目录
GPU video decoder/encoder
Author: Moto Hira
This tutorial shows how to use NVIDIA’s hardware video decoder (NVDEC) and encoder (NVENC) with TorchAudio.
Using hardware encoder/decoder improves the speed of loading and saving certain types of videos.
Using them in TorchAduio requires FFmpeg built with NVENC/NVDEC support. Google Colab has such FFmpeg pre-installed, so you can run this tutorial on Google Colab.
If you want to enable GPU decoding/encoding, please refer to Enabling GPU video decoder/encoder.
Update PyTorch and TorchAudio with nightly builds
Until PyTorch 2.0 is released, we need to use the nightly builds of PyTorch and TorchAudio.
[2]:
%%bash
pip uninstall -y -q torch torchaudio torchvision torchtext
pip install --progress-bar off --pre torch torchaudio --extra-index-url https://download.pytorch.org/whl/nightly/cu117 2> /dev/null
Looking in indexes: https://pypi.org/simple, https://us-python.pkg.dev/colab-wheels/public/simple/, https://download.pytorch.org/whl/nightly/cu117
Collecting torch
  Downloading https://download.pytorch.org/whl/nightly/cu117/torch-2.0.0.dev20230209%2Bcu117-cp38-cp38-linux_x86_64.whl (1837.7 MB)
Collecting torchaudio
  Downloading https://download.pytorch.org/whl/nightly/cu117/torchaudio-2.0.0.dev20230208%2Bcu117-cp38-cp38-linux_x86_64.whl (4.4 MB)
Requirement already satisfied: filelock in /usr/local/lib/python3.8/dist-packages (from torch) (3.9.0)
Collecting pytorch-triton==2.0.0+0d7e753227
  Downloading https://download.pytorch.org/whl/nightly/pytorch_triton-2.0.0%2B0d7e753227-cp38-cp38-linux_x86_64.whl (18.7 MB)
Requirement already satisfied: typing-extensions in /usr/local/lib/python3.8/dist-packages (from torch) (4.4.0)
Requirement already satisfied: networkx in /usr/local/lib/python3.8/dist-packages (from torch) (3.0)
Requirement already satisfied: sympy in /usr/local/lib/python3.8/dist-packages (from torch) (1.7.1)
Requirement already satisfied: cmake in /usr/local/lib/python3.8/dist-packages (from pytorch-triton==2.0.0+0d7e753227->torch) (3.22.6)
Requirement already satisfied: mpmath>=0.19 in /usr/local/lib/python3.8/dist-packages (from sympy->torch) (1.2.1)
Installing collected packages: pytorch-triton, torch, torchaudio
Successfully installed pytorch-triton-2.0.0+0d7e753227 torch-2.0.0.dev20230209+cu117 torchaudio-2.0.0.dev20230208+cu117
Install third party libraries and download assets
[8]:
%%bash
pip3 install --progress-bar off boto3 2> /dev/null
Collecting boto3
  Downloading boto3-1.26.67-py3-none-any.whl (132 kB)
Collecting botocore<1.30.0,>=1.29.67
  Downloading botocore-1.29.67-py3-none-any.whl (10.4 MB)
Collecting jmespath<2.0.0,>=0.7.1
  Downloading jmespath-1.0.1-py3-none-any.whl (20 kB)
Collecting s3transfer<0.7.0,>=0.6.0
  Downloading s3transfer-0.6.0-py3-none-any.whl (79 kB)
Requirement already satisfied: python-dateutil<3.0.0,>=2.1 in /usr/local/lib/python3.8/dist-packages (from botocore<1.30.0,>=1.29.67->boto3) (2.8.2)
Collecting urllib3<1.27,>=1.25.4
  Downloading urllib3-1.26.14-py2.py3-none-any.whl (140 kB)
Requirement already satisfied: six>=1.5 in /usr/local/lib/python3.8/dist-packages (from python-dateutil<3.0.0,>=2.1->botocore<1.30.0,>=1.29.67->boto3) (1.15.0)
Installing collected packages: urllib3, jmespath, botocore, s3transfer, boto3
  Attempting uninstall: urllib3
    Found existing installation: urllib3 1.24.3
    Uninstalling urllib3-1.24.3:
      Successfully uninstalled urllib3-1.24.3
Successfully installed boto3-1.26.67 botocore-1.29.67 jmespath-1.0.1 s3transfer-0.6.0 urllib3-1.26.14
[10]:
%%bash
wget -q -O input.mp4 "https://download.pytorch.org/torchaudio/tutorial-assets/stream-api/NASAs_Most_Scientifically_Complex_Space_Observatory_Requires_Precision-MP4_small.mp4"
Check the available GPU
[1]:
%%bash
nvidia-smi
Thu Feb  9 15:54:05 2023
| NVIDIA-SMI 510.47.03    Driver Version: 510.47.03    CUDA Version: 11.6     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  Tesla T4            Off  | 00000000:00:04.0 Off |                    0 |
| N/A   58C    P0    28W /  70W |      0MiB / 15360MiB |      0%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|  No running processes found                                                 |
Check FFmpeg installation
Let’s do a quick sanity check to confirm that the FFmpeg we built works.
