目录
Audio Datasets
Author: Moto Hira
torchaudio provides easy access to common, publicly accessible datasets. Please refer to the official documentation for the list of available datasets.
import torch
import torchaudio
print(torch.__version__)
print(torchaudio.__version__)
2.5.0
2.5.0
import os
import IPython
_SAMPLE_DIR = "_assets"
YESNO_DATASET_PATH = os.path.join(_SAMPLE_DIR, "yes_no")
os.makedirs(YESNO_DATASET_PATH, exist_ok=True)
def plot_specgram(waveform, sample_rate, title="Spectrogram"):
    waveform = waveform.numpy()
    figure, ax = plt.subplots()
    ax.specgram(waveform[0], Fs=sample_rate)
    figure.suptitle(title)
    figure.tight_layout()
Here, we show how to use the torchaudio.datasets.YESNO dataset.
  0%|          | 0.00/4.49M [00:00<?, ?B/s]
  3%|2         | 128k/4.49M [00:00<00:08, 546kB/s]
 11%|#1        | 512k/4.49M [00:00<00:02, 1.47MB/s]
 36%|###6      | 1.62M/4.49M [00:00<00:00, 3.89MB/s]
100%|##########| 4.49M/4.49M [00:00<00:00, 7.28MB/s]
i = 1
waveform, sample_rate, label = dataset[i]
plot_specgram(waveform, sample_rate, title=f"Sample {i}: {label}")
IPython.display.Audio(waveform, rate=sample_rate)
Sample 1: [0, 0, 0, 1, 0, 0, 0, 1]
i = 3
Sample 3: [0, 0, 1, 0, 0, 0, 1, 0]
i = 5
Sample 5: [0, 0, 1, 0, 0, 1, 1, 1]
Total running time of the script: ( 0 minutes 1.965 seconds)
Gallery generated by Sphinx-Gallery
文档
访问 PyTorch 的全面开发人员文档
查看文档
教程
获取面向初学者和高级开发人员的深入教程
查看教程
资源
查找开发资源并解答您的问题
查看资源
