目录
torchtext.nn
MultiheadAttentionContainer
class torchtext.nn.MultiheadAttentionContainer(nhead, in_proj_container, attention_layer, out_proj, batch_first=False)[source]
__init__(nhead, in_proj_container, attention_layer, out_proj, batch_first=False)[source]
A multi-head attention container
Parameters
  • nhead – the number of heads in the multiheadattention model
  • in_proj_container – A container of multi-head in-projection linear layers (a.k.a nn.Linear).
  • attention_layer – The custom attention layer. The input sent from MHA container to the attention layer is in the shape of (…, L, N * H, E / H) for query and (…, S, N * H, E / H) for key/value while the output shape of the attention layer is expected to be (…, L, N * H, E / H). The attention_layer needs to support broadcast if users want the overall MultiheadAttentionContainer with broadcast.
  • out_proj – The multi-head out-projection layer (a.k.a nn.Linear).
  • batch_first – If True, then the input and output tensors are provided as (…, N, L, E). Default: False
Examples::
>>> import torch
>>> from torchtext.nn import MultiheadAttentionContainer, InProjContainer, ScaledDotProduct
>>> embed_dim, num_heads, bsz = 10, 5, 64
>>> in_proj_container = InProjContainer(torch.nn.Linear(embed_dim, embed_dim),
                                        torch.nn.Linear(embed_dim, embed_dim))
>>> MHA = MultiheadAttentionContainer(num_heads,
                                      in_proj_container,
                                      ScaledDotProduct(),
>>> query = torch.rand((21, bsz, embed_dim))
>>> key = value = torch.rand((16, bsz, embed_dim))
>>> attn_output, attn_weights = MHA(query, key, value)
>>> print(attn_output.shape)
>>> torch.Size([21, 64, 10])
forward(query: torch.Tensor, key: torch.Tensor, value: torch.Tensor, attn_mask: Optional[torch.Tensor] = None, bias_k: Optional[torch.Tensor] = None, bias_v: Optional[torch.Tensor] = None)Tuple[torch.Tensor, torch.Tensor][source]
Parameters
  • query (Tensor) – The query of the attention function. See “Attention Is All You Need” for more details.
  • key (Tensor) – The keys of the attention function. See “Attention Is All You Need” for more details.
  • value (Tensor) – The values of the attention function. See “Attention Is All You Need” for more details.
  • attn_mask (BoolTensor, optional) – 3D mask that prevents attention to certain positions.
  • bias_k (Tensor, optional) – one more key and value sequence to be added to keys at sequence dim (dim=-3). Those are used for incremental decoding. Users should provide bias_v.
  • bias_v (Tensor, optional) – one more key and value sequence to be added to values at sequence dim (dim=-3). Those are used for incremental decoding. Users should also provide bias_k.
Shape:
  • Inputs:
    • query: \((..., L, N, E)\)
    • key: \((..., S, N, E)\)
    • value: \((..., S, N, E)\)
    • attn_mask, bias_k and bias_v: same with the shape of the corresponding args in attention layer.
  • Outputs:
    • attn_output: \((..., L, N, E)\)
    • attn_output_weights: \((N * H, L, S)\)
Note: It’s optional to have the query/key/value inputs with more than three dimensions (for broadcast purpose). The MultiheadAttentionContainer module will operate on the last three dimensions.
where where L is the target length, S is the sequence length, H is the number of attention heads, N is the batch size, and E is the embedding dimension.
InProjContainer
class torchtext.nn.InProjContainer(query_proj, key_proj, value_proj)[source]
__init__(query_proj, key_proj, value_proj)[source]
A in-proj container to project query/key/value in MultiheadAttention. This module happens before reshaping the projected query/key/value into multiple heads. See the linear layers (bottom) of Multi-head Attention in Fig 2 of Attention Is All You Need paper. Also check the usage example in torchtext.nn.MultiheadAttentionContainer.
Parameters
  • query_proj – a proj layer for query. A typical projection layer is torch.nn.Linear.
  • key_proj – a proj layer for key. A typical projection layer is torch.nn.Linear.
  • value_proj – a proj layer for value. A typical projection layer is torch.nn.Linear.
forward(query: torch.Tensor, key: torch.Tensor, value: torch.Tensor)Tuple[torch.Tensor, torch.Tensor, torch.Tensor][source]
Projects the input sequences using in-proj layers. query/key/value are simply passed to the forward func of query/key/value_proj, respectively.
Parameters
  • query (Tensor) – The query to be projected.
  • key (Tensor) – The keys to be projected.
  • value (Tensor) – The values to be projected.
Examples::
>>> import torch
>>> from torchtext.nn import InProjContainer
>>> embed_dim, bsz = 10, 64
>>> q = torch.rand((5, bsz, embed_dim))
>>> k = v = torch.rand((6, bsz, embed_dim))
>>> q, k, v = in_proj_container(q, k, v)
ScaledDotProduct
class torchtext.nn.ScaledDotProduct(dropout=0.0, batch_first=False)[source]
__init__(dropout=0.0, batch_first=False)[source]
Processes a projected query and key-value pair to apply scaled dot product attention.
Parameters
  • dropout (float) – probability of dropping an attention weight.
  • batch_first – If True, then the input and output tensors are provided as (batch, seq, feature). Default: False
Examples::
>>> import torch, torchtext
>>> SDP = torchtext.nn.ScaledDotProduct(dropout=0.1)
>>> q = torch.randn(21, 256, 3)
>>> k = v = torch.randn(21, 256, 3)
>>> attn_output, attn_weights = SDP(q, k, v)
>>> print(attn_output.shape, attn_weights.shape)
torch.Size([21, 256, 3]) torch.Size([256, 21, 21])
Uses a scaled dot product with the projected key-value pair to update the projected query.
Parameters
  • query (Tensor) – Projected query
  • key (Tensor) – Projected key
  • value (Tensor) – Projected value
  • attn_mask – 3D mask that prevents attention to certain positions.
Shape:
  • query: \((..., L, N * H, E / H)\)
  • key: \((..., S, N * H, E / H)\)
  • value: \((..., S, N * H, E / H)\)
  • attn_mask: \((N * H, L, S)\), positions with True are not allowed to attend
    while False values will be unchanged.
  • bias_k and bias_v:bias: \((1, N * H, E / H)\)
  • Output: \((..., L, N * H, E / H)\), \((N * H, L, S)\)
The ScaledDotProduct module will operate on the last three dimensions.
where L is the target length, S is the source length, H is the number of attention heads, N is the batch size, and E is the embedding dimension.
文档
访问 PyTorch 的全面开发人员文档
查看文档
教程
获取面向初学者和高级开发人员的深入教程
查看教程
资源
查找开发资源并解答您的问题
查看资源
