目录
ASR Inference with CUDA CTC Decoder
Author: Yuekai Zhang
This tutorial shows how to perform speech recognition inference using a CUDA-based CTC beam search decoder. We demonstrate this on a pretrained Zipformer model from Next-gen Kaldi project.
Overview
Beam search decoding works by iteratively expanding text hypotheses (beams) with next possible characters, and maintaining only the hypotheses with the highest scores at each time step.
The underlying implementation uses cuda to acclerate the whole decoding process
A mathematical formula for the decoder can be
found in the paper, and a more detailed algorithm can be found in this blog.
Running ASR inference using a CUDA CTC Beam Search decoder requires the following components
  • Acoustic Model: model predicting modeling units (BPE in this tutorial) from acoustic features
  • BPE Model: the byte-pair encoding (BPE) tokenizer file
Acoustic Model and Set Up
First we import the necessary utilities and fetch the data that we are working with
import torch
import torchaudio
print(torch.__version__)
print(torchaudio.__version__)
2.4.0
2.4.0
import time
from pathlib import Path
import IPython
import sentencepiece as spm
from torchaudio.models.decoder import cuda_ctc_decoder
from torchaudio.utils import download_asset
We use the pretrained Zipformer model that is trained on the LibriSpeech dataset. The model is jointly trained with CTC and Transducer loss functions. In this tutorial, we only use CTC head of the model.
def download_asset_external(url, key):
    path = Path(torch.hub.get_dir()) / "torchaudio" / Path(key)
    if not path.exists():
        path.parent.mkdir(parents=True, exist_ok=True)
        torch.hub.download_url_to_file(url, path)
    return str(path)
url_prefix = "https://huggingface.co/Zengwei/icefall-asr-librispeech-pruned-transducer-stateless7-ctc-2022-12-01"
model_link = f"{url_prefix}/resolve/main/exp/cpu_jit.pt"
model_path = download_asset_external(model_link, "cuda_ctc_decoder/cpu_jit.pt")
  0%|          | 0.00/269M [00:00<?, ?B/s]
  8%|7         | 21.1M/269M [00:00<00:01, 221MB/s]
 16%|#5        | 42.2M/269M [00:00<00:03, 69.8MB/s]
 20%|#9        | 53.6M/269M [00:00<00:04, 48.1MB/s]
 25%|##5       | 67.8M/269M [00:01<00:03, 60.4MB/s]
 28%|##8       | 76.5M/269M [00:01<00:04, 42.8MB/s]
 33%|###2      | 87.8M/269M [00:01<00:03, 51.7MB/s]
 37%|###7      | 100M/269M [00:02<00:03, 45.6MB/s]
 39%|###9      | 106M/269M [00:02<00:03, 44.3MB/s]
 46%|####6     | 124M/269M [00:02<00:02, 62.0MB/s]
 49%|####8     | 132M/269M [00:02<00:02, 53.7MB/s]
 56%|#####5    | 150M/269M [00:02<00:02, 55.8MB/s]
 65%|######4   | 174M/269M [00:02<00:01, 84.8MB/s]
 69%|######8   | 186M/269M [00:03<00:01, 48.5MB/s]
 74%|#######4  | 200M/269M [00:03<00:01, 47.3MB/s]
 79%|#######9  | 213M/269M [00:04<00:01, 54.1MB/s]
 83%|########3 | 224M/269M [00:04<00:00, 58.2MB/s]
 86%|########5 | 232M/269M [00:04<00:00, 49.1MB/s]
 93%|#########2| 250M/269M [00:04<00:00, 60.6MB/s]
 98%|#########7| 263M/269M [00:04<00:00, 70.4MB/s]
100%|##########| 269M/269M [00:04<00:00, 58.2MB/s]
We will load a sample from the LibriSpeech test-other dataset.
speech_file = download_asset("tutorial-assets/ctc-decoding/1688-142285-0007.wav")
waveform, sample_rate = torchaudio.load(speech_file)
assert sample_rate == 16000
IPython.display.Audio(speech_file)
  0%|          | 0.00/441k [00:00<?, ?B/s]
100%|##########| 441k/441k [00:00<00:00, 191MB/s]
The transcript corresponding to this audio file is
i really was very much afraid of showing him how much shocked i was at some parts of what he said
Files and Data for Decoder
Next, we load in our token from BPE model, which is the tokenizer for decoding.
