目录
Oscillator and ADSR envelope
Author: Moto Hira
This tutorial shows how to synthesize various waveforms using oscillator_bank() and adsr_envelope().
Warning
This tutorial requires prototype DSP features, which are available in nightly builds.
Please refer to https://pytorch.org/get-started/locally for instructions for installing a nightly build.
import torch
import torchaudio
print(torch.__version__)
print(torchaudio.__version__)
2.2.0
2.2.0
try:
    from torchaudio.prototype.functional import adsr_envelope, oscillator_bank
except ModuleNotFoundError:
    print(
        "Failed to import prototype DSP features. "
        "Please install torchaudio nightly builds. "
        "Please refer to https://pytorch.org/get-started/locally "
        "for instructions to install a nightly build."
    raise
import math
from IPython.display import Audio
PI = torch.pi
PI2 = 2 * torch.pi
Oscillator Bank
Sinusoidal oscillator generates sinusoidal waveforms from given amplitudes and frequencies.
\[x_t = A_t \sin \theta_t\]
Where the phase \(\theta_t\) is found by integrating the instantaneous frequency \(f_t\).
\[\theta_t = \sum_{k=1}^{t} f_k\]
Note
Why integrate the frequencies? Instantaneous frequency represents the velocity of oscillation at given time. So integrating the instantaneous frequency gives the displacement of the phase of the oscillation, since the start. In discrete-time signal processing, integration becomes accumulation. In PyTorch, accumulation can be computed using torch.cumsum().
torchaudio.prototype.functional.oscillator_bank() generates a bank of sinsuoidal waveforms from amplitude envelopes and instantaneous frequencies.
Simple Sine Wave
Let’s start with simple case.
First, we generate sinusoidal wave that has constant frequency and amplitude everywhere, that is, a regular sine wave.
We define some constants and helper function that we use for the rest of the tutorial.
F0 = 344.0  # fundamental frequency
DURATION = 1.1  # [seconds]
SAMPLE_RATE = 16_000  # [Hz]
NUM_FRAMES = int(DURATION * SAMPLE_RATE)
def show(freq, amp, waveform, sample_rate, zoom=None, vol=0.3):
    t = (torch.arange(waveform.size(0)) / sample_rate).numpy()
    fig, axes = plt.subplots(4, 1, sharex=True)
    axes[0].plot(t, freq.numpy())
    axes[0].set(title=f"Oscillator bank (bank size: {amp.size(-1)})", ylabel="Frequency [Hz]", ylim=[-0.03, None])
    axes[1].plot(t, amp.numpy())
    axes[1].set(ylabel="Amplitude", ylim=[-0.03 if torch.all(amp >= 0.0) else None, None])
    axes[2].plot(t, waveform.numpy())
    axes[2].set(ylabel="Waveform")
    axes[3].specgram(waveform, Fs=sample_rate)
    axes[3].set(ylabel="Spectrogram", xlabel="Time [s]", xlim=[-0.01, t[-1] + 0.01])
    for i in range(4):
        axes[i].grid(True)
    pos = axes[2].get_position()
    plt.tight_layout()
    if zoom is not None:
        ax = fig.add_axes([pos.x0 + 0.01, pos.y0 + 0.03, pos.width / 2.5, pos.height / 2.0])
        ax.plot(t, waveform)
        ax.set(xlim=zoom, xticks=[], yticks=[])
    waveform /= waveform.abs().max()
    return Audio(vol * waveform, rate=sample_rate, normalize=False)
Now we synthesize the audio with constant frequency and amplitude
freq = torch.full((NUM_FRAMES, 1), F0)
amp = torch.ones((NUM_FRAMES, 1))
waveform = oscillator_bank(freq, amp, sample_rate=SAMPLE_RATE)
show(freq, amp, waveform, SAMPLE_RATE, zoom=(1 / F0, 3 / F0))
Oscillator bank (bank size: 1)
Combining multiple sine waves
oscillator_bank() can combine an arbitrary number of sinusoids to generate a waveform.
freq = torch.empty((NUM_FRAMES, 3))
freq[:, 0] = F0
freq[:, 1] = 3 * F0
freq[:, 2] = 5 * F0
amp = torch.ones((NUM_FRAMES, 3)) / 3
Oscillator bank (bank size: 3)
Changing Frequencies across time
Let’s change the frequency over time. Here, we change the frequency from zero to the Nyquist frequency (half of the sample rate) in log-scale so that it is easy to see the change in waveform.
