicing
Providing num_frames and frame_offset arguments restricts decoding to the corresponding segment of the input.
The same result can be achieved using vanilla Tensor slicing, (i.e. waveform[:, frame_offset:frame_offset+num_frames]). However, providing num_frames and frame_offset arguments is more efficient.
This is because the function will end data acquisition and decoding once it finishes decoding the requested frames. This is advantageous when the audio data are transferred via network as the data transfer will stop as soon as the necessary amount of data is fetched.
# Illustration of two different decoding methods.
# The first one will fetch all the data and decode them, while
# the second one will stop fetching data once it completes decoding.
# The resulting waveforms are identical.
frame_offset, num_frames = 16000, 16000  # Fetch and decode the 1 - 2 seconds
print("Fetching all the data...")
    waveform1, sample_rate1 = torchaudio.load(response.raw)
    waveform1 = waveform1[:, frame_offset : frame_offset + num_frames]
    print(f" - Fetched {response.raw.tell()} bytes")
print("Fetching until the requested frames are available...")
    waveform2, sample_rate2 = torchaudio.load(response.raw, frame_offset=frame_offset, num_frames=num_frames)
print("Checking the resulting waveform ... ", end="")
assert (waveform1 == waveform2).all()
print("matched!")
Out:
 - Fetched 108844 bytes
 - Fetched 65580 bytes
Checking the resulting waveform ... matched!
Saving audio to file
To save audio data in formats interpretable by common applications, you can use torchaudio.save().
This function accepts a path-like object or file-like object.
When passing a file-like object, you also need to provide argument format so that the function knows which format it should use. In the case of a path-like object, the function will infer the format from the extension. If you are saving to a file without an extension, you need to provide argument format.
When saving WAV-formatted data, the default encoding for float32 Tensor is 32-bit floating-point PCM. You can provide arguments encoding and bits_per_sample to change this behavior. For example, to save data in 16-bit signed integer PCM, you can do the following.
Note Saving data in encodings with lower bit depth reduces the resulting file size but also precision.
waveform, sample_rate = get_sample()
# Save without any encoding option.
# The function will pick up the encoding which
# the provided data fit
path = f"{_SAMPLE_DIR}/save_example_default.wav"
torchaudio.save(path, waveform, sample_rate)
inspect_file(path)
# Save as 16-bit signed integer Linear PCM
# The resulting file occupies half the storage but loses precision
path = f"{_SAMPLE_DIR}/save_example_PCM_S16.wav"
torchaudio.save(path, waveform, sample_rate, encoding="PCM_S", bits_per_sample=16)
inspect_file(path)
Out:
Sample Rate: 44100
Shape: (1, 109368)
 - Max:      0.508
 - Min:     -0.449
 - Mean:    -0.000
 - Std Dev:  0.122
tensor([[0.0027, 0.0063, 0.0092,  ..., 0.0032, 0.0047, 0.0052]])
Source: _assets/save_example_default.wav
 - File size: 437530 bytes
 - AudioMetaData(sample_rate=44100, num_frames=109368, num_channels=1, bits_per_sample=32, encoding=PCM_F)
Source: _assets/save_example_PCM_S16.wav
 - File size: 218780 bytes
 - AudioMetaData(sample_rate=44100, num_frames=109368, num_channels=1, bits_per_sample=16, encoding=PCM_S)
:py:func`torchaudio.save` can also handle other formats. To name a few:
waveform, sample_rate = get_sample(resample=8000)
formats = [
    "mp3",
    "flac",
    "vorbis",
    "sph",
    "amb",
    "amr-nb",
    "gsm",
for format in formats:
    path = f"{_SAMPLE_DIR}/save_example.{format}"
    torchaudio.save(path, waveform, sample_rate, format=format)
    inspect_file(path)
Out:
Source: _assets/save_example.mp3
 - File size: 2664 bytes
 - AudioMetaData(sample_rate=8000, num_frames=21312, num_channels=1, bits_per_sample=0, encoding=MP3)
Source: _assets/save_example.flac
 - File size: 47315 bytes
 - AudioMetaData(sample_rate=8000, num_frames=19840, num_channels=1, bits_per_sample=24, encoding=FLAC)
Source: _assets/save_example.vorbis
 - File size: 9967 bytes
 - AudioMetaData(sample_rate=8000, num_frames=19840, num_channels=1, bits_per_sample=0, encoding=VORBIS)
Source: _assets/save_example.sph
 - File size: 80384 bytes
 - AudioMetaData(sample_rate=8000, num_frames=19840, num_channels=1, bits_per_sample=32, encoding=PCM_S)
Source: _assets/save_example.amb
 - File size: 79418 bytes
 - AudioMetaData(sample_rate=8000, num_frames=19840, num_channels=1, bits_per_sample=32, encoding=PCM_F)
Source: _assets/save_example.amr-nb
 - File size: 1618 bytes
 - AudioMetaData(sample_rate=8000, num_frames=19840, num_channels=1, bits_per_sample=0, encoding=AMR_NB)
Source: _assets/save_example.gsm
 - File size: 4092 bytes
 - AudioMetaData(sample_rate=8000, num_frames=0, num_channels=1, bits_per_sample=0, encoding=GSM)
Saving to file-like object
Similar to the other I/O functions, you can save audio to file-like objects. When saving to a file-like object, argument format is required.
# Saving to bytes buffer
buffer_ = io.BytesIO()
torchaudio.save(buffer_, waveform, sample_rate, format="wav")
buffer_.seek(0)
print(buffer_.read(16))
Out:
b'RIFF\x12\xad\x06\x00WAVEfmt '
Total running time of the script: ( 0 minutes 2.243 seconds)
Gallery generated by Sphinx-Gallery
文档
访问 PyTorch 的全面开发人员文档
查看文档
教程
获取面向初学者和高级开发人员的深入教程
查看教程
资源
查找开发资源并解答您的问题
查看资源
