Note
Click here to download the full example code
Torchaudio-Squim: Non-intrusive Speech Assessment in TorchAudio¶
Author: Anurag Kumar, Zhaoheng Ni
1. Overview¶
This tutorial shows uses of Torchaudio-Squim to estimate objective and subjective metrics for assessment of speech quality and intelligibility.
TorchAudio-Squim enables speech assessment in Torchaudio. It provides interface and pre-trained models to estimate various speech quality and intelligibility metrics. Currently, Torchaudio-Squim [1] supports reference-free estimation 3 widely used objective metrics:
- Wideband Perceptual Estimation of Speech Quality (PESQ) [2]
- Short-Time Objective Intelligibility (STOI) [3]
- Scale-Invariant Signal-to-Distortion Ratio (SI-SDR) [4]
It also supports estimation of subjective Mean Opinion Score (MOS) for a given audio waveform using Non-Matching References [1, 5].
References
[1] Kumar, Anurag, et al. “TorchAudio-Squim: Reference-less Speech Quality and Intelligibility measures in TorchAudio.” ICASSP 2023-2023 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP). IEEE, 2023.
[2] I. Rec, “P.862.2: Wideband extension to recommendation P.862 for the assessment of wideband telephone networks and speech codecs,” International Telecommunication Union, CH–Geneva, 2005.
[3] Taal, C. H., Hendriks, R. C., Heusdens, R., & Jensen, J. (2010, March). A short-time objective intelligibility measure for time-frequency weighted noisy speech. In 2010 IEEE international conference on acoustics, speech and signal processing (pp. 4214-4217). IEEE.
[4] Le Roux, Jonathan, et al. “SDR–half-baked or well done?.” ICASSP 2019-2019 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP). IEEE, 2019.
[5] Manocha, Pranay, and Anurag Kumar. “Speech quality assessment through MOS using non-matching references.” Interspeech, 2022.
import torch
import torchaudio
print(torch.__version__)
print(torchaudio.__version__)
2.1.1
2.1.2
2. Preparation¶
First import the modules and define the helper functions.
We will need torch, torchaudio to use Torchaudio-squim, Matplotlib to plot data, pystoi, pesq for computing reference metrics.
try:
    from pesq import pesq
    from pystoi import stoi
    from torchaudio.pipelines import SQUIM_OBJECTIVE, SQUIM_SUBJECTIVE
except ImportError:
    try:
        import google.colab  # noqa: F401
        print(
            To enable running this notebook in Google Colab, install nightly
            torch and torchaudio builds by adding the following code block to the top
            of the notebook before running it:
            !pip3 uninstall -y torch torchvision torchaudio
            !pip3 install --pre torch torchvision torchaudio --extra-index-url https://download.pytorch.org/whl/nightly/cpu
            !pip3 install pesq
            !pip3 install pystoi
    except Exception:
        pass
    raise
import torchaudio.functional as F
from IPython.display import Audio
from torchaudio.utils import download_asset
def si_snr(estimate, reference, epsilon=1e-8):
    estimate = estimate - estimate.mean()
    reference = reference - reference.mean()
    reference_pow = reference.pow(2).mean(axis=1, keepdim=True)
    mix_pow = (estimate * reference).mean(axis=1, keepdim=True)
    scale = mix_pow / (reference_pow + epsilon)
    reference = scale * reference
    error = estimate - reference
    error_pow = error.pow(2)
    reference_pow = reference_pow.mean(axis=1)
    error_pow = error_pow.mean(axis=1)
    si_snr = 10 * torch.log10(reference_pow) - 10 * torch.log10(error_pow)
    return si_snr.item()
def plot(waveform, title, sample_rate=16000):
    wav_numpy = waveform.numpy()
    sample_size = waveform.shape[1]
    time_axis = torch.arange(0, sample_size) / sample_rate
    figure, axes = plt.subplots(2, 1)
    axes[0].plot(time_axis, wav_numpy[0], linewidth=1)
    axes[0].grid(True)
    axes[1].specgram(wav_numpy[0], Fs=sample_rate)
    figure.suptitle(title)
3. Load Speech and Noise Sample¶
SAMPLE_SPEECH = download_asset("tutorial-assets/Lab41-SRI-VOiCES-src-sp0307-ch127535-sg0042.wav")
SAMPLE_NOISE = download_asset("tutorial-assets/Lab41-SRI-VOiCES-rm1-babb-mc01-stu-clo.wav")
  0%|          | 0.00/156k [00:00<?, ?B/s]
100%|##########| 156k/156k [00:00<00:00, 10.2MB/s]
WAVEFORM_SPEECH, SAMPLE_RATE_SPEECH = torchaudio.load(SAMPLE_SPEECH)
WAVEFORM_NOISE, SAMPLE_RATE_NOISE = torchaudio.load(SAMPLE_NOISE)
WAVEFORM_NOISE = WAVEFORM_NOISE[0:1, :]
Currently, Torchaudio-Squim model only supports 16000 Hz sampling rate. Resample the waveforms if necessary.
