Note
Click here to download the full example code
Audio Feature Augmentation¶
Author: Moto Hira
# When running this tutorial in Google Colab, install the required packages
# with the following.
# !pip install torchaudio librosa
import torch
import torchaudio
import torchaudio.transforms as T
print(torch.__version__)
print(torchaudio.__version__)
2.5.0
2.5.0
Preparation¶
import librosa
from IPython.display import Audio
from torchaudio.utils import download_asset
In this tutorial, we will use a speech data from VOiCES dataset, which is licensed under Creative Commos BY 4.0.
SAMPLE_WAV_SPEECH_PATH = download_asset("tutorial-assets/Lab41-SRI-VOiCES-src-sp0307-ch127535-sg0042.wav")
def _get_sample(path, resample=None):
effects = [["remix", "1"]]
if resample:
effects.extend(
["lowpass", f"{resample // 2}"],
["rate", f"{resample}"],
return torchaudio.sox_effects.apply_effects_file(path, effects=effects)
def get_speech_sample(*, resample=None):
return _get_sample(SAMPLE_WAV_SPEECH_PATH, resample=resample)
def get_spectrogram(
n_fft=400,
win_len=None,
hop_len=None,
power=2.0,
waveform, _ = get_speech_sample()
spectrogram = T.Spectrogram(
n_fft=n_fft,
win_length=win_len,
hop_length=hop_len,
center=True,
pad_mode="reflect",
power=power,
return spectrogram(waveform)
SpecAugment¶
SpecAugment is a popular spectrogram augmentation technique.
torchaudio
implements torchaudio.transforms.TimeStretch()
torchaudio.transforms.TimeMasking()
and
torchaudio.transforms.FrequencyMasking()
TimeStretch¶
Visualization¶
def plot():
def plot_spec(ax, spec, title):
ax.set_title(title)
ax.imshow(librosa.amplitude_to_db(spec), origin="lower", aspect="auto")
fig, axes = plt.subplots(3, 1, sharex=True, sharey=True)
plot_spec(axes[0], torch.abs(spec_12[0]), title="Stretched x1.2")
plot_spec(axes[1], torch.abs(spec[0]), title="Original")
plot_spec(axes[2], torch.abs(spec_09[0]), title="Stretched x0.9")
fig.tight_layout()
plot()
![Stretched x1.2, Original, Stretched x0.9](https://pytorch.org/audio/2.5.0/_images/sphx_glr_audio_feature_augmentation_tutorial_001.png)
Audio Samples¶
def preview(spec, rate=16000):
ispec = T.InverseSpectrogram()
waveform = ispec(spec)
return Audio(waveform[0].numpy().T, rate=rate)
preview(spec)
preview(spec_12)
preview(spec_09)
Time and Frequency Masking¶
torch.random.manual_seed(4)
time_masking = T.TimeMasking(time_mask_param=80)
freq_masking = T.FrequencyMasking(freq_mask_param=80)
spec = get_spectrogram()
time_masked = time_masking(spec)
freq_masked = freq_masking(spec)
def plot():
ax.set_title(title)
ax.imshow(librosa.power_to_db(spec), origin="lower", aspect="auto")
plot_spec(axes[0], spec[0], title="Original")
plot_spec(axes[1], time_masked[0], title="Masked along time axis")
plot_spec(axes[2], freq_masked[0], title="Masked along frequency axis")
fig.tight_layout()
plot()
![Original, Masked along time axis, Masked along frequency axis](https://pytorch.org/audio/2.5.0/_images/sphx_glr_audio_feature_augmentation_tutorial_002.png)
Total running time of the script: ( 0 minutes 2.298 seconds)