[55]:
%%bash
ffmpeg -hide_banner -decoders | grep -i cuvid
 V..... h264_cuvid           Nvidia CUVID H264 decoder (codec h264)
 V..... hevc_cuvid           Nvidia CUVID HEVC decoder (codec hevc)
 V..... mjpeg_cuvid          Nvidia CUVID MJPEG decoder (codec mjpeg)
 V..... mpeg1_cuvid          Nvidia CUVID MPEG1VIDEO decoder (codec mpeg1video)
 V..... mpeg2_cuvid          Nvidia CUVID MPEG2VIDEO decoder (codec mpeg2video)
 V..... mpeg4_cuvid          Nvidia CUVID MPEG4 decoder (codec mpeg4)
 V..... vc1_cuvid            Nvidia CUVID VC1 decoder (codec vc1)
 V..... vp8_cuvid            Nvidia CUVID VP8 decoder (codec vp8)
 V..... vp9_cuvid            Nvidia CUVID VP9 decoder (codec vp9)
[56]:
%%bash
ffmpeg -hide_banner -encoders | grep -i nvenc
 V..... h264_nvenc           NVIDIA NVENC H.264 encoder (codec h264)
 V..... nvenc                NVIDIA NVENC H.264 encoder (codec h264)
 V..... nvenc_h264           NVIDIA NVENC H.264 encoder (codec h264)
 V..... nvenc_hevc           NVIDIA NVENC hevc encoder (codec hevc)
 V..... hevc_nvenc           NVIDIA NVENC hevc encoder (codec hevc)
The following command fetches video from remote server, decode with NVDEC (cuvid) and re-encode with NVENC. If this command does not work, then there is an issue with FFmpeg installation, and TorchAudio would not be able to use them either.
