目录
torchtext.data.functional
generate_sp_model
torchtext.data.functional.generate_sp_model(filename, vocab_size=20000, model_type='unigram', model_prefix='m_user')[source]
Train a SentencePiece tokenizer.
Parameters
  • filename – the data file for training SentencePiece model.
  • vocab_size – the size of vocabulary (Default: 20,000).
  • model_type – the type of SentencePiece model, including unigram, bpe, char, word.
  • model_prefix – the prefix of the files saving model and vocab.
Outputs:
The model and vocab are saved in two separate files with
model_prefix.
Examples
>>> from torchtext.data.functional import generate_sp_model
>>> generate_sp_model('test.csv', vocab_size=23456, model_prefix='spm_user')
load_sp_model
torchtext.data.functional.load_sp_model(spm)[source]
Load a sentencepiece model for file.
Parameters
spm – the file path or a file object saving the sentencepiece model.
Outputs:
output: a SentencePiece model.
Examples
>>> from torchtext.data.functional import load_sp_model
>>> sp_model = load_sp_model("m_user.model")
>>> sp_model = load_sp_model(open("m_user.model", 'rb'))
sentencepiece_numericalizer
torchtext.data.functional.sentencepiece_numericalizer(sp_model)[source]
A sentencepiece model to numericalize a text sentence into
a generator over the ids.
Parameters
sp_model – a SentencePiece model.
Outputs:
output: a generator with the input of text sentence and the output of the
corresponding ids based on SentencePiece model.
Examples
>>> from torchtext.data.functional import sentencepiece_numericalizer
>>> sp_id_generator = sentencepiece_numericalizer(sp_model)
>>> list_a = ["sentencepiece encode as pieces", "examples to   try!"]
>>> list(sp_id_generator(list_a))
    [[9858, 9249, 1629, 1305, 1809, 53, 842],
     [2347, 13, 9, 150, 37]]
sentencepiece_tokenizer
torchtext.data.functional.sentencepiece_tokenizer(sp_model)[source]
A sentencepiece model to tokenize a text sentence into
a generator over the tokens.
Parameters
Outputs:
corresponding tokens based on SentencePiece model.
Examples
>>> from torchtext.data.functional import sentencepiece_tokenizer
>>> sp_tokens_generator = sentencepiece_tokenizer(sp_model)
>>> list(sp_tokens_generator(list_a))
    [['_sentence', 'piece', '_en', 'co', 'de', '_as', '_pieces'],
     ['_example', 's', '_to', '_try', '!']]
custom_replace
torchtext.data.functional.custom_replace(replace_pattern)[source]
A transform to convert text string.
Examples
>>> from torchtext.data.functional import custom_replace
>>> custom_replace_transform = custom_replace([(r'S', 's'), (r'\s+', ' ')])
>>> list_a = ["Sentencepiece encode  aS  pieces", "exampleS to   try!"]
>>> list(custom_replace_transform(list_a))
    ['sentencepiece encode as pieces', 'examples to try!']
simple_space_split
torchtext.data.functional.simple_space_split(iterator)[source]
A transform to split text string by spaces.
Examples
>>> from torchtext.data.functional import simple_space_split
>>> list_a = ["Sentencepiece encode as pieces", "example to try!"]
>>> list(simple_space_split(list_a))
    [['Sentencepiece', 'encode', 'as', 'pieces'], ['example', 'to', 'try!']]
numericalize_tokens_from_iterator
torchtext.data.functional.numericalize_tokens_from_iterator(vocab, iterator, removed_tokens=None)[source]
Yield a list of ids from an token iterator with a vocab.
Parameters
  • vocab – the vocabulary convert token into id.
  • iterator – the iterator yield a list of tokens.
  • removed_tokens – removed tokens from output dataset (Default: None)
Examples
>>> from torchtext.data.functional import numericalize_tokens_from_iterator
>>> vocab = {'Sentencepiece' : 0, 'encode' : 1, 'as' : 2, 'pieces' : 3}
>>> ids_iter = numericalize_tokens_from_iterator(vocab,
>>>                               simple_space_split(["Sentencepiece as pieces",
>>>                                                   "as pieces"]))
>>> for ids in ids_iter:
>>>     print([num for num in ids])
>>> [0, 2, 3]
>>> [2, 3]
filter_wikipedia_xml
torchtext.data.functional.filter_wikipedia_xml(text_iterator)[source]
Filter wikipedia xml lines according to https://github.com/facebookresearch/fastText/blob/master/wikifil.pl
Parameters
text_iterator – An iterator type object that yields strings. Examples include string list, text io, generators etc.
Examples
>>> from torchtext.data.functional import filter_wikipedia_xml
>>> from torchtext.datasets import EnWik9
>>> data_iter = EnWik9(split='train')
>>> filter_data_iter = filter_wikipedia_xml(data_iter)
>>> file_name = '.data/EnWik9/enwik9'
>>> filter_data_iter = filter_wikipedia_xml(open(file_name,'r'))
to_map_style_dataset
torchtext.data.functional.to_map_style_dataset(iter_data)[source]
Convert iterable-style dataset to map-style dataset.
Parameters
iter_data – An iterator type object. Examples include Iterable datasets, string list, text io, generators etc.
Examples
>>> from torchtext.datasets import IMDB
>>> from torchtext.data import to_map_style_dataset
>>> train_iter = IMDB(split='train')
>>> train_dataset = to_map_style_dataset(train_iter)
>>> data_iter = to_map_style_dataset(open(file_name,'r'))
文档
访问 PyTorch 的全面开发人员文档
查看文档
教程
获取面向初学者和高级开发人员的深入教程
查看教程
资源
查找开发资源并解答您的问题
查看资源