if SAMPLE_RATE_SPEECH != 16000:
    WAVEFORM_SPEECH = F.resample(WAVEFORM_SPEECH, SAMPLE_RATE_SPEECH, 16000)
if SAMPLE_RATE_NOISE != 16000:
    WAVEFORM_NOISE = F.resample(WAVEFORM_NOISE, SAMPLE_RATE_NOISE, 16000)
Trim waveforms so that they have the same number of frames.
if WAVEFORM_SPEECH.shape[1] < WAVEFORM_NOISE.shape[1]:
    WAVEFORM_NOISE = WAVEFORM_NOISE[:, : WAVEFORM_SPEECH.shape[1]]
else:
    WAVEFORM_SPEECH = WAVEFORM_SPEECH[:, : WAVEFORM_NOISE.shape[1]]
Play speech sample
Audio(WAVEFORM_SPEECH.numpy()[0], rate=16000)
Play noise sample
Audio(WAVEFORM_NOISE.numpy()[0], rate=16000)
4. Create distorted (noisy) speech samples¶
snr_dbs = torch.tensor([20, -5])
WAVEFORM_DISTORTED = F.add_noise(WAVEFORM_SPEECH, WAVEFORM_NOISE, snr_dbs)
Play distorted speech with 20dB SNR
Audio(WAVEFORM_DISTORTED.numpy()[0], rate=16000)
Play distorted speech with -5dB SNR
Audio(WAVEFORM_DISTORTED.numpy()[1], rate=16000)
5. Visualize the waveforms¶
Visualize speech sample
plot(WAVEFORM_SPEECH, "Clean Speech")
Visualize noise sample
plot(WAVEFORM_NOISE, "Noise")
Visualize distorted speech with 20dB SNR
plot(WAVEFORM_DISTORTED[0:1], f"Distorted Speech with {snr_dbs[0]}dB SNR")
Visualize distorted speech with -5dB SNR
plot(WAVEFORM_DISTORTED[1:2], f"Distorted Speech with {snr_dbs[1]}dB SNR")
6. Predict Objective Metrics¶
Get the pre-trained SquimObjectivemodel.
objective_model = SQUIM_OBJECTIVE.get_model()
Downloading: "https://download.pytorch.org/torchaudio/models/squim_objective_dns2020.pth" to /root/.cache/torch/hub/checkpoints/squim_objective_dns2020.pth
  0%|          | 0.00/28.2M [00:00<?, ?B/s]
 42%|####2     | 11.9M/28.2M [00:00<00:00, 124MB/s]
 84%|########4 | 23.8M/28.2M [00:00<00:00, 42.7MB/s]
100%|##########| 28.2M/28.2M [00:00<00:00, 34.3MB/s]
Compare model outputs with ground truths for distorted speech with 20dB SNR
stoi_hyp, pesq_hyp, si_sdr_hyp = objective_model(WAVEFORM_DISTORTED[0:1, :])
print(f"Estimated metrics for distorted speech at {snr_dbs[0]}dB are\n")
print(f"STOI: {stoi_hyp[0]}")
print(f"PESQ: {pesq_hyp[0]}")
print(f"SI-SDR: {si_sdr_hyp[0]}\n")
pesq_ref = pesq(16000, WAVEFORM_SPEECH[0].numpy(), WAVEFORM_DISTORTED[0].numpy(), mode="wb")
stoi_ref = stoi(WAVEFORM_SPEECH[0].numpy(), WAVEFORM_DISTORTED[0].numpy(), 16000, extended=False)
si_sdr_ref = si_snr(WAVEFORM_DISTORTED[0:1], WAVEFORM_SPEECH)
print(f"Reference metrics for distorted speech at {snr_dbs[0]}dB are\n")
print(f"STOI: {stoi_ref}")
print(f"PESQ: {pesq_ref}")
print(f"SI-SDR: {si_sdr_ref}")
Estimated metrics for distorted speech at 20dB are
STOI: 0.9610356092453003
PESQ: 2.7801530361175537
SI-SDR: 20.6926326751709
Reference metrics for distorted speech at 20dB are
STOI: 0.9670831113894452
PESQ: 2.7961528301239014
SI-SDR: 19.998966217041016
Compare model outputs with ground truths for distorted speech with -5dB SNR
stoi_hyp, pesq_hyp, si_sdr_hyp = objective_model(WAVEFORM_DISTORTED[1:2, :])
print(f"Estimated metrics for distorted speech at {snr_dbs[1]}dB are\n")