[5]:
%%bash
ffmpeg -hide_banner -y -vsync 0 -hwaccel cuvid -hwaccel_output_format cuda -c:v h264_cuvid -resize 360x240 -i "https://download.pytorch.org/torchaudio/tutorial-assets/stream-api/NASAs_Most_Scientifically_Complex_Space_Observatory_Requires_Precision-MP4_small.mp4" -c:a copy -c:v h264_nvenc -b:v 5M test.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'https://download.pytorch.org/torchaudio/tutorial-assets/stream-api/NASAs_Most_Scientifically_Complex_Space_Observatory_Requires_Precision-MP4_small.mp4':
  Metadata:
    major_brand     : mp42
    minor_version   : 512
    compatible_brands: mp42iso2avc1mp41
    encoder         : Lavf58.76.100
  Duration: 00:03:26.04, start: 0.000000, bitrate: 1294 kb/s
    Stream #0:0(eng): Video: h264 (High) (avc1 / 0x31637661), yuv420p(tv, bt709), 960x540 [SAR 1:1 DAR 16:9], 1156 kb/s, 29.97 fps, 29.97 tbr, 30k tbn, 59.94 tbc (default)
    Metadata:
      handler_name    : ?Mainconcept Video Media Handler
    Stream #0:1(eng): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 128 kb/s (default)
    Metadata:
      handler_name    : #Mainconcept MP4 Sound Media Handler
Stream mapping:
  Stream #0:0 -> #0:0 (h264 (h264_cuvid) -> h264 (h264_nvenc))
  Stream #0:1 -> #0:1 (copy)
Press [q] to stop, [?] for help
Output #0, mp4, to 'test.mp4':
  Metadata:
    major_brand     : mp42
    minor_version   : 512
    encoder         : Lavf58.29.100
    Stream #0:0(eng): Video: h264 (h264_nvenc) (Main) (avc1 / 0x31637661), cuda, 360x240 [SAR 1:1 DAR 3:2], q=-1--1, 5000 kb/s, 29.97 fps, 30k tbn, 29.97 tbc (default)
    Metadata:
      encoder         : Lavc58.54.100 h264_nvenc
    Side data:
      cpb: bitrate max/min/avg: 0/0/5000000 buffer size: 10000000 vbv_delay: -1
    Metadata:
frame= 6175 fps=1673 q=8.0 Lsize=   41278kB time=00:03:26.17 bitrate=1640.1kbits/s speed=55.9x
video:37869kB audio:3234kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.424815%
Check the TorchAudio / FFmpeg integration
[6]:
import torch
import torchaudio
print(torch.__version__)
print(torchaudio.__version__)
from torchaudio.io import StreamReader, StreamWriter
[61]:
from torchaudio.utils import ffmpeg_utils
print("Library versions:")
print(ffmpeg_utils.get_versions())
print("\nBuild config:")
print(ffmpeg_utils.get_build_config())
print("\nDecoders:")
print([k for k in ffmpeg_utils.get_video_decoders().keys() if "cuvid" in k])
print("\nEncoders:")
print([k for k in ffmpeg_utils.get_video_encoders().keys() if "nvenc" in k])
Library versions:
{'libavutil': (56, 31, 100), 'libavcodec': (58, 54, 100), 'libavformat': (58, 29, 100), 'libavfilter': (7, 57, 100), 'libavdevice': (58, 8, 100)}
Build config:
--prefix=/usr --extra-version=0ubuntu0.1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-nvenc --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
Decoders:
['h264_cuvid', 'hevc_cuvid', 'mjpeg_cuvid', 'mpeg1_cuvid', 'mpeg2_cuvid', 'mpeg4_cuvid', 'vc1_cuvid', 'vp8_cuvid', 'vp9_cuvid']
Encoders:
['h264_nvenc', 'nvenc', 'nvenc_h264', 'nvenc_hevc', 'hevc_nvenc']
Benchmarking GPU Encoding and Decoding
Now that FFmpeg and the resulting libraries are ready to use, we test NVDEC/NVENC with TorchAudio. For the basics of TorchAudio’s streaming APIs, please refer to Media I/O tutorials.
[7]:
import time
import pandas as pd
pd.set_option('display.max_rows', None)
pd.set_option('display.max_columns', None)
Benchmark NVDEC with StreamReader
First we test hardware decoding, and we fetch video from multiple locations (local file, network file, AWS S3) and use NVDEC to decod them.
[9]:
import boto3
from botocore import UNSIGNED
from botocore.config import Config
print(boto3.__version__)
1.26.67
First, we define the functions we’ll use for testing.
Funcion test_decode decodes the given source from start to end, and it reports the elapsed time, and returns one image frmae as a sample.
