目录
Warning
TorchAudio’s C++ API is a prototype feature. API/ABI backward compatibility is not guaranteed.
Note
The top-level namespace has been changed from torchaudio to torio. StreamReader has been renamed to StreamingMediaDecoder.
torio::io::StreamingMediaDecoder
StreamingMediaDecoder is the implementation used by Python equivalent and provides similar interface. When working with custom I/O, such as in-memory data, StreamingMediaDecoderCustomIO class can be used.
Both classes have the same methods defined, so their usages are the same.
Constructors
class StreamingMediaDecoder
Fetch and decode audio/video streams chunk by chunk.
Subclassed by torio::io::StreamingMediaDecoderCustomIO
Warning
doxygenfunction: Unable to resolve function “torio::io::StreamingMediaDecoder::StreamingMediaDecoder” with arguments (const std::string&, const std::optional<std::string>&, const c10::optional<OptionDict>&) in doxygen xml output for project “libtorio” from directory: cpp/xml. Potential matches:
- StreamingMediaDecoder(const std::string &src, const std::optional<std::string> &format = c10::nullopt, const std::optional<OptionDict> &option = c10::nullopt)
class StreamingMediaDecoderCustomIO : private detail::CustomInput, public torio::io::StreamingMediaDecoder
A subclass of StreamingMediaDecoder which works with custom read function. Can be used for decoding media from memory or custom object.
torio::io::StreamingMediaDecoderCustomIO::StreamingMediaDecoderCustomIO(void *opaque, const std::optional<std::string> &format, int buffer_size, int (*read_packet)(void *opaque, uint8_t *buf, int buf_size), int64_t (*seek)(void *opaque, int64_t offset, int whence) = nullptr, const std::optional<OptionDict> &option = c10::nullopt)
Construct StreamingMediaDecoder with custom read and seek functions.
Parameters:
  • opaque – Custom data used by read_packet and seek functions.
  • format – Specify input format.
  • buffer_size – The size of the intermediate buffer, which FFmpeg uses to pass data to function read_packet.
  • read_packet – Custom read function that is called from FFmpeg to read data from the destination.
  • seek – Optional seek function that is used to seek the destination.
  • option – Custom option passed when initializing format context.
Query Methods
find_best_audio_stream
int64_t torio::io::StreamingMediaDecoder::find_best_audio_stream() const
Find a suitable audio stream using heuristics from ffmpeg.
If successful, the index of the best stream (>=0) is returned. Otherwise a negative value is returned.
find_best_video_stream
int64_t torio::io::StreamingMediaDecoder::find_best_video_stream() const
Find a suitable video stream using heuristics from ffmpeg.
If successful, the index of the best stream (0>=) is returned. otherwise a negative value is returned.
get_metadata
OptionDict torio::io::StreamingMediaDecoder::get_metadata() const
Fetch metadata of the source media.
num_src_streams
int64_t torio::io::StreamingMediaDecoder::num_src_streams() const
Fetch the number of source streams found in the input media.
The source streams include not only audio/video streams but also subtitle and others.
get_src_stream_info
SrcStreamInfo torio::io::StreamingMediaDecoder::get_src_stream_info(int i) const
Fetch information about the specified source stream.
The valid value range is [0, num_src_streams()).
num_out_streams
int64_t torio::io::StreamingMediaDecoder::num_out_streams() const
Fetch the number of output streams defined by client code.
get_out_stream_info
OutputStreamInfo torio::io::StreamingMediaDecoder::get_out_stream_info(int i) const
Fetch information about the specified output stream.
The valid value range is [0, num_out_streams()).
is_buffer_ready
bool torio::io::StreamingMediaDecoder::is_buffer_ready() const
Check if all the buffers of the output streams have enough decoded frames.
Configure Methods
add_audio_stream
void torio::io::StreamingMediaDecoder::add_audio_stream(int64_t i, int64_t frames_per_chunk, int64_t num_chunks, const std::optional<std::string> &filter_desc = c10::nullopt, const std::optional<std::string> &decoder = c10::nullopt, const std::optional<OptionDict> &decoder_option = c10::nullopt)
Define an output audio stream.
Parameters:
  • i – The index of the source stream.
  • frames_per_chunk – Number of frames returned as one chunk.
    If a source stream is exhausted before frames_per_chunk frames are buffered, the chunk is returned as-is. Thus the number of frames in the chunk may be smaller than ``frames_per_chunk.
    Providing -1 disables chunking, in which case, method pop_chunks() returns all the buffered frames as one chunk.
  • num_chunks – Internal buffer size.
    When the number of buffered chunks exceeds this number, old chunks are dropped. For example, if frames_per_chunk is 5 and buffer_chunk_size is 3, then frames older than 15 are dropped.
    Providing -1 disables this behavior, forcing the retention of all chunks.
  • filter_desc – Description of filter graph applied to the source stream.
  • decoder – The name of the decoder to be used. When provided, use the specified decoder instead of the default one.
  • decoder_option – Options passed to decoder.
    To list decoder options for a decoder, you can use ffmpeg -h decoder=<DECODER> command.
    In addition to decoder-specific options, you can also pass options related to multithreading. They are effective only if the decoder supports them. If neither of them are provided, StreamingMediaDecoder defaults to single thread.
    • "threads": The number of threads or the value "0" to let FFmpeg decide based on its heuristics.
    • "thread_type": Which multithreading method to use. The valid values are "frame" or "slice". Note that each decoder supports a different set of methods. If not provided, a default value is used.
