目录
StreamWriter Basic Usage
Author: Moto Hira
This tutorial shows how to use torchaudio.io.StreamWriter to encode and save audio/video data into various formats/destinations.
Note
This tutorial requires FFmpeg libraries. Please refer to FFmpeg dependency for the detail.
Warning
TorchAudio dynamically loads compatible FFmpeg libraries installed on the system. The types of supported formats (media format, encoder, encoder options, etc) depend on the libraries.
To check the available muxers and encoders, you can use the following command
ffmpeg -muxers
ffmpeg -encoders
Preparation
import torch
import torchaudio
print(torch.__version__)
print(torchaudio.__version__)
from torchaudio.io import StreamWriter
print("FFmpeg library versions")
for k, v in torchaudio.utils.ffmpeg_utils.get_versions().items():
    print(f"  {k}: {v}")
2.4.0
2.4.0
  libavcodec: (60, 3, 100)
  libavdevice: (60, 1, 100)
  libavfilter: (9, 3, 100)
  libavformat: (60, 3, 100)
  libavutil: (58, 2, 100)
import io
import os
import tempfile
from IPython.display import Audio, Video
from torchaudio.utils import download_asset
SAMPLE_PATH = download_asset("tutorial-assets/Lab41-SRI-VOiCES-src-sp0307-ch127535-sg0042.wav")
WAVEFORM, SAMPLE_RATE = torchaudio.load(SAMPLE_PATH, channels_first=False)
NUM_FRAMES, NUM_CHANNELS = WAVEFORM.shape
_BASE_DIR = tempfile.TemporaryDirectory()
def get_path(filename):
    return os.path.join(_BASE_DIR.name, filename)
The basic usage
To save Tensor data into media formats with StreamWriter, there are three necessary steps
  1. Specify the output
  2. Configure streams
  3. Write data
The following code illustrates how to save audio data as WAV file.
# 1. Define the destination. (local file in this case)
path = get_path("test.wav")
s = StreamWriter(path)
# 2. Configure the stream. (8kHz, Stereo WAV)
s.add_audio_stream(
    sample_rate=SAMPLE_RATE,
    num_channels=NUM_CHANNELS,
# 3. Write the data
with s.open():
    s.write_audio_chunk(0, WAVEFORM)
Audio(path)
Now we look into each step in more detail.
Write destination
StreamWriter supports different types of write destinations
  1. Local files
  2. File-like objects
  3. Streaming protocols (such as RTMP and UDP)
  4. Media devices (speakers and video players) †
† For media devices, please refer to StreamWriter Advanced Usages.
Local files
StreamWriter supports saving media to local files.
StreamWriter(dst="audio.wav")
StreamWriter(dst="audio.mp3")
This works for still images and videos as well.
StreamWriter(dst="image.jpeg")
StreamWriter(dst="video.mpeg")
File-like objects
You can also pass a file-lie object. A file-like object must implement write method conforming to io.RawIOBase.write.
# Open the local file as fileobj
with open("audio.wav", "wb") as dst:
    StreamWriter(dst=dst)
# In-memory encoding
buffer = io.BytesIO()
StreamWriter(dst=buffer)
Streaming protocols
You can stream the media with streaming protocols
# Real-Time Messaging Protocol
StreamWriter(dst="rtmp://localhost:1234/live/app", format="flv")
# UDP
StreamWriter(dst="udp://localhost:48550", format="mpegts")
Configuring output streams
Once the destination is specified, the next step is to configure the streams. For typical audio and still image cases, only one stream is required, but for video with audio, at least two streams (one for audio and the other for video) need to be configured.
Audio Stream
An audio stream can be added with add_audio_stream() method.
For writing regular audio files, at minimum sample_rate and num_channels are required.
s = StreamWriter("audio.wav")
s.add_audio_stream(sample_rate=8000, num_channels=2)
By default, audio streams expect the input waveform tensors to be torch.float32 type. If the above case, the data will be encoded into the detault encoding format of WAV format, which is 16-bit signed integer Linear PCM. StreamWriter converts the sample format internally.
If the encoder supports multiple sample formats and you want to change the encoder sample format, you can use encoder_format option.
In the following example, the StreamWriter expects the data type of the input waveform Tensor to be torch.float32, but it will convert the sample to 16-bit signed integer when encoding.
s = StreamWriter("audio.mp3")
s.add_audio_stream(
    encoder="libmp3lame",   # "libmp3lame" is often the default encoder for mp3,
                            # but specifying it manually, for the sake of illustration.
    encoder_format="s16p",  # "libmp3lame" encoder supports the following sample format.
                            #  - "s16p" (16-bit signed integer)
                            #  - "s32p" (32-bit signed integer)
                            #  - "fltp" (32-bit floating point)
If the data type of your waveform Tensor is something other than torch.float32, you can provide format option to change the expected data type.
