Note
Click here to download the full example code
Audio Resampling¶
Author: Caroline Chen, Moto Hira
This tutorial shows how to use torchaudio’s resampling API.
import torch
import torchaudio
import torchaudio.functional as F
import torchaudio.transforms as T
print(torch.__version__)
print(torchaudio.__version__)
2.1.1
2.1.0
Preparation¶
First, we import the modules and define the helper functions.
import math
import timeit
import librosa
import matplotlib.colors as mcolors
import pandas as pd
import resampy
from IPython.display import Audio
pd.set_option("display.max_rows", None)
pd.set_option("display.max_columns", None)
DEFAULT_OFFSET = 201
def _get_log_freq(sample_rate, max_sweep_rate, offset):
"""Get freqs evenly spaced out in log-scale, between [0, max_sweep_rate // 2]
offset is used to avoid negative infinity `log(offset + x)`.
start, stop = math.log(offset), math.log(offset + max_sweep_rate // 2)
return torch.exp(torch.linspace(start, stop, sample_rate, dtype=torch.double)) - offset
def _get_inverse_log_freq(freq, sample_rate, offset):
"""Find the time where the given frequency is given by _get_log_freq"""
half = sample_rate // 2
return sample_rate * (math.log(1 + freq / offset) / math.log(1 + half / offset))
def _get_freq_ticks(sample_rate, offset, f_max):
# Given the original sample rate used for generating the sweep,
# find the x-axis value where the log-scale major frequency values fall in
times, freq = [], []
for exp in range(2, 5):
for v in range(1, 10):
f = v * 10**exp
if f < sample_rate // 2:
t = _get_inverse_log_freq(f, sample_rate, offset) / sample_rate
times.append(t)
freq.append(f)
t_max = _get_inverse_log_freq(f_max, sample_rate, offset) / sample_rate
times.append(t_max)
freq.append(f_max)
return times, freq
def get_sine_sweep(sample_rate, offset=DEFAULT_OFFSET):
max_sweep_rate = sample_rate
freq = _get_log_freq(sample_rate, max_sweep_rate, offset)
delta = 2 * math.pi * freq / sample_rate
cummulative = torch.cumsum(delta, dim=0)
signal = torch.sin(cummulative).unsqueeze(dim=0)
return signal
def plot_sweep(
waveform,
sample_rate,
title,
max_sweep_rate=48000,
offset=DEFAULT_OFFSET,
x_ticks = [100, 500, 1000, 5000, 10000, 20000, max_sweep_rate // 2]
y_ticks = [1000, 5000, 10000, 20000, sample_rate // 2]
time, freq = _get_freq_ticks(max_sweep_rate, offset, sample_rate // 2)
freq_x = [f if f in x_ticks and f <= max_sweep_rate // 2 else None for f in freq]
freq_y = [f for f in freq if f in y_ticks and 1000 <= f <= sample_rate // 2]
figure, axis = plt.subplots(1, 1)
_, _, _, cax = axis.specgram(waveform[0].numpy(), Fs=sample_rate)
plt.xticks(time, freq_x)
plt.yticks(freq_y, freq_y)
axis.set_xlabel("Original Signal Frequency (Hz, log scale)")
axis.set_ylabel("Waveform Frequency (Hz)")
axis.xaxis.grid(True, alpha=0.67)
axis.yaxis.grid(True, alpha=0.67)
figure.suptitle(f"{title} (sample rate: {sample_rate} Hz)")
plt.colorbar(cax)
Resampling Overview¶
To resample an audio waveform from one freqeