目录
Additive Synthesis
Author: Moto Hira
This tutorial is the continuation of Oscillator and ADSR Envelope.
This tutorial shows how to perform additive synthesis and subtractive synthesis using TorchAudio’s DSP functions.
Additive synthesis creates timbre by combining multiple waveform. Subtractive synthesis creates timbre by applying filters.
Warning
This tutorial requires prototype DSP features, which are available in nightly builds.
Please refer to https://pytorch.org/get-started/locally for instructions for installing a nightly build.
import torch
import torchaudio
print(torch.__version__)
print(torchaudio.__version__)
2.2.0
2.2.0
Overview
try:
    from torchaudio.prototype.functional import adsr_envelope, extend_pitch, oscillator_bank
except ModuleNotFoundError:
    print(
        "Failed to import prototype DSP features. "
        "Please install torchaudio nightly builds. "
        "Please refer to https://pytorch.org/get-started/locally "
        "for instructions to install a nightly build."
    raise
from IPython.display import Audio
Creating multiple frequency pitches
The core of additive synthesis is oscillator. We create a timbre by summing up the multiple waveforms generated by oscillator.
In the oscillator tutorial, we used oscillator_bank() and adsr_envelope() to generate various waveforms.
In this tutorial, we use extend_pitch() to create a timbre from base frequency.
First, we define some constants and helper function that we use throughout the tutorial.
PI = torch.pi
PI2 = 2 * torch.pi
F0 = 344.0  # fundamental frequency
DURATION = 1.1  # [seconds]
SAMPLE_RATE = 16_000  # [Hz]
NUM_FRAMES = int(DURATION * SAMPLE_RATE)
def plot(freq, amp, waveform, sample_rate, zoom=None, vol=0.1):
    t = (torch.arange(waveform.size(0)) / sample_rate).numpy()
    fig, axes = plt.subplots(4, 1, sharex=True)
    axes[0].plot(t, freq.numpy())
    axes[0].set(title=f"Oscillator bank (bank size: {amp.size(-1)})", ylabel="Frequency [Hz]", ylim=[-0.03, None])
    axes[1].plot(t, amp.numpy())
    axes[1].set(ylabel="Amplitude", ylim=[-0.03 if torch.all(amp >= 0.0) else None, None])
    axes[2].plot(t, waveform)
    axes[2].set(ylabel="Waveform")
    axes[3].specgram(waveform, Fs=sample_rate)
    axes[3].set(ylabel="Spectrogram", xlabel="Time [s]", xlim=[-0.01, t[-1] + 0.01])
    for i in range(4):
        axes[i].grid(True)
    pos = axes[2].get_position()
    fig.tight_layout()
    if zoom is not None:
        ax = fig.add_axes([pos.x0 + 0.02, pos.y0 + 0.03, pos.width / 2.5, pos.height / 2.0])
        ax.plot(t, waveform)
        ax.set(xlim=zoom, xticks=[], yticks=[])
    waveform /= waveform.abs().max()
    return Audio(vol * waveform, rate=sample_rate, normalize=False)
Harmonic Overtones
Harmonic overtones are frequency components that are an integer multiple of the fundamental frequency.
We look at how to generate the common waveforms that are used in synthesizers. That is,
  • Sawtooth wave
  • Square wave
  • Triangle wave
Sawtooth wave
Sawtooth wave can be expressed as the following. It contains all the integer harmonics, so it is commonly used in subtractive synthesis as well.
\[\begin{align*} y_t &= \sum_{k=1}^{K} A_k \sin ( 2 \pi f_k t ) \\ \text{where} \\ f_k &= k f_0 \\ A_k &= -\frac{ (-1) ^k }{k \pi} \end{align*}\]
The following function takes fundamental frequencies and amplitudes, and adds extend pitch in accordance with the formula above.