Tokens
The tokens are the possible symbols that the acoustic model can predict, including the blank symbol in CTC. In this tutorial, it includes 500 BPE tokens. It can either be passed in as a file, where each line consists of the tokens corresponding to the same index, or as a list of tokens, each mapping to a unique index.
# tokens
<blk>
<sos/eos>
<unk>
S
_THE
_A
T
_AND
bpe_link = f"{url_prefix}/resolve/main/data/lang_bpe_500/bpe.model"
bpe_path = download_asset_external(bpe_link, "cuda_ctc_decoder/bpe.model")
bpe_model = spm.SentencePieceProcessor()
bpe_model.load(bpe_path)
tokens = [bpe_model.id_to_piece(id) for id in range(bpe_model.get_piece_size())]
print(tokens)
  0%|          | 0.00/239k [00:00<?, ?B/s]
100%|##########| 239k/239k [00:00<00:00, 50.9MB/s]
['<blk>', '<sos/eos>', '<unk>', 'S', '▁THE', '▁A', 'T', '▁AND', 'ED', '▁OF', '▁TO', 'E', 'D', 'N', 'ING', '▁IN', 'Y', 'M', 'C', '▁I', 'A', 'P', '▁HE', 'R', 'O', 'L', 'RE', 'I', 'U', 'ER', '▁IT', 'LY', '▁THAT', '▁WAS', '▁', '▁S', 'AR', '▁BE', 'F', '▁C', 'IN', 'B', '▁FOR', 'OR', 'LE', "'", '▁HIS', '▁YOU', 'AL', '▁RE', 'V', '▁B', 'G', 'RI', '▁E', '▁WITH', '▁T', '▁AS', 'LL', '▁P', '▁HER', 'ST', '▁HAD', '▁SO', '▁F', 'W', 'CE', '▁IS', 'ND', '▁NOT', 'TH', '▁BUT', 'EN', '▁SHE', '▁ON', 'VE', 'ON', 'SE', '▁DE', 'UR', '▁G', 'CH', 'K', 'TER', '▁AT', 'IT', '▁ME', 'RO', 'NE', 'RA', 'ES', 'IL', 'NG', 'IC', '▁NO', '▁HIM', 'ENT', 'IR', '▁WE', 'H', '▁DO', '▁ALL', '▁HAVE', 'LO', '▁BY', '▁MY', '▁MO', '▁THIS', 'LA', '▁ST', '▁WHICH', '▁CON', '▁THEY', 'CK', 'TE', '▁SAID', '▁FROM', '▁GO', '▁WHO', '▁TH', '▁OR', '▁D', '▁W', 'VER', 'LI', '▁SE', '▁ONE', '▁CA', '▁AN', '▁LA', '▁WERE', 'EL', '▁HA', '▁MAN', '▁FA', '▁EX', 'AD', '▁SU', 'RY', '▁MI', 'AT', '▁BO', '▁WHEN', 'AN', 'THER', 'PP', 'ATION', '▁FI', '▁WOULD', '▁PRO', 'OW', 'ET', '▁O', '▁THERE', '▁HO', 'ION', '▁WHAT', '▁FE', '▁PA', 'US', 'MENT', '▁MA', 'UT', '▁OUT', '▁THEIR', '▁IF', '▁LI', '▁K', '▁WILL', '▁ARE', 'ID', '▁RO', 'DE', 'TION', '▁WA', 'PE', '▁UP', '▁SP', '▁PO', 'IGHT', '▁UN', 'RU', '▁LO', 'AS', 'OL', '▁LE', '▁BEEN', '▁SH', '▁RA', '▁SEE', 'KE', 'UL', 'TED', '▁SA', 'UN', 'UND', 'ANT', '▁NE', 'IS', '▁THEM', 'CI', 'GE', '▁COULD', '▁DIS', 'OM', 'ISH', 'HE', 'EST', '▁SOME', 'ENCE', 'ITY', 'IVE', '▁US', '▁MORE', '▁EN', 'ARD', 'ATE', '▁YOUR', '▁INTO', '▁KNOW', '▁CO', 'ANCE', '▁TIME', '▁WI', '▁YE', 'AGE', '▁NOW', 'TI', 'FF', 'ABLE', '▁VERY', '▁LIKE', 'AM', 'HI', 'Z', '▁OTHER', '▁THAN', '▁LITTLE', '▁DID', '▁LOOK', 'TY', 