[11]:
result = torch.zeros((4, 2))
samples = [[None, None] for _ in range(4)]
def test_decode(src, config, i_sample):
  print("=" * 40)
  print("* Configuration:", config)
  print("* Source:", src)
  print("=" * 40)
  t0 = time.monotonic()
  s = StreamReader(src)
  s.add_video_stream(5, **config)
  num_frames = 0
  for i, (chunk, ) in enumerate(s.stream()):
    if i == 0:
      print(' - Chunk:', chunk.shape, chunk.device, chunk.dtype)
    if i == i_sample:
      sample = chunk[0]
    num_frames += chunk.shape[0]
  elapsed = time.monotonic() - t0
  print()
  print(f" - Processed {num_frames} frames.")
  print(f" - Elapsed: {elapsed} seconds.")
  print()
  return elapsed, sample
Decode MP4 from local file
For the first test, we compare the time it takes for CPU and NVDEC to decode 250MB of MP4 video.
[12]:
local_src = "input.mp4"
i_sample = 520
CPU
[13]:
cpu_conf = {
    "decoder": "h264",  # CPU decoding
elapsed, sample = test_decode(local_src, cpu_conf, i_sample)
* Configuration: {'decoder': 'h264'}
* Source: input.mp4
 - Chunk: torch.Size([5, 3, 540, 960]) cpu torch.uint8
 - Processed 6175 frames.
 - Elapsed: 43.65067997 seconds.
[14]:
result[0, 0] = elapsed
samples[0][0] = sample
CUDA
[15]:
cuda_conf = {
    "decoder": "h264_cuvid",  # Use CUDA HW decoder
    "hw_accel": "cuda:0",  # Then keep the memory on CUDA:0
elapsed, sample = test_decode(local_src, cuda_conf, i_sample)
* Configuration: {'decoder': 'h264_cuvid', 'hw_accel': 'cuda:0'}
* Source: input.mp4
 - Chunk: torch.Size([5, 3, 540, 960]) cuda:0 torch.uint8
 - Elapsed: 5.754925530000008 seconds.
[16]:
result[0, 1] = elapsed
samples[0][1] = sample
Decode MP4 from network
Let’s run the same test on the source retrieved via network on-the-fly.
[17]:
network_src = "https://download.pytorch.org/torchaudio/tutorial-assets/stream-api/NASAs_Most_Scientifically_Complex_Space_Observatory_Requires_Precision-MP4_small.mp4"
i_sample = 750
CPU
[18]:
elapsed, sample = test_decode(network_src, cpu_conf, i_sample)
* Source: https://download.pytorch.org/torchaudio/tutorial-assets/stream-api/NASAs_Most_Scientifically_Complex_Space_Observatory_Requires_Precision-MP4_small.mp4
 - Elapsed: 33.74701378400002 seconds.
[19]:
result[1, 0] = elapsed
samples[1][0] = sample
CUDA
[20]:
elapsed, sample = test_decode(network_src, cuda_conf, i_sample)
 - Elapsed: 15.769149663000007 seconds.
[21]:
result[1, 1] = elapsed
samples[1][1] = sample
Decode MP4 directly from S3
Using file-like object input, we can fetch a video stored on AWS S3 and decode it without saving it on local file system.
[22]:
bucket = "pytorch"
key = "torchaudio/tutorial-assets/stream-api/NASAs_Most_Scientifically_Complex_Space_Observatory_Requires_Precision-MP4_small.mp4"
s3_client = boto3.client("s3", config=Config(signature_version=UNSIGNED))
i_sample = 115
Defining Helper class
StreamReader supports file-like objects with read method. In addition to this, if the file-like object has seek method, StreamReader attempts to use it for more reliable detection of media formats.
However, the seek method of boto3’s S3 client response object only raises errors to let users know that seek operation is not supported. Therefore we wrap it with a class that does not have seek method. This way, StreamReader won’t try to use the seek method.
Note
Due to the nature of streaming, when using file-like object without seek method, some formats are not supported. For example, MP4 formats contain metadata at the beginning of file or at the end. If metadata is located at the end, without seek method, StreamReader cannot decode streams.
