目录
torchaudio.kaldi_io
To use this module, the dependency kaldi_io needs to be installed. This is a light wrapper around kaldi_io that returns torch.Tensor.
Vectors
read_vec_int_ark
torchaudio.kaldi_io.read_vec_int_ark(file_or_fd: Any)Iterable[Tuple[str, torch.Tensor]][source]
Create generator of (key,vector<int>) tuples, which reads from the ark file/stream.
Parameters
file_or_fd (str/FileDescriptor) – ark, gzipped ark, pipe or opened file descriptor
Returns
The string is the key and the tensor is the vector read from file
Return type
Iterable[Tuple[str, Tensor]]
Example
>>> # read ark to a 'dictionary'
>>> d = { u:d for u,d in torchaudio.kaldi_io.read_vec_int_ark(file) }
read_vec_flt_scp
torchaudio.kaldi_io.read_vec_flt_scp(file_or_fd: Any)Iterable[Tuple[str, torch.Tensor]][source]
Create generator of (key,vector<float32/float64>) tuples, read according to Kaldi scp.
Parameters
file_or_fd (str/FileDescriptor) – scp, gzipped scp, pipe or opened file descriptor
Returns
Return type
Example
>>> # read scp to a 'dictionary'
>>> # d = { u:d for u,d in torchaudio.kaldi_io.read_vec_flt_scp(file) }
read_vec_flt_ark
torchaudio.kaldi_io.read_vec_flt_ark(file_or_fd: Any)Iterable[Tuple[str, torch.Tensor]][source]
Create generator of (key,vector<float32/float64>) tuples, which reads from the ark file/stream.
Parameters
Returns
Return type
Example
>>> d = { u:d for u,d in torchaudio.kaldi_io.read_vec_flt_ark(file) }
Matrices
read_mat_scp
torchaudio.kaldi_io.read_mat_scp(file_or_fd: Any)Iterable[Tuple[str, torch.Tensor]][source]
Create generator of (key,matrix<float32/float64>) tuples, read according to Kaldi scp.
Parameters
Returns
The string is the key and the tensor is the matrix read from file
Return type
Example
>>> d = { u:d for u,d in torchaudio.kaldi_io.read_mat_scp(file) }
read_mat_ark
torchaudio.kaldi_io.read_mat_ark(file_or_fd: Any)Iterable[Tuple[str, torch.Tensor]][source]
Create generator of (key,matrix<float32/float64>) tuples, which reads from the ark file/stream.
Parameters
Returns
Return type
Example
>>> d = { u:d for u,d in torchaudio.kaldi_io.read_mat_ark(file) }
文档
访问 PyTorch 的全面开发人员文档
查看文档
教程
获取面向初学者和高级开发人员的深入教程
查看教程
资源
查找开发资源并解答您的问题
查看资源
APP信息