'ERS', '▁CAN', '▁CHA', '▁AR', 'X', 'FUL', 'UGH', '▁BA', '▁DAY', '▁ABOUT', 'TEN', 'IM', '▁ANY', '▁PRE', '▁OVER', 'IES', 'NESS', 'ME', 'BLE', '▁M', 'ROW', '▁HAS', '▁GREAT', '▁VI', 'TA', '▁AFTER', 'PER', '▁AGAIN', 'HO', 'SH', '▁UPON', '▁DI', '▁HAND', '▁COM', 'IST', 'TURE', '▁STA', '▁THEN', '▁SHOULD', '▁GA', 'OUS', 'OUR', '▁WELL', '▁ONLY', 'MAN', '▁GOOD', '▁TWO', '▁MAR', '▁SAY', '▁HU', 'TING', '▁OUR', 'RESS', '▁DOWN', 'IOUS', '▁BEFORE', '▁DA', '▁NA', 'QUI', '▁MADE', '▁EVERY', '▁OLD', '▁EVEN', 'IG', '▁COME', '▁GRA', '▁RI', '▁LONG', 'OT', 'SIDE', 'WARD', '▁FO', '▁WHERE', 'MO', 'LESS', '▁SC', '▁MUST', '▁NEVER', '▁HOW', '▁CAME', '▁SUCH', '▁RU', '▁TAKE', '▁WO', '▁CAR', 'UM', 'AK', '▁THINK', '▁MUCH', '▁MISTER', '▁MAY', '▁JO', '▁WAY', '▁COMP', '▁THOUGHT', '▁STO', '▁MEN', '▁BACK', '▁DON', 'J', '▁LET', '▁TRA', '▁FIRST', '▁JUST', '▁VA', '▁OWN', '▁PLA', '▁MAKE', 'ATED', '▁HIMSELF', '▁WENT', '▁PI', 'GG', 'RING', '▁DU', '▁MIGHT', '▁PART', '▁GIVE', '▁IMP', '▁BU', '▁PER', '▁PLACE', '▁HOUSE', '▁THROUGH', 'IAN', '▁SW', '▁UNDER', 'QUE', '▁AWAY', '▁LOVE', 'QUA', '▁LIFE', '▁GET', '▁WITHOUT', '▁PASS', '▁TURN', 'IGN', '▁HEAD', '▁MOST', '▁THOSE', '▁SHALL', '▁EYES', '▁COL', '▁STILL', '▁NIGHT', '▁NOTHING', 'ITION', 'HA', '▁TELL', '▁WORK', '▁LAST', '▁NEW', '▁FACE', '▁HI', '▁WORD', '▁FOUND', '▁COUNT', '▁OB', '▁WHILE', '▁SHA', '▁MEAN', '▁SAW', '▁PEOPLE', '▁FRIEND', '▁THREE', '▁ROOM', '▁SAME', '▁THOUGH', '▁RIGHT', '▁CHILD', '▁FATHER', '▁ANOTHER', '▁HEART', '▁WANT', '▁TOOK', 'OOK', '▁LIGHT', '▁MISSUS', '▁OPEN', '▁JU', '▁ASKED', 'PORT', '▁LEFT', '▁JA', '▁WORLD', '▁HOME', '▁WHY', '▁ALWAYS', '▁ANSWER', '▁SEEMED', '▁SOMETHING', '▁GIRL', '▁BECAUSE', '▁NAME', '▁TOLD', '▁NI', '▁HIGH', 'IZE', '▁WOMAN', '▁FOLLOW', '▁RETURN', '▁KNEW', '▁EACH', '▁KIND', '▁JE', '▁ACT', '▁LU', '▁CERTAIN', '▁YEARS', '▁QUITE', '▁APPEAR', '▁BETTER', '▁HALF', '▁PRESENT', '▁PRINCE', 'SHIP', '▁ALSO', '▁BEGAN', '▁HAVING', '▁ENOUGH', '▁PERSON', '▁LADY', '▁WHITE', '▁COURSE', '▁VOICE', '▁SPEAK', '▁POWER', '▁MORNING', '▁BETWEEN', '▁AMONG', '▁KEEP', '▁WALK', '▁MATTER', '▁TEA', '▁BELIEVE', '▁SMALL', '▁TALK', '▁FELT', '▁HORSE', '▁MYSELF', '▁SIX', '▁HOWEVER', '▁FULL', '▁HERSELF', '▁POINT', '▁STOOD', '▁HUNDRED', '▁ALMOST', '▁SINCE', '▁LARGE', '▁LEAVE', '▁PERHAPS', '▁DARK', '▁SUDDEN', '▁REPLIED', '▁ANYTHING', '▁WONDER', '▁UNTIL', 'Q']
Construct CUDA Decoder
In this tutorial, we will construct a CUDA beam search decoder. The decoder can be constructed using the factory function cuda_ctc_decoder().