def sawtooth_wave(freq0, amp0, num_pitches, sample_rate):
    freq = extend_pitch(freq0, num_pitches)
    mults = [-((-1) ** i) / (PI * i) for i in range(1, 1 + num_pitches)]
    amp = extend_pitch(amp0, mults)
    waveform = oscillator_bank(freq, amp, sample_rate=sample_rate)
    return freq, amp, waveform
Now synthesize a waveform
freq0 = torch.full((NUM_FRAMES, 1), F0)
amp0 = torch.ones((NUM_FRAMES, 1))
freq, amp, waveform = sawtooth_wave(freq0, amp0, int(SAMPLE_RATE / F0), SAMPLE_RATE)
plot(freq, amp, waveform, SAMPLE_RATE, zoom=(1 / F0, 3 / F0))
Oscillator bank (bank size: 46)
/pytorch/audio/src/torchaudio/prototype/functional/_dsp.py:63: UserWarning: Some frequencies are above nyquist frequency. Setting the corresponding amplitude to zero. This might cause numerically unstable gradient.
  warnings.warn(
It is possible to oscillate the base frequency to create a time-varying tone based on sawtooth wave.
fm = 10  # rate at which the frequency oscillates [Hz]
f_dev = 0.1 * F0  # the degree of frequency oscillation [Hz]
phase = torch.linspace(0, fm * PI2 * DURATION, NUM_FRAMES)
freq0 = F0 + f_dev * torch.sin(phase).unsqueeze(-1)
  warnings.warn(
Square wave
Square wave contains only odd-integer harmonics.
\[\begin{align*} y_t &= \sum_{k=0}^{K-1} A_k \sin ( 2 \pi f_k t ) \\ \text{where} \\ f_k &= n f_0 \\ A_k &= \frac{ 4 }{n \pi} \\ n &= 2k + 1 \end{align*}\]
def square_wave(freq0, amp0, num_pitches, sample_rate):
    mults = [2.0 * i + 1.0 for i in range(num_pitches)]
    freq = extend_pitch(freq0, mults)
    mults = [4 / (PI * (2.0 * i + 1.0)) for i in range(num_pitches)]
freq, amp, waveform = square_wave(freq0, amp0, int(SAMPLE_RATE / F0 / 2), SAMPLE_RATE)
Oscillator bank (bank size: 23)
  warnings.warn(
Triangle wave
Triangle wave also only contains odd-integer harmonics.
\[\begin{align*} y_t &= \sum_{k=0}^{K-1} A_k \sin ( 2 \pi f_k t ) \\ \text{where} \\ f_k &= n f_0 \\ A_k &= (-1) ^ k \frac{8}{(n\pi) ^ 2} \\ n &= 2k + 1 \end{align*}\]
def triangle_wave(freq0, amp0, num_pitches, sample_rate):
    c = 8 / (PI**2)
    mults = [c * ((-1) ** i) / ((2.0 * i + 1.0) ** 2) for i in range(num_pitches)]
freq, amp, waveform = triangle_wave(freq0, amp0, int(SAMPLE_RATE / F0 / 2), SAMPLE_RATE)
  warnings.warn(
Inharmonic Paritials
Inharmonic partials refer to freqencies that are not integer multiple of fundamental frequency.
They are essential in re-creating realistic sound or making the result of synthesis more interesting.
Bell sound
https://computermusicresource.com/Simple.bell.tutorial.html
num_tones = 9
duration = 2.0
num_frames = int(SAMPLE_RATE * duration)
freq0 = torch.full((num_frames, 1), F0)
mults = [0.56, 0.92, 1.19, 1.71, 2, 2.74, 3.0, 3.76, 4.07]
amp = adsr_envelope(
    num_frames=num_frames,
    attack=0.002,
    decay=0.998,
    sustain=0.0,
    release=0.0,
    n_decay=2,
amp = torch.stack([amp * (0.5**i) for i in range(num_tones)], dim=-1)
waveform = oscillator_bank(freq, amp, sample_rate=SAMPLE_RATE)
plot(freq, amp, waveform, SAMPLE_RATE, vol=0.4)
Oscillator bank (bank size: 9)
As a comparison, the following is the harmonic version of the above. Only frequency values are different. The number of overtones and its amplitudes are same.
freq = extend_pitch(freq0, num_tones)
plot(freq, amp, waveform, SAMPLE_RATE)
References
Total running time of the script: ( 0 minutes 4.662 seconds)
Gallery generated by Sphinx-Gallery
文档
访问 PyTorch 的全面开发人员文档
查看文档
教程
获取面向初学者和高级开发人员的深入教程
查看教程
资源
查找开发资源并解答您的问题
查看资源
