App Best Practices
TorchX apps can be written using any language as well as with any set of libraries to allow for maximum flexibility. However, we do have a standard set of recommended libraries and practices to have a starting point for users and to provide consistency across the built in components and applications.
See Component Best Practices for information how to handle component management and AppDefs.
Data Passing and Storage
We recommend fsspec. fsspec allows pluggable filesystems so apps can be written once and run on most infrastructures just by changing the input and output paths.
TorchX builtin components use fsspec for all storage access to make it possible to run in new environments by using a different fsspec backend or by adding a new one.
Pytorch Lightning supports fsspec out of the box so using fsspec elsewhere makes it seamless to integrate in with your trainer.
Using remote storage also makes it easier to transition your apps to running with distributed support via libraries such as torch.distributed.elastic.
Train Loops
There are lots of ways to structure a training loop and it depends a lot on your model type and architecture which is why we don’t provide one out of the box.
Some common choices are:
Pure Pytorch
- Use a managed train loop
See Train for more information.
Metrics
For logging metrics and monitoring your job we recommend using standalone Tensorboard since it’s supported natively by Pytorch tensorboard integrations and Pytorch Lightning logging.
Since Tensorboard can log to remote storage like s3 or gcs you can view complex information about your model while it’s training.
See Metrics for more information on metric handling within TorchX.
Checkpointing
Periodic checkpoints allow your application to recover from failures and in some cases allow you to restart your trainer with different parameters without losing training progress.
Pytorch Lighting provides a standardized way to checkpoint your models to an fsspec remote path.
Fine Tuning
To support things like transfer learning, fine tuning and resuming from checkpoints we recommend having a command line argument to your app that will resume from a checkpoint file.
This will allow you to recover from transient errors, continue train on new data, or later adjust the learning rate without losing training progress.
Having load support allows for less code and better maintainability since you can have one app doing a number of similar tasks.
Interpretability
We recommend captum for model interpretability and analysing model results. This can be used interactively from a Jupyter notebook or from a component.
See Interpret for more information.
Hyper Parameter Optimization
See HPO for more information.
Model Packaging
The pytorch community hasn’t standardized on one package format. Here’s a couple of options and when you might need to use them.
Python + Saved Weights
This is the most common format for packaging models. To use you’ll load your
model definition from a python file and then you’ll load the weights and state
dict from a .ckpt
or .pt
file.
This is how Pytorch Lightning’s ModelCheckpoint hook works.
This is the most common but makes it harder to make a reusable app since your trainer app needs to include the model definition code.
TorchScript Models
TorchScript is a way to create serializable and optimized Pytorch models that can be executed without Python. This can be used for inference or training in a performant way without relying on Python’s GIL.
These model files are completely self described but not all pytorch models can be automatically converted to TorchScript.
See the TorchScript documentation.
TorchServe Model Archiver (.mar)
If you want to use TorchServe for inference you’ll need to export your model to
this format. For inference it’s common to use a quantized version of the model
so it’s best to have your trainer export both a full precision model for fine
tuning as well as a quantized .mar
file for TorchServe to consume.
See the Model Archiver documentation.
torch.package
This is a new format as of pytorch 1.9.0 and can be used to save and load model definitions and their weights so you don’t need to manage the model definition separately.
See the torch.package documentation.
It’s quite new and doesn’t have widespread adoption or support.
Serving / Inference
For serving and inference we recommend using TorchServe for common use cases. We provide a component that allows you to upload your model to TorchServe via the management API.
See the Serve built in components for more information.
For more complex serving and performance reasons you may need to write your own custom inference logic. Torchscript and torch::deploy are some standard utilities you can use to build your own inference server.
Testing
Since TorchX apps are typically standard python you can write unit tests for them like you would with any other Python code.
import unittest
from your.custom.app import main
class CustomAppTest(unittest.TestCase):
def test_main(self) -> None:
main(["--src", "src", "--dst", "dst"])
self.assertTrue(...)
