目录
Distributed
For distributed training, TorchX relies on the scheduler’s gang scheduling capabilities to schedule n copies of nodes. Once launched, the application is expected to be written in a way that leverages this topology, for instance, with PyTorch’s DDP. You can express a variety of node topologies with TorchX by specifying multiple torchx.specs.Role in your component’s AppDef. Each role maps to a homogeneous group of nodes that performs a “role” (function) in the overall training. Scheduling-wise, TorchX launches each role as a sub-gang.
A DDP-style training job has a single role: trainers. Whereas a training job that uses parameter servers will have two roles: parameter server, trainer. You can specify different entrypoint (executable), num replicas, resource requirements, and more for each role.
DDP Builtin
DDP-style trainers are common and easy to templetize since they are homogeneous single role AppDefs, so there is a builtin: dist.ddp. Assuming your DDP training script is called main.py, launch it as:
# locally, 1 node x 4 workers
$ torchx run -s local_cwd dist.ddp --entrypoint main.py --nproc_per_node 4
# locally, 2 node x 4 workers (8 total)
$ torchx run -s local_cwd dist.ddp --entrypoint main.py \
    --rdzv_backend c10d \
    --nnodes 2 \
    --nproc_per_node 4 \
# remote (needs you to setup an etcd server first!)
$ torchx run -s kubernetes -cfg queue=default dist.ddp \
    --rdzv_backend etcd \
    --rdzv_endpoint etcd-server.default.svc.cluster.local:2379 \
    --nnodes 2 \
There is a lot happening under the hood so we strongly encourage you to continue reading the rest of this section to get an understanding of how everything works. Also note that while dist.ddp is convenient, you’ll find that authoring your own distributed component is not only easy (simplest way is to just copy dist.ddp!) but also leads to better flexbility and maintainability down the road since builtin APIs are subject to more changes than the more stable specs API. However the choice is yours, feel free to rely on the builtins if they meet your needs.
Distributed Training
Local Testing
Note
Please follow Prerequisites of running examples first.
Running distributed training locally is a quick way to validate your training script. TorchX’s local scheduler will create a process per replica (--nodes). The example below uses torchelastic, as the main entrypoint of each node, which in turn spawns --nprocs_per_node number of trainers. In total you’ll see nnodes*nprocs_per_node trainer processes and nnodes elastic agent procesess created on your local host.
$ torchx run -s local_cwd ./torchx/examples/apps/lightning_classy_vision/component.py:trainer_dist \
     --nnodes 2 \
     --nproc_per_node 2 \
     --rdzv_endpoint localhost:29500
Warning
There is a known issue with local_docker (the default scheduler when no -s argument is supplied), hence we use -s local_cwd instead. Please track the progress of the fix on issue-286, issue-287.
Remote Launching
Note
Please follow the Prerequisites first.
The following example demonstrate launching the same job remotely on kubernetes.
$ torchx run -s kubernetes -cfg queue=default \
    --nnodes 2 \
torchx 2021-10-18 18:46:55 INFO     Launched app: kubernetes://torchx/default:cv-trainer-pa2a7qgee9zng
torchx 2021-10-18 18:46:55 INFO     AppStatus:
  msg: <NONE>
  num_restarts: -1
  roles: []
  state: PENDING (2)
  structured_error_msg: <NONE>
  ui_url: null
torchx 2021-10-18 18:46:55 INFO     Job URL: None
Note that the only difference compared to the local launch is the scheduler (-s) and --rdzv_backend. etcd will also work in the local case, but we used c10d since it does not require additional setup. Note that this is a torchelastic requirement not TorchX. Read more about rendezvous here.
Note
For GPU training, keep nproc_per_node equal to the amount of GPUs on the host and change the resource requirements in torchx/examples/apps/lightning_classy_vision/component.py:trainer_dist method. Modify resource_def to the number of GPUs that your host has.
Components APIs
torchx.components.dist.ddp(*script_args: str, entrypoint: str, image: str = 'ghcr.io/pytorch/torchx:0.1.0', rdzv_backend: Optional[str] = None, rdzv_endpoint: Optional[str] = None, resource: Optional[str] = None, nnodes: int = 1, nproc_per_node: int = 1, name: str = 'test-name', role: str = 'worker', env: Optional[Dict[str, str]] = None) → torchx.specs.api.AppDef[source]
Distributed data parallel style application (one role, multi-replica). Uses torch.distributed.run to launch and coordinate pytorch worker processes.
Parameters
  • script_args – Script arguments.
  • image – container image.
  • entrypoint – script or binary to run within the image.
  • rdzv_backend – rendezvous backend to use, allowed values can be found in the rdzv registry docs The default backend is c10d
  • rdzv_endpoint – Controller endpoint. In case of rdzv_backend is etcd, this is a etcd endpoint, in case of c10d, this is the endpoint of one of the hosts. The default entdpoint it localhost:29500
  • resource – Optional named resource identifier. The resource parameter gets ignored when running on the local scheduler.
  • nnodes – Number of nodes.
  • nproc_per_node – Number of processes per node.
  • name – Name of the application.
  • role – Name of the ddp role.
  • env – Env variables.
Returns
Torchx AppDef
Return type
specs.AppDef
文档
访问 PyTorch 的全面开发人员文档
查看文档
教程
获取面向初学者和高级开发人员的深入教程
查看教程
资源
查找开发资源并解答您的问题
查看资源