[23]:
# Wrapper to hide the native `seek` method of boto3, which
# only raises an error.
class UnseekableWrapper:
  def __init__(self, obj):
    self.obj = obj
  def read(self, n):
    return self.obj.read(n)
  def __str__(self):
    return str(self.obj)
CPU
[24]:
response = s3_client.get_object(Bucket=bucket, Key=key)
src = UnseekableWrapper(response["Body"])
elapsed, sample = test_decode(src, cpu_conf, i_sample)
* Source: <botocore.response.StreamingBody object at 0x7fcc9b0b83a0>
 - Elapsed: 29.465254898000012 seconds.
[25]:
result[2, 0] = elapsed
samples[2][0] = sample
CUDA
[26]:
elapsed, sample = test_decode(src, cuda_conf, i_sample)
* Source: <botocore.response.StreamingBody object at 0x7fcc9b0b8730>
 - Elapsed: 3.475249672000018 seconds.
[27]:
result[2, 1] = elapsed
samples[2][1] = sample
Decoding and resizing
In the next test, we add preprocessing. NVDEC supports several preprocessing schemes, which are also performed on the chosen hardware. For CPU, we apply the same kind of software preprocessing through FFmpeg’s filter graph.
[28]:
i_sample = 1085
CPU
[29]:
cpu_conf = {
    "filter_desc": "scale=360:240",  # Software filter
* Configuration: {'decoder': 'h264', 'filter_desc': 'scale=360:240'}
* Source: input.mp4
 - Chunk: torch.Size([5, 3, 240, 360]) cpu torch.uint8
 - Elapsed: 17.26762169899996 seconds.
[30]:
result[3, 0] = elapsed
samples[3][0] = sample
CUDA
[31]:
cuda_conf = {
    "decoder_option": {
        "resize": "360x240",  # Then apply HW preprocessing (resize)
* Configuration: {'decoder': 'h264_cuvid', 'decoder_option': {'resize': '360x240'}, 'hw_accel': 'cuda:0'}
* Source: input.mp4
 - Chunk: torch.Size([5, 3, 240, 360]) cuda:0 torch.uint8
 - Elapsed: 15.233130482000035 seconds.
[32]:
result[3, 1] = elapsed
samples[3][1] = sample
Results
The following table summarizes the time it took to decode the same media with CPU and NVDEC. We see significant speedup with NVDEC.
[33]:
res = pd.DataFrame(
    result.numpy(),
    index=["Decoding (local file)", "Decoding (network file)", "Decoding (file-like object, S3)", "Decoding + Resize"],
    columns=["CPU", "NVDEC"],
print(res)
                                       CPU      NVDEC
Decoding (local file)            43.650681   5.754926
Decoding (network file)          33.747013  15.769150
Decoding (file-like object, S3)  29.465256   3.475250
Decoding + Resize                17.267622  15.233130
The following code shows some frames generated by CPU decoding and NVDEC. They produce seemingly identical results.
[34]:
def yuv_to_rgb(img):
  img = img.cpu().to(torch.float)
  y = img[..., 0, :, :]
  u = img[..., 1, :, :]
  v = img[..., 2, :, :]
  y /= 255
  u = u / 255 - 0.5
  v = v / 255 - 0.5
  r = y + 1.14 * v
  g = y + -0.396 * u - 0.581 * v
  b = y + 2.029 * u
  rgb = torch.stack([r, g, b], -1)
  rgb = (rgb * 255).clamp(0, 255).to(torch.uint8)
  return rgb.numpy()
[35]:
f, axs = plt.subplots(4, 2, figsize=[12.8, 19.2])
for i in range(4):
  for j in range(2):
    axs[i][j].imshow(yuv_to_rgb(samples[i][j]))
    axs[i][j].set_title(
        f"{'CPU' if j == 0 else 'NVDEC'}{' with resize' if i == 3 else ''}")
plt.plot(block=False)
[35]:
_images/hw_acceleration_tutorial_60_1.png
Benchmark NVENC with StreamWriter
Next, we benchmark encoding speed with StreamWriter and NVENC.
[36]:
def test_encode(data, dst, **config):
  print("=" * 40)
  print("* Destination:", dst)
  print("=" * 40)
  s = StreamWriter(dst)
  s.add_video_stream(**config)
  with s.open():
    s.write_video_chunk(0, data)
  print()
  print(f" - Processed {len(data)} frames.")
  print()
  return elapsed
result = torch.zeros((3, 3))
We use StreamReader to generate test data.