nyquist_freq = SAMPLE_RATE / 2
freq = torch.logspace(0, math.log(0.99 * nyquist_freq, 10), NUM_FRAMES).unsqueeze(-1)
show(freq, amp, waveform, SAMPLE_RATE, vol=0.2)
We can also oscillate frequency.
fm = 2.5  # rate at which the frequency oscillates
f_dev = 0.9 * F0  # the degree of frequency oscillation
freq = F0 + f_dev * torch.sin(torch.linspace(0, fm * PI2 * DURATION, NUM_FRAMES))
freq = freq.unsqueeze(-1)
show(freq, amp, waveform, SAMPLE_RATE)
ADSR Envelope
Next, we change the amplitude over time. A common technique to model amplitude is ADSR Envelope.
ADSR stands for Attack, Decay, Sustain, and Release.
  • Attack is the time it takes to reach from zero to the top level.
  • Decay is the time it takes from the top to reach sustain level.
  • Sustain is the level at which the level stays constant.
  • Release is the time it takes to drop to zero from sustain level.
There are many variants of ADSR model, additionally, some models have the following properties
  • Hold: The time the level stays at the top level after attack.
  • non-linear decay/release: The decay and release take non-linear change.
adsr_envelope supports hold and polynomial decay.
freq = torch.full((SAMPLE_RATE, 1), F0)
amp = adsr_envelope(
    SAMPLE_RATE,
    attack=0.2,
    hold=0.2,
    decay=0.2,
    sustain=0.5,
    release=0.2,
    n_decay=1,
amp = amp.unsqueeze(-1)
audio = show(freq, amp, waveform, SAMPLE_RATE)
ax = plt.gcf().axes[1]
ax.annotate("Attack", xy=(0.05, 0.7))
ax.annotate("Hold", xy=(0.28, 0.65))
ax.annotate("Decay", xy=(0.45, 0.5))
ax.annotate("Sustain", xy=(0.65, 0.3))
ax.annotate("Release", xy=(0.88, 0.35))
audio
Now let’s look into some examples of how ADSR envelope can be used to create different sounds.
The following examples are inspired by this article.
Drum Beats
unit = NUM_FRAMES // 3
repeat = 9
freq = torch.empty((unit * repeat, 2))
freq[:, 0] = F0 / 9
freq[:, 1] = F0 / 5
amp = torch.stack(
        adsr_envelope(unit, attack=0.01, hold=0.125, decay=0.12, sustain=0.05, release=0),
        adsr_envelope(unit, attack=0.01, hold=0.25, decay=0.08, sustain=0, release=0),
    dim=-1,
amp = amp.repeat(repeat, 1) / 2
bass = oscillator_bank(freq, amp, sample_rate=SAMPLE_RATE)
show(freq, amp, bass, SAMPLE_RATE, vol=0.5)
Oscillator bank (bank size: 2)
Pluck
tones = [
    513.74,  # do
    576.65,  # re
    647.27,  # mi
    685.76,  # fa
    769.74,  # so
    685.76,  # fa
    647.27,  # mi
    576.65,  # re
    513.74,  # do
freq = torch.cat([torch.full((unit, 1), tone) for tone in tones], dim=0)
amp = adsr_envelope(unit, attack=0, decay=0.7, sustain=0.28, release=0.29)
amp = amp.repeat(9).unsqueeze(-1)
doremi = oscillator_bank(freq, amp, sample_rate=SAMPLE_RATE)
show(freq, amp, doremi, SAMPLE_RATE)
Riser
env = adsr_envelope(NUM_FRAMES * 6, attack=0.98, decay=0.0, sustain=1, release=0.02)
tones = [
    484.90,  # B4
    513.74,  # C5
    576.65,  # D5
    1221.88,  # D#6/Eb6
    3661.50,  # A#7/Bb7
    6157.89,  # G8
freq = torch.stack([f * env for f in tones], dim=-1)
amp = env.unsqueeze(-1).expand(freq.shape) / len(tones)
Oscillator bank (bank size: 6)
References
Total running time of the script: ( 0 minutes 2.975 seconds)
Gallery generated by Sphinx-Gallery
文档
访问 PyTorch 的全面开发人员文档
查看文档
教程
获取面向初学者和高级开发人员的深入教程
查看教程
资源
查找开发资源并解答您的问题
查看资源
