目录
Audio Datasets
torchaudio provides easy access to common, publicly accessible datasets. Please refer to the official documentation for the list of available datasets.
# When running this tutorial in Google Colab, install the required packages
# with the following.
# !pip install torchaudio
import torch
import torchaudio
print(torch.__version__)
print(torchaudio.__version__)
Out:
1.11.0+cpu
0.11.0+cpu
Preparing data and utility functions (skip this section)
# @title Prepare data and utility functions. {display-mode: "form"}
# @markdown
# @markdown You do not need to look into this cell.
# @markdown Just execute once and you are good to go.
# Preparation of data and helper functions.
import multiprocessing
import os
from IPython.display import Audio, display
_SAMPLE_DIR = "_assets"
YESNO_DATASET_PATH = os.path.join(_SAMPLE_DIR, "yes_no")
os.makedirs(YESNO_DATASET_PATH, exist_ok=True)
def plot_specgram(waveform, sample_rate, title="Spectrogram", xlim=None):
    waveform = waveform.numpy()
    num_channels, num_frames = waveform.shape
    figure, axes = plt.subplots(num_channels, 1)
    if num_channels == 1:
        axes = [axes]
    for c in range(num_channels):
        axes[c].specgram(waveform[c], Fs=sample_rate)
        if num_channels > 1:
            axes[c].set_ylabel(f"Channel {c+1}")
        if xlim:
            axes[c].set_xlim(xlim)
    figure.suptitle(title)
    plt.show(block=False)
def play_audio(waveform, sample_rate):
        display(Audio(waveform[0], rate=sample_rate))
    elif num_channels == 2:
        display(Audio((waveform[0], waveform[1]), rate=sample_rate))
    else:
        raise ValueError("Waveform with more than 2 channels are not supported.")
Here, we show how to use the torchaudio.datasets.YESNO() dataset.
dataset = torchaudio.datasets.YESNO(YESNO_DATASET_PATH, download=True)
for i in [1, 3, 5]:
    waveform, sample_rate, label = dataset[i]
    plot_specgram(waveform, sample_rate, title=f"Sample {i}: {label}")
  • Sample 1: [0, 0, 0, 1, 0, 0, 0, 1]
  • Sample 3: [0, 0, 1, 0, 0, 0, 1, 0]
  • Sample 5: [0, 0, 1, 0, 0, 1, 1, 1]
Out:
  0%|          | 0.00/4.49M [00:00<?, ?B/s]
  1%|          | 32.0k/4.49M [00:00<00:25, 186kB/s]
  4%|4         | 200k/4.49M [00:00<00:07, 635kB/s]
 18%|#8        | 832k/4.49M [00:00<00:01, 1.97MB/s]
 64%|######4   | 2.88M/4.49M [00:00<00:00, 5.86MB/s]
100%|##########| 4.49M/4.49M [00:00<00:00, 5.74MB/s]
<IPython.lib.display.Audio object>
Total running time of the script: ( 0 minutes 2.440 seconds)
Gallery generated by Sphinx-Gallery
文档
访问 PyTorch 的全面开发人员文档
查看文档
教程
获取面向初学者和高级开发人员的深入教程
查看教程
资源
查找开发资源并解答您的问题
查看资源