[37]:
def get_data(frame_rate, height, width, format, duration=15):
  src = f"testsrc2=rate={frame_rate}:size={width}x{height}:duration={duration}"
  s = StreamReader(src=src, format="lavfi")
  s.add_basic_video_stream(-1, format=format)
  s.process_all_packets()
  video, = s.pop_chunks()
  return video
Encode MP4 - 360P
For the first test, we compare the time it takes for CPU and NVENC to encode 15 seconds of video with small resolution.
[38]:
pict_config = {
    "height": 360,
    "width": 640,
    "frame_rate": 30000/1001,
    "format": "yuv444p",
video = get_data(**pict_config)
CPU
[39]:
encode_config = {
    "encoder": "libx264",
    "encoder_format": "yuv444p",
result[0, 0] = test_encode(video, "360p_cpu.mp4", **pict_config, **encode_config)
* Configuration: {'height': 360, 'width': 640, 'frame_rate': 29.97002997002997, 'format': 'yuv444p', 'encoder': 'libx264', 'encoder_format': 'yuv444p'}
* Destination: 360p_cpu.mp4
 - Processed 450 frames.
 - Elapsed: 6.311792093000008 seconds.
CUDA (from CPU Tensor)
Now we test NVENC. This time, the data is sent from CPU memory to GPU memory as part of encoding.
[40]:
encode_config = {
    "encoder": "h264_nvenc",  # Use NVENC
    "encoder_option": {"gpu": "0"},  # Run encoding on the cuda:0 device
result[1, 0] = test_encode(video, "360p_cuda.mp4", **pict_config, **encode_config)
* Configuration: {'height': 360, 'width': 640, 'frame_rate': 29.97002997002997, 'format': 'yuv444p', 'encoder': 'h264_nvenc', 'encoder_format': 'yuv444p', 'encoder_option': {'gpu': '0'}}
* Destination: 360p_cuda.mp4
 - Elapsed: 0.5352325430000064 seconds.
CUDA (from CUDA Tensor)
If the data is already present on CUDA, then we can pass it to GPU encoder directly.
[41]:
device = "cuda:0"
encode_config = {
    "encoder": "h264_nvenc",  # GPU Encoder
    "hw_accel": device,  # Data comes from cuda:0 device
result[2, 0] = test_encode(video.to(torch.device(device)), "360p_cuda_hw.mp4", **pict_config, **encode_config)
* Configuration: {'height': 360, 'width': 640, 'frame_rate': 29.97002997002997, 'format': 'yuv444p', 'encoder': 'h264_nvenc', 'encoder_format': 'yuv444p', 'encoder_option': {'gpu': '0'}, 'hw_accel': 'cuda:0'}
* Destination: 360p_cuda_hw.mp4
 - Elapsed: 0.7045466739999711 seconds.
Encode MP4 - 720P
Let’s run the same tests on video with larger resolution.
[42]:
pict_config = {
    "height": 720,
    "width": 1280,
CPU
[43]:
encode_config = {
result[0, 1] = test_encode(video, "720p_cpu.mp4", **pict_config, **encode_config)
* Configuration: {'height': 720, 'width': 1280, 'frame_rate': 29.97002997002997, 'format': 'yuv444p', 'encoder': 'libx264', 'encoder_format': 'yuv444p'}
* Destination: 720p_cpu.mp4
 - Elapsed: 14.017578084000036 seconds.
[44]:
encode_config = {
result[1, 1] = test_encode(video, "720p_cuda.mp4", **pict_config, **encode_config)
* Configuration: {'height': 720, 'width': 1280, 'frame_rate': 29.97002997002997, 'format': 'yuv444p', 'encoder': 'h264_nvenc', 'encoder_format': 'yuv444p'}
* Destination: 720p_cuda.mp4
 - Elapsed: 0.9797491379999883 seconds.