The following example configures StreamWriter to expect Tensor of torch.int16 type.
# Audio data passed to StreamWriter must be torch.int16
s.add_audio_stream(..., format="s16")
The following figure illustrates how format and encoder_format options work for audio streams.
https://download.pytorch.org/torchaudio/tutorial-assets/streamwriter-format-audio.png
Video Stream
To add a still image or a video stream, you can use add_video_stream() method.
At minimum, frame_rate, height and width are required.
s = StreamWriter("video.mp4")
s.add_video_stream(frame_rate=10, height=96, width=128)
For still images, please use frame_rate=1.
s = StreamWriter("image.png")
s.add_video_stream(frame_rate=1, ...)
Similar to the audio stream, you can provide format and encoder_format option to controll the format of input data and encoding.
The following example encodes video data in YUV422 format.
s = StreamWriter("video.mov")
s.add_video_stream(
    encoder="libx264",  # libx264 supports different YUV formats, such as
                        # yuv420p yuvj420p yuv422p yuvj422p yuv444p yuvj444p nv12 nv16 nv21
    encoder_format="yuv422p",  # StreamWriter will convert the input data to YUV422 internally
YUV formats are commonly used in video encoding. Many YUV formats are composed of chroma channel of different plane size than that of luma channel. This makes it difficult to directly express it as torch.Tensor type. Therefore, StreamWriter will automatically convert the input video Tensor into the target format.
StreamWriter expects the input image tensor to be 4-D (time, channel, height, width) and torch.uint8 type.
The default color channel is RGB. That is three color channels corresponding red, green and blue. If your input has different color channel, such as BGR and YUV, you can specify it with format option.
The following example specifies BGR format.
s.add_video_stream(..., format="bgr24")
                   # Image data passed to StreamWriter must have
                   # three color channels representing Blue Green Red.
                   # The shape of the input tensor has to be
                   # (time, channel==3, height, width)
The following figure illustrates how format and encoder_format options work for video streams.
https://download.pytorch.org/torchaudio/tutorial-assets/streamwriter-format-video.png
Write data
Once streams are configured, the next step is to open the output location and start writing data.
Use open() method to open the destination, and then write data with write_audio_chunk() and/or write_video_chunk().
Audio tensors are expected to have the shape of (time, channels), and video/image tensors are expected to have the shape of (time, channels, height, width).
Channels, height and width must match the configuration of the corresponding stream, specified with "format" option.
Tensor representing a still image must have only one frame in time dimension, but audio and video tensors can have arbitral number of frames in time dimension.
The following code snippet illustrates this;
Ex) Audio
# Configure stream
s = StreamWriter(dst=get_path("audio.wav"))
s.add_audio_stream(sample_rate=SAMPLE_RATE, num_channels=NUM_CHANNELS)
# Write data
with s.open():
Ex) Image
# Image config
height = 96
width = 128
# Configure stream
s = StreamWriter(dst=get_path("image.png"))
s.add_video_stream(frame_rate=1, height=height, width=width, format="rgb24")
# Generate image
chunk = torch.randint(256, (1, 3, height, width), dtype=torch.uint8)
# Write data
with s.open():
    s.write_video_chunk(0, chunk)
Ex) Video without audio
# Video config
frame_rate = 30
height = 96
width = 128
# Configure stream
s = StreamWriter(dst=get_path("video.mp4"))
s.add_video_stream(frame_rate=frame_rate, height=height, width=width, format="rgb24")
# Generate video chunk (3 seconds)
time = int(frame_rate * 3)
chunk = torch.randint(256, (time, 3, height, width), dtype=torch.uint8)
# Write data
with s.open():
Ex) Video with audio
To write video with audio, separate streams have to be configured.
# Configure stream
# Generate audio/video chunk (3 seconds)
time = int(SAMPLE_RATE * 3)
audio_chunk = torch.randn((time, NUM_CHANNELS))
video_chunk = torch.randint(256, (time, 3, height, width), dtype=torch.uint8)
# Write data
with s.open():
    s.write_audio_chunk(0, audio_chunk)
    s.write_video_chunk(1, video_chunk)
Writing data chunk by chunk
When writing data, it is possible to split data along time dimension and write them by smaller chunks.
# Write data in one-go
dst1 = io.BytesIO()
s = StreamWriter(dst=dst1, format="mp3")
s.add_audio_stream(SAMPLE_RATE, NUM_CHANNELS)
with s.open():
# Write data in smaller chunks
dst2 = io.BytesIO()
s = StreamWriter(dst=dst2, format="mp3")
with s.open():
    for start in range(0, NUM_FRAMES, SAMPLE_RATE):
        end = start + SAMPLE_RATE
        s.write_audio_chunk(0, WAVEFORM[start:end, ...])