pesq_ref = pesq(16000, WAVEFORM_SPEECH[0].numpy(), WAVEFORM_DISTORTED[1].numpy(), mode="wb")
stoi_ref = stoi(WAVEFORM_SPEECH[0].numpy(), WAVEFORM_DISTORTED[1].numpy(), 16000, extended=False)
si_sdr_ref = si_snr(WAVEFORM_DISTORTED[1:2], WAVEFORM_SPEECH)
print(f"Reference metrics for distorted speech at {snr_dbs[1]}dB are\n")
Estimated metrics for distorted speech at -5dB are
STOI: 0.5743248462677002
PESQ: 1.1112866401672363
SI-SDR: -6.248741149902344
Reference metrics for distorted speech at -5dB are
STOI: 0.5848137931588825
PESQ: 1.0803768634796143
SI-SDR: -5.016279220581055
7. Predict Mean Opinion Scores (Subjective) Metric¶
Get the pre-trained SquimSubjective model.
subjective_model = SQUIM_SUBJECTIVE.get_model()
Downloading: "https://download.pytorch.org/torchaudio/models/squim_subjective_bvcc_daps.pth" to /root/.cache/torch/hub/checkpoints/squim_subjective_bvcc_daps.pth
  0%|          | 0.00/360M [00:00<?, ?B/s]
  1%|          | 2.05M/360M [00:00<00:22, 16.7MB/s]
  1%|1         | 4.18M/360M [00:00<00:22, 16.8MB/s]
  2%|2         | 7.68M/360M [00:00<00:15, 23.9MB/s]
  3%|2         | 10.0M/360M [00:00<00:15, 23.3MB/s]
  4%|3         | 12.7M/360M [00:00<00:16, 21.8MB/s]
  5%|4         | 16.4M/360M [00:00<00:17, 21.1MB/s]
  9%|8         | 31.1M/360M [00:00<00:07, 45.7MB/s]
 10%|9         | 35.3M/360M [00:01<00:10, 34.0MB/s]
 13%|#3        | 47.5M/360M [00:01<00:07, 42.0MB/s]
 14%|#4        | 51.5M/360M [00:01<00:10, 30.2MB/s]
 15%|#5        | 54.7M/360M [00:01<00:11, 28.8MB/s]
 16%|#5        | 57.6M/360M [00:02<00:11, 28.6MB/s]
 17%|#6        | 60.4M/360M [00:02<00:11, 28.1MB/s]
 18%|#8        | 65.5M/360M [00:02<00:12, 24.0MB/s]
 19%|#8        | 68.0M/360M [00:02<00:12, 24.3MB/s]
 21%|##        | 74.0M/360M [00:02<00:10, 29.5MB/s]
 21%|##1       | 77.2M/360M [00:02<00:12, 24.1MB/s]
 22%|##2       | 80.3M/360M [00:03<00:11, 24.9MB/s]
 23%|##2       | 82.8M/360M [00:03<00:13, 21.2MB/s]
 26%|##6       | 93.8M/360M [00:03<00:06, 40.1MB/s]
 27%|##7       | 98.6M/360M [00:03<00:07, 35.2MB/s]
 31%|###1      | 112M/360M [00:03<00:04, 57.9MB/s]
 33%|###3      | 119M/360M [00:03<00:05, 43.6MB/s]
 36%|###6      | 130M/360M [00:04<00:05, 44.3MB/s]
 38%|###7      | 136M/360M [00:04<00:06, 35.9MB/s]
 39%|###8      | 140M/360M [00:04<00:06, 37.1MB/s]
 40%|####      | 146M/360M [00:04<00:07, 30.3MB/s]
 41%|####1     | 149M/360M [00:04<00:07, 28.3MB/s]
 45%|####5     | 162M/360M [00:05<00:04, 44.6MB/s]
 46%|####6     | 167M/360M [00:05<00:05, 34.9MB/s]
 50%|####9     | 180M/360M [00:05<00:04, 40.0MB/s]
 51%|#####1    | 184M/360M [00:05<00:05, 31.0MB/s]
 55%|#####4    | 197M/360M [00:06<00:04, 35.2MB/s]
 59%|#####8    | 211M/360M [00:06<00:04, 38.3MB/s]
 60%|#####9    | 215M/360M [00:06<00:04, 35.7MB/s]
 63%|######3   | 228M/360M [00:06<00:03, 41.2MB/s]
 64%|######4   | 232M/360M [00:07<00:03, 38.1MB/s]
 68%|######7   | 244M/360M [00:07<00:02, 46.5MB/s]
 69%|######9   | 249M/360M [00:07<00:03, 37.0MB/s]
