目录
Feature Classifications
Features described in this documentation are classified by release status:
Stable: These features will be maintained long-term and there should generally be no major performance limitations or gaps in documentation. We also expect to maintain backwards compatibility (although breaking changes can happen and notice will be given one release ahead of time).
Beta: Features are tagged as Beta because the API may change based on user feedback, because the performance needs to improve, or because coverage across operators is not yet complete. For Beta features, we are committing to seeing the feature through to the Stable classification. We are not, however, committing to backwards compatibility.
Prototype: These features are typically not available as part of binary distributions like PyPI or Conda, except sometimes behind run-time flags, and are at an early stage for feedback and testing.
文档
访问 PyTorch 的全面开发人员文档
查看文档
教程
获取面向初学者和高级开发人员的深入教程
查看教程
资源
查找开发资源并解答您的问题
查看资源
