目录
Audio Feature Extractions
Author: Moto Hira
torchaudio implements feature extractions commonly used in the audio domain. They are available in torchaudio.functional and torchaudio.transforms.
functional implements features as standalone functions. They are stateless.
transforms implements features as objects, using implementations from functional and torch.nn.Module. They can be serialized using TorchScript.
import torch
import torchaudio
import torchaudio.functional as F
import torchaudio.transforms as T
print(torch.__version__)
print(torchaudio.__version__)
2.0.0
2.0.1
Preparation
Note
When running this tutorial in Google Colab, install the required packages
!pip install librosa
from IPython.display import Audio
import librosa
from torchaudio.utils import download_asset
torch.random.manual_seed(0)
SAMPLE_SPEECH = download_asset("tutorial-assets/Lab41-SRI-VOiCES-src-sp0307-ch127535-sg0042.wav")
def plot_waveform(waveform, sr, title="Waveform"):
    waveform = waveform.numpy()
    num_channels, num_frames = waveform.shape
    time_axis = torch.arange(0, num_frames) / sr
    figure, axes = plt.subplots(num_channels, 1)
    axes.plot(time_axis, waveform[0], linewidth=1)
    axes.grid(True)
    figure.suptitle(title)
    plt.show(block=False)
def plot_spectrogram(specgram, title=None, ylabel="freq_bin"):
    fig, axs = plt.subplots(1, 1)
    axs.set_title(title or "Spectrogram (db)")
    axs.set_ylabel(ylabel)
    axs.set_xlabel("frame")
    im = axs.imshow(librosa.power_to_db(specgram), origin="lower", aspect="auto")
    fig.colorbar(im, ax=axs)
def plot_fbank(fbank, title=None):
    axs.set_title(title or "Filter bank")
    axs.imshow(fbank, aspect="auto")
    axs.set_ylabel("frequency bin")
    axs.set_xlabel("mel bin")
Overview of audio features
The following diagram shows the relationship between common audio features and torchaudio APIs to generate them.
https://download.pytorch.org/torchaudio/tutorial-assets/torchaudio_feature_extractions.png
For the complete list of available features, please refer to the documentation.
Spectrogram
To get the frequency make-up of an audio signal as it varies with time, you can use torchaudio.transforms.Spectrogram().
SPEECH_WAVEFORM, SAMPLE_RATE = torchaudio.load(SAMPLE_SPEECH)
plot_waveform(SPEECH_WAVEFORM, SAMPLE_RATE, title="Original waveform")
Audio(SPEECH_WAVEFORM.numpy(), rate=SAMPLE_RATE)
Original waveform
n_fft = 1024
win_length = None
hop_length = 512
# Define transform
spectrogram = T.Spectrogram(
    n_fft=n_fft,
    win_length=win_length,
    hop_length=hop_length,
    center=True,
    pad_mode="reflect",
    power=2.0,
# Perform transform
spec = spectrogram(SPEECH_WAVEFORM)
plot_spectrogram(spec[0], title="torchaudio")
torchaudio
GriffinLim
To recover a waveform from a spectrogram, you can use GriffinLim.
n_fft = 1024
win_length = None
hop_length = 512
spec = T.Spectrogram(
    n_fft=n_fft,
)(SPEECH_WAVEFORM)
griffin_lim = T.GriffinLim(
    n_fft=n_fft,
plot_waveform(reconstructed_waveform, SAMPLE_RATE, title="Reconstructed")
Audio(reconstructed_waveform, rate=SAMPLE_RATE)
Reconstructed
Mel Filter Bank
torchaudio.functional.melscale_fbanks() generates the filter bank for converting frequency bins to mel-scale bins.
Since this function does not require input audio/features, there is no equivalent transform in torchaudio.transforms().
n_fft = 256
n_mels = 64
sample_rate = 6000
mel_filters = F.melscale_fbanks(
    int(n_fft // 2 + 1),
    n_mels=n_mels,
    f_min=0.0,
    f_max=sample_rate / 2.0,
    sample_rate=sample_rate,
    norm="slaney",
plot_fbank(mel_filters, "Mel Filter Bank - torchaudio")
Comparison against librosa
For reference, here is the equivalent way to get the mel filter bank with librosa.
mel_filters_librosa = librosa.filters.mel(
    sr=sample_rate,
    n_fft=n_fft,
    n_mels=n_mels,
    fmin=0.0,
    fmax=sample_rate / 2.0,
    norm="slaney",
    htk=True,
).T
plot_fbank(mel_filters_librosa, "Mel Filter Bank - librosa")
mse = torch.square(mel_filters - mel_filters_librosa).mean().item()
print("Mean Square Difference: ", mse)
Mean Square Difference:  3.934872696751886e-17
MelSpectrogram
Generating a mel-scale spectrogram involves generating a spectrogram and performing mel-scale conversion. In torchaudio, torchaudio.transforms.MelSpectrogram() provides this functionality.
n_fft = 1024
win_length = None
hop_length = 512
n_mels = 128
mel_spectrogram = T.MelSpectrogram(
    n_fft=n_fft,
    center=True,
    pad_mode="reflect",
    power=2.0,
    norm="slaney",
    onesided=True,
    n_mels=n_mels,
    mel_scale="htk",
melspec = mel_spectrogram(SPEECH_WAVEFORM)
/usr/local/envs/python3.8/lib/python3.8/site-packages/torchaudio/transforms/_transforms.py:611: UserWarning: Argument 'onesided' has been deprecated and has no influence on the behavior of this module.