# Check that the contents are same
dst1.seek(0)
bytes1 = dst1.read()
print(f"bytes1: {len(bytes1)}")
print(f"{bytes1[:10]}...{bytes1[-10:]}\n")
dst2.seek(0)
bytes2 = dst2.read()
print(f"bytes2: {len(bytes2)}")
print(f"{bytes2[:10]}...{bytes2[-10:]}\n")
assert bytes1 == bytes2
bytes1: 10700
b'ID3\x04\x00\x00\x00\x00\x00"'...b'\xaa\xaa\xaa\xaa\xaa\xaa\xaa\xaa\xaa\xaa'
bytes2: 10700
Example - Spectrum Visualizer
In this section, we use StreamWriter to create a spectrum visualization of audio and save it as a video file.
To create spectrum visualization, we use torchaudio.transforms.Spectrogram, to get spectrum presentation of audio, generate raster images of its visualization using matplotplib, then use StreamWriter to convert them to video with the original audio.
import torchaudio.transforms as T
Prepare Data
First, we prepare the spectrogram data. We use Spectrogram.
We adjust hop_length so that one frame of the spectrogram corresponds to one video frame.
frame_rate = 20
n_fft = 4000
trans = T.Spectrogram(
    n_fft=n_fft,
    hop_length=SAMPLE_RATE // frame_rate,  # One FFT per one video frame
    normalized=True,
    power=1,
specs = trans(WAVEFORM.T)[0].T
The resulting spectrogram looks like the following.
spec_db = T.AmplitudeToDB(stype="magnitude", top_db=80)(specs.T)
_ = plt.imshow(spec_db, aspect="auto", origin="lower")
streamwriter basic tutorial
Prepare Canvas
We use matplotlib to visualize the spectrogram per frame. We create a helper function that plots the spectrogram data and generates a raster imager of the figure.
fig, ax = plt.subplots(figsize=[3.2, 2.4])
ax.set_position([0, 0, 1, 1])
ax.set_facecolor("black")
ncols, nrows = fig.canvas.get_width_height()
def _plot(data):
    ax.clear()
    x = list(range(len(data)))
    R, G, B = 238 / 255, 76 / 255, 44 / 255
    for coeff, alpha in [(0.8, 0.7), (1, 1)]:
        d = data**coeff
        ax.fill_between(x, d, -d, color=[R, G, B, alpha])
    xlim = n_fft // 2 + 1
    ax.set_xlim([-1, n_fft // 2 + 1])
    ax.set_ylim([-1, 1])
    ax.text(
        xlim,
        0.95,
        f"Created with TorchAudio\n{torchaudio.__version__}",
        color="white",
        ha="right",
        va="top",
        backgroundcolor="black",
    fig.canvas.draw()
    frame = torch.frombuffer(fig.canvas.tostring_rgb(), dtype=torch.uint8)
    return frame.reshape(nrows, ncols, 3).permute(2, 0, 1)
# sphinx_gallery_defer_figures
Write Video
Finally, we use StreamWriter and write video. We process one second of audio and video frames at a time.
s = StreamWriter(get_path("example.mp4"))
s.add_video_stream(frame_rate=frame_rate, height=nrows, width=ncols)
with s.open():
    i = 0
    # Process by second
    for t in range(0, NUM_FRAMES, SAMPLE_RATE):
        # Write audio chunk
        s.write_audio_chunk(0, WAVEFORM[t : t + SAMPLE_RATE, :])
        # write 1 second of video chunk
        frames = [_plot(spec) for spec in specs[i : i + frame_rate]]
        if frames:
            s.write_video_chunk(1, torch.stack(frames))
        i += frame_rate
plt.close(fig)
/pytorch/audio/examples/tutorials/streamwriter_basic_tutorial.py:566: MatplotlibDeprecationWarning: The tostring_rgb function was deprecated in Matplotlib 3.8 and will be removed two minor releases later. Use buffer_rgba instead.
/pytorch/audio/examples/tutorials/streamwriter_basic_tutorial.py:566: UserWarning: The given buffer is not writable, and PyTorch does not support non-writable tensors. This means you can write to the underlying (supposedly non-writable) buffer using the tensor. You may want to copy the buffer to protect its data or make it writable before converting it to a tensor. This type of warning will be suppressed for the rest of this program. (Triggered internally at /opt/conda/conda-bld/pytorch_1720538440907/work/torch/csrc/utils/tensor_new.cpp:1544.)
Result
The result looks like below.
Video(get_path("example.mp4"), embed=True)
Carefully watching the video, it can be observed that the sound of “s” (curiosity, besides, this) has more energy allocated on higher frequency side (right side of the video).
Tag: torchaudio.io
Total running time of the script: ( 0 minutes 7.427 seconds)
Gallery generated by Sphinx-Gallery
文档
访问 PyTorch 的全面开发人员文档
查看文档
教程
获取面向初学者和高级开发人员的深入教程
查看教程
资源
查找开发资源并解答您的问题
查看资源
APP信息