      • "frame": Decode more than one frame at once. Each thread handles one frame. This will increase decoding delay by one frame per thread
      • "slice": Decode more than one part of a single frame at once.
add_video_stream
void torio::io::StreamingMediaDecoder::add_video_stream(int64_t i, int64_t frames_per_chunk, int64_t num_chunks, const std::optional<std::string> &filter_desc = c10::nullopt, const std::optional<std::string> &decoder = c10::nullopt, const std::optional<OptionDict> &decoder_option = c10::nullopt, const std::optional<std::string> &hw_accel = c10::nullopt)
Define an output video stream.
Parameters:
  • i, frames_per_chunk, num_chunks, filter_desc, decoder, decoder_option – See add_audio_stream().
  • hw_accel – Enable hardware acceleration.
    When video is decoded on CUDA hardware, (for example by specifying "h264_cuvid" decoder), passing CUDA device indicator to hw_accel (i.e. hw_accel="cuda:0") will make StreamingMediaDecoder place the resulting frames directly on the specified CUDA device as a CUDA tensor.
    If None, the chunk will be moved to CPU memory.
remove_stream
void torio::io::StreamingMediaDecoder::remove_stream(int64_t i)
Remove an output stream.
Parameters:
i – The index of the output stream to be removed. The valid value range is [0, num_out_streams()).
Stream Methods
seek
void torio::io::StreamingMediaDecoder::seek(double timestamp, int64_t mode)
Seek into the given time stamp.
Parameters:
  • timestamp – Target time stamp in second.
  • mode – Seek mode.
    • 0: Keyframe mode. Seek into nearest key frame before the given timestamp.
    • 1: Any mode. Seek into any frame (including non-key frames) before the given timestamp.
    • 2: Precise mode. First seek into the nearest key frame before the given timestamp, then decode frames until it reaches the frame closest to the given timestamp.
process_packet
int torio::io::StreamingMediaDecoder::process_packet()
Demultiplex and process one packet.
Returns:
  • 0: A packet was processed successfully and there are still packets left in the stream, so client code can call this method again.
  • 1: A packet was processed successfully and it reached EOF. Client code should not call this method again.
  • <0: An error has happened.
process_packet_block
int torio::io::StreamingMediaDecoder::process_packet_block(const double timeout, const double backoff)
Similar to process_packet(), but in case it fails due to resource temporarily being unavailable, it automatically retries.
This behavior is helpful when using device input, such as a microphone, during which the buffer may be busy while sample acquisition is happening.
Parameters:
  • timeout – Timeout in milli seconds.
    • >=0: Keep retrying until the given time passes.
    • <0: Keep retrying forever.
  • backoff – Time to wait before retrying in milli seconds.
process_all_packets
void torio::io::StreamingMediaDecoder::process_all_packets()
Process packets unitl EOF.
fill_buffer
int torio::io::StreamingMediaDecoder::fill_buffer(const std::optional<double> &timeout = c10::nullopt, const double backoff = 10.)
Process packets until all the chunk buffers have at least one chunk
Parameters:
Retrieval Methods
pop_chunks
std::vector<std::optional<Chunk>> torio::io::StreamingMediaDecoder::pop_chunks()
Pop one chunk from each output stream if it is available.
Support Structures
Chunk
struct Chunk
Stores decoded frames and metadata.
Public Members
torch::Tensor frames
Audio/video frames.
For audio, the shape is [time, num_channels], and the dtype depends on output stream configurations.
For video, the shape is [time, channel, height, width], and the dtype is torch.uint8.
double pts
Presentation time stamp of the first frame, in second.
SrcStreaminfo
struct SrcStreamInfo
Information about source stream found in the input media.
COMMON MEMBERS
AVMediaType media_type
The stream media type.
Please see refer to the FFmpeg documentation for the available values
Todo:
Introduce own enum and get rid of FFmpeg dependency
const char *codec_name = "N/A"
The name of codec.
const char *codec_long_name = "N/A"
The name of codec in long, human friendly form.
const char *fmt_name = "N/A"
For audio, it is sample format.
Commonly found values are;
  • "u8", "u8p": 8-bit unsigned integer.
  • "s16", "s16p": 16-bit signed integer.
  • "s32", "s32p": 32-bit signed integer.
  • "s64", "s64p": 64-bit signed integer.
  • "flt", "fltp": 32-bit floating point.
  • "dbl", "dblp": 64-bit floating point.
For video, it is color channel format.
Commonly found values include;
  • "gray8": grayscale
  • "rgb24": RGB
  • "bgr24": BGR
  • "yuv420p": YUV420p
int64_t bit_rate = 0
Bit rate.
int64_t num_frames = 0
Number of frames.
Note
In some formats, the value is not reliable or unavailable.
int bits_per_sample = 0
Bits per sample.
OptionDict metadata = {}
Metadata
This method can fetch ID3 tag from MP3.
Example:
  "title": "foo",
  "artist": "bar",
  "date": "2017"
AUDIO-SPECIFIC MEMBERS
double sample_rate = 0
Sample rate.
int num_channels = 0
The number of channels.
VIDEO-SPECIFIC MEMBERS
int width = 0
Width.
int height = 0
Height.
double frame_rate = 0
Frame rate.
OutputStreaminfo
struct OutputStreamInfo
Information about output stream configured by user code.
double sample_rate = -1
Sample rate.
int num_channels = -1
int width = -1
Width.
int height = -1
Height.
AVRational frame_rate = {0, 1}
Frame rate.
Public Members
int source_index
The index of the input source stream.
AVMediaType media_type = AVMEDIA_TYPE_UNKNOWN
Todo:
int format = -1
Media format. AVSampleFormat for audio or AVPixelFormat for video.
std::string filter_description = {}
Filter graph definition, such as "aresample=16000,aformat=sample_fmts=fltp".
文档
访问 PyTorch 的全面开发人员文档
查看文档
教程
获取面向初学者和高级开发人员的深入教程
查看教程
资源
查找开发资源并解答您的问题
查看资源