  warnings.warn(
plot_spectrogram(melspec[0], title="MelSpectrogram - torchaudio", ylabel="mel freq")
For reference, here is the equivalent means of generating mel-scale spectrograms with librosa.
melspec_librosa = librosa.feature.melspectrogram(
    y=SPEECH_WAVEFORM.numpy()[0],
    sr=sample_rate,
    n_fft=n_fft,
    center=True,
    pad_mode="reflect",
    power=2.0,
    n_mels=n_mels,
    norm="slaney",
    htk=True,
plot_spectrogram(melspec_librosa, title="MelSpectrogram - librosa", ylabel="mel freq")
mse = torch.square(melspec - melspec_librosa).mean().item()
Mean Square Difference:  1.2913579094941952e-09
MFCC
n_fft = 2048
win_length = None
hop_length = 512
n_mels = 256
n_mfcc = 256
mfcc_transform = T.MFCC(
    n_mfcc=n_mfcc,
    melkwargs={
        "n_fft": n_fft,
        "n_mels": n_mels,
        "hop_length": hop_length,
        "mel_scale": "htk",
mfcc = mfcc_transform(SPEECH_WAVEFORM)
plot_spectrogram(mfcc[0])
Spectrogram (db)
melspec = librosa.feature.melspectrogram(
    sr=sample_rate,
    n_fft=n_fft,
    n_mels=n_mels,
    htk=True,
    norm=None,
mfcc_librosa = librosa.feature.mfcc(
    S=librosa.core.spectrum.power_to_db(melspec),
    n_mfcc=n_mfcc,
    dct_type=2,
    norm="ortho",
plot_spectrogram(mfcc_librosa)
mse = torch.square(mfcc - mfcc_librosa).mean().item()
Spectrogram (db)
Mean Square Difference:  0.8103961944580078
LFCC
n_fft = 2048
win_length = None
hop_length = 512
n_lfcc = 256
lfcc_transform = T.LFCC(
    n_lfcc=n_lfcc,
    speckwargs={
        "n_fft": n_fft,
        "win_length": win_length,
lfcc = lfcc_transform(SPEECH_WAVEFORM)
plot_spectrogram(lfcc[0])
Spectrogram (db)
Pitch
pitch = F.detect_pitch_frequency(SPEECH_WAVEFORM, SAMPLE_RATE)
def plot_pitch(waveform, sr, pitch):
    figure, axis = plt.subplots(1, 1)
    axis.set_title("Pitch Feature")
    axis.grid(True)
    end_time = waveform.shape[1] / sr
    time_axis = torch.linspace(0, end_time, waveform.shape[1])
    axis.plot(time_axis, waveform[0], linewidth=1, color="gray", alpha=0.3)
    axis2 = axis.twinx()
    time_axis = torch.linspace(0, end_time, pitch.shape[1])
    axis2.plot(time_axis, pitch[0], linewidth=2, label="Pitch", color="green")
    axis2.legend(loc=0)
plot_pitch(SPEECH_WAVEFORM, SAMPLE_RATE, pitch)
Pitch Feature
Kaldi Pitch (beta)
Kaldi Pitch feature [1] is a pitch detection mechanism tuned for automatic speech recognition (ASR) applications. This is a beta feature in torchaudio, and it is available as torchaudio.functional.compute_kaldi_pitch().
  1. A pitch extraction algorithm tuned for automatic speech recognition
    Ghahremani, B. BabaAli, D. Povey, K. Riedhammer, J. Trmal and S. Khudanpur
    2014 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), Florence, 2014, pp. 2494-2498, doi: 10.1109/ICASSP.2014.6854049. [abstract], [paper]
pitch_feature = F.compute_kaldi_pitch(SPEECH_WAVEFORM, SAMPLE_RATE)
pitch, nfcc = pitch_feature[..., 0], pitch_feature[..., 1]
def plot_kaldi_pitch(waveform, sr, pitch, nfcc):
    _, axis = plt.subplots(1, 1)
    axis.set_title("Kaldi Pitch Feature")
    axis.grid(True)
    ln1 = axis.plot(time_axis, pitch[0], linewidth=2, label="Pitch", color="green")
    axis.set_ylim((-1.3, 1.3))
    time_axis = torch.linspace(0, end_time, nfcc.shape[1])
    ln2 = axis2.plot(time_axis, nfcc[0], linewidth=2, label="NFCC", color="blue", linestyle="--")
    lns = ln1 + ln2
    labels = [l.get_label() for l in lns]
    axis.legend(lns, labels, loc=0)
plot_kaldi_pitch(SPEECH_WAVEFORM, SAMPLE_RATE, pitch, nfcc)
Kaldi Pitch Feature
Total running time of the script: ( 0 minutes 11.902 seconds)
Gallery generated by Sphinx-Gallery
文档
访问 PyTorch 的全面开发人员文档
查看文档
教程
获取面向初学者和高级开发人员的深入教程
查看教程
资源
查找开发资源并解答您的问题
查看资源