cuda_decoder = cuda_ctc_decoder(tokens, nbest=10, beam_size=10, blank_skip_threshold=0.95)
Run Inference
Now that we have the data, acoustic model, and decoder, we can perform inference. The output of the beam search decoder is of type CUCTCHypothesis, consisting of the predicted token IDs, words (symbols corresponding to the token IDs), and hypothesis scores. Recall the transcript corresponding to the waveform is
actual_transcript = "i really was very much afraid of showing him how much shocked i was at some parts of what he said"
actual_transcript = actual_transcript.split()
device = torch.device("cuda", 0)
acoustic_model = torch.jit.load(model_path)
acoustic_model.to(device)
acoustic_model.eval()
waveform = waveform.to(device)
feat = torchaudio.compliance.kaldi.fbank(waveform, num_mel_bins=80, snip_edges=False)
feat = feat.unsqueeze(0)
feat_lens = torch.tensor(feat.size(1), device=device).unsqueeze(0)
encoder_out, encoder_out_lens = acoustic_model.encoder(feat, feat_lens)
nnet_output = acoustic_model.ctc_output(encoder_out)
log_prob = torch.nn.functional.log_softmax(nnet_output, -1)
print(f"The shape of log_prob: {log_prob.shape}, the shape of encoder_out_lens: {encoder_out_lens.shape}")
The shape of log_prob: torch.Size([1, 175, 500]), the shape of encoder_out_lens: torch.Size([1])
The cuda ctc decoder gives the following result.
results = cuda_decoder(log_prob, encoder_out_lens.to(torch.int32))
beam_search_transcript = bpe_model.decode(results[0][0].tokens).lower()
beam_search_wer = torchaudio.functional.edit_distance(actual_transcript, beam_search_transcript.split()) / len(
    actual_transcript
print(f"Transcript: {beam_search_transcript}")
print(f"WER: {beam_search_wer}")
Transcript: i really was very much afraid of showing him how much shocked i was at some parts of what he said
WER: 0.0
Beam Search Decoder Parameters
In this section, we go a little bit more in depth about some different parameters and tradeoffs. For the full list of customizable parameters, please refer to the documentation.
Helper Function
def print_decoded(cuda_decoder, bpe_model, log_prob, encoder_out_lens, param, param_value):
    start_time = time.monotonic()
    decode_time = time.monotonic() - start_time
    score = results[0][0].score
    print(f"{param} {param_value:<3}: {transcript} (score: {score:.2f}; {decode_time:.4f} secs)")
nbest
This parameter indicates the number of best hypotheses to return. For instance, by setting nbest=10 when constructing the beam search decoder earlier, we can now access the hypotheses with the top 10 scores.