 70%|#######   | 252M/360M [00:07<00:03, 32.2MB/s]
 72%|#######1  | 258M/360M [00:07<00:03, 33.7MB/s]
 73%|#######2  | 262M/360M [00:08<00:03, 29.3MB/s]
 76%|#######5  | 272M/360M [00:08<00:02, 40.6MB/s]
 77%|#######6  | 277M/360M [00:08<00:02, 36.9MB/s]
 78%|#######7  | 281M/360M [00:08<00:03, 24.8MB/s]
 79%|#######8  | 284M/360M [00:09<00:03, 22.7MB/s]
 80%|#######9  | 287M/360M [00:09<00:03, 22.8MB/s]
 80%|########  | 289M/360M [00:09<00:03, 20.3MB/s]
 81%|########  | 292M/360M [00:09<00:03, 20.2MB/s]
 82%|########1 | 295M/360M [00:09<00:03, 20.4MB/s]
 86%|########5 | 310M/360M [00:09<00:01, 44.7MB/s]
 87%|########7 | 314M/360M [00:09<00:01, 37.6MB/s]
 91%|######### | 326M/360M [00:10<00:01, 34.8MB/s]
 92%|#########1| 330M/360M [00:10<00:01, 28.8MB/s]
 96%|#########5| 344M/360M [00:10<00:00, 39.1MB/s]
100%|#########9| 359M/360M [00:11<00:00, 49.6MB/s]
100%|##########| 360M/360M [00:11<00:00, 34.3MB/s]
Load a non-matching reference (NMR)
NMR_SPEECH = download_asset("tutorial-assets/ctc-decoding/1688-142285-0007.wav")
WAVEFORM_NMR, SAMPLE_RATE_NMR = torchaudio.load(NMR_SPEECH)
if SAMPLE_RATE_NMR != 16000:
    WAVEFORM_NMR = F.resample(WAVEFORM_NMR, SAMPLE_RATE_NMR, 16000)
Compute MOS metric for distorted speech with 20dB SNR
mos = subjective_model(WAVEFORM_DISTORTED[0:1, :], WAVEFORM_NMR)
print(f"Estimated MOS for distorted speech at {snr_dbs[0]}dB is MOS: {mos[0]}")
Estimated MOS for distorted speech at 20dB is MOS: 4.309267997741699
Compute MOS metric for distorted speech with -5dB SNR
mos = subjective_model(WAVEFORM_DISTORTED[1:2, :], WAVEFORM_NMR)
print(f"Estimated MOS for distorted speech at {snr_dbs[1]}dB is MOS: {mos[0]}")
Estimated MOS for distorted speech at -5dB is MOS: 3.2918038368225098
8. Comparison with ground truths and baselines¶
Visualizing the estimated metrics by the SquimObjective and
SquimSubjective models can help users better understand how the
models can be applicable in real scenario. The graph below shows scatter
plots of three different systems: MOSA-Net [1], AMSA [2], and the
SquimObjective model, where y axis represents the estimated STOI,
PESQ, and Si-SDR scores, and x axis represents the corresponding ground
truth.
[1] Zezario, Ryandhimas E., Szu-Wei Fu, Fei Chen, Chiou-Shann Fuh, Hsin-Min Wang, and Yu Tsao. “Deep learning-based non-intrusive multi-objective speech assessment model with cross-domain features.” IEEE/ACM Transactions on Audio, Speech, and Language Processing 31 (2022): 54-70.
[2] Dong, Xuan, and Donald S. Williamson. “An attention enhanced multi-task model for objective speech assessment in real-world environments.” In ICASSP 2020-2020 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp. 911-915. IEEE, 2020.
The graph below shows scatter plot of the SquimSubjective model,
where y axis represents the estimated MOS metric score, and x axis
represents the corresponding ground truth.
Total running time of the script: ( 0 minutes 17.568 seconds)