[45]:
device = "cuda:0"
encode_config = {
    "hw_accel": device,
result[2, 1] = test_encode(video.to(torch.device(device)), "720p_cuda_hw.mp4", **pict_config, **encode_config)
* Configuration: {'height': 720, 'width': 1280, 'frame_rate': 29.97002997002997, 'format': 'yuv444p', 'encoder': 'h264_nvenc', 'encoder_format': 'yuv444p', 'encoder_option': {'gpu': '0'}, 'hw_accel': 'cuda:0'}
* Destination: 720p_cuda_hw.mp4
 - Elapsed: 0.7259890020000057 seconds.
Encode MP4 - 1080P
We make the video with even larger.
[46]:
pict_config = {
    "height": 1080,
    "width": 1920,
CPU
[47]:
encode_config = {
result[0, 2] = test_encode(video, "1080p_cpu.mp4", **pict_config, **encode_config)
* Configuration: {'height': 1080, 'width': 1920, 'frame_rate': 29.97002997002997, 'format': 'yuv444p', 'encoder': 'libx264', 'encoder_format': 'yuv444p'}
* Destination: 1080p_cpu.mp4
 - Elapsed: 29.441768007999997 seconds.
[48]:
encode_config = {
result[1, 2] = test_encode(video, "1080p_cuda.mp4", **pict_config, **encode_config)
* Configuration: {'height': 1080, 'width': 1920, 'frame_rate': 29.97002997002997, 'format': 'yuv444p', 'encoder': 'h264_nvenc', 'encoder_format': 'yuv444p'}
* Destination: 1080p_cuda.mp4
 - Elapsed: 1.5768605540000067 seconds.
[49]:
device = "cuda:0"
encode_config = {
    "hw_accel": device,
result[2, 2] = test_encode(video.to(torch.device(device)), "1080p_cuda_hw.mp4", **pict_config, **encode_config)
* Configuration: {'height': 1080, 'width': 1920, 'frame_rate': 29.97002997002997, 'format': 'yuv444p', 'encoder': 'h264_nvenc', 'encoder_format': 'yuv444p', 'encoder_option': {'gpu': '0'}, 'hw_accel': 'cuda:0'}
* Destination: 1080p_cuda_hw.mp4
 - Elapsed: 1.4002963130000126 seconds.
Result
Here is the result.
[50]:
labels = ["CPU", "CUDA (from CPU Tensor)", "CUDA (from CUDA Tensor)"]
columns = ["360P", "720P", "1080P"]
res = pd.DataFrame(
    result.numpy(),
    index=labels,
    columns=columns,
print(res)
                             360P       720P      1080P
CPU                      6.311792  14.017578  29.441769
CUDA (from CPU Tensor)   0.535233   0.979749   1.576861
CUDA (from CUDA Tensor)  0.704547   0.725989   1.400296
[51]:
plt.plot(result.T)
plt.legend(labels)
plt.xticks([i for i in range(3)], columns)
plt.grid(visible=True, axis='y')
_images/hw_acceleration_tutorial_91_0.png
The resulting videos look like the following.
[52]:
from IPython.display import HTML
HTML('''
<div>
  <video width=360 controls autoplay>
    <source src="https://download.pytorch.org/torchaudio/tutorial-assets/streamwriter_360p_cpu.mp4" type="video/mp4">
  </video>
    <source src="https://download.pytorch.org/torchaudio/tutorial-assets/streamwriter_360p_cuda.mp4" type="video/mp4">
  </video>
    <source src="https://download.pytorch.org/torchaudio/tutorial-assets/streamwriter_360p_cuda_hw.mp4" type="video/mp4">
  </video>
</div>
[52]:
Conclusion
We looked at how to build FFmpeg libraries with NVDEC/NVENC support and use them from TorchAudio. NVDEC/NVENC provide significant speed up when saving/loading a video.
文档
访问 PyTorch 的全面开发人员文档
查看文档
教程
获取面向初学者和高级开发人员的深入教程
查看教程
资源
查找开发资源并解答您的问题
查看资源