for i in range(10):
    transcript = bpe_model.decode(results[0][i].tokens).lower()
    score = results[0][i].score
    print(f"{transcript} (score: {score})")
i really was very much afraid of showing him how much shocked i was at some parts of what he said (score: -0.20280733704566956)
i really was very much afraid of showing him how much shocked i was at some part of what he said (score: -1.7408883571624756)
i really was very much afraid of sheowing him how much shocked i was at some parts of what he said (score: -6.67951774597168)
i reallyly very much afraid of showing him how much shocked i was at some parts of what he said (score: -7.597038745880127)
i really was very much afraid of sheowing him how much shocked i was at some part of what he said (score: -8.224080085754395)
i really was very much afraid of shwing him how much shocked i was at some parts of what he said (score: -8.439373970031738)
i really was very much afraid of showing him how much shocked i was in some parts of what he said (score: -8.781461715698242)
i really was very much afraid of showing him how much shocked i was at some parts of what said (score: -8.883706092834473)
i really was very much afraid of showing him how much shocked i was at some partes of what he said (score: -8.999059677124023)
i really was very much afraid of showing him how much shocked i was at some parts of what he say (score: -9.138861656188965)
beam size
The beam_size parameter determines the maximum number of best hypotheses to hold after each decoding step. Using larger beam sizes allows for exploring a larger range of possible hypotheses which can produce hypotheses with higher scores, but it does not provide additional gains beyond a certain point. We recommend to set beam_size=10 for cuda beam search decoder.
In the example below, we see improvement in decoding quality as we increase beam size from 1 to 3, but notice how using a beam size of 3 provides the same output as beam size 10.
beam_sizes = [1, 2, 3, 10]
for beam_size in beam_sizes:
    beam_search_decoder = cuda_ctc_decoder(
        tokens,
        nbest=1,
        beam_size=beam_size,
        blank_skip_threshold=0.95,
    print_decoded(beam_search_decoder, bpe_model, log_prob, encoder_out_lens, "beam size", beam_size)
beam size 1  : i really was very much afraid of showing him how much shocked i was at some parts of what he said (score: -1.35; 0.0009 secs)
beam size 2  : i really was very much afraid of showing him how much shocked i was at some parts of what he said (score: -0.21; 0.0009 secs)
beam size 3  : i really was very much afraid of showing him how much shocked i was at some parts of what he said (score: -0.20; 0.0009 secs)
beam size 10 : i really was very much afraid of showing him how much shocked i was at some parts of what he said (score: -0.20; 0.0010 secs)
blank skip threshold
The blank_skip_threshold parameter is used to prune the frames which have large blank probability. Pruning these frames with a good blank_skip_threshold could speed up decoding process a lot while no accuracy drop. Since the rule of CTC, we would keep at least one blank frame between two non-blank frames to avoid mistakenly merge two consecutive identical symbols. We recommend to set blank_skip_threshold=0.95 for cuda beam search decoder.
blank_skip_probs = [0.25, 0.95, 1.0]
for blank_skip_prob in blank_skip_probs:
        tokens,
        nbest=10,
        beam_size=10,
        blank_skip_threshold=blank_skip_prob,
    print_decoded(beam_search_decoder, bpe_model, log_prob, encoder_out_lens, "blank_skip_threshold", blank_skip_prob)
del cuda_decoder
blank_skip_threshold 0.25: i really was very much afraid of showing him how much shocked i was at some part of what he said (score: -0.01; 0.0009 secs)
blank_skip_threshold 0.95: i really was very much afraid of showing him how much shocked i was at some parts of what he said (score: -0.20; 0.0010 secs)
blank_skip_threshold 1.0: i really was very much afraid of showing him how much shocked i was at some parts of what he said (score: -0.21; 0.0043 secs)
Benchmark with flashlight CPU decoder
We benchmark the throughput and accuracy between CUDA decoder and CPU decoder using librispeech test_other set. To reproduce below benchmark results, you may refer here.
Decoder
Setting
WER (%)
N-Best Oracle WER (%)
Decoder Cost Time (seconds)
CUDA decoder
5.81
4.11
2.57
CUDA decoder
blank_skip_threshold 1.0 (no frame-skip)
5.81
4.09
6.24
CPU decoder
beam_size_token 10
5.86
4.30
28.61
CPU decoder
beam_size_token 500
5.86
4.30
791.80
From the above table, CUDA decoder could give a slight improvement in WER and a significant increase in throughput.
Total running time of the script: ( 0 minutes 6.618 seconds)
Gallery generated by Sphinx-Gallery
文档
访问 PyTorch 的全面开发人员文档
查看文档
教程
获取面向初学者和高级开发人员的深入教程
查看教程
资源
查找开发资源并解答您的问题
查看资源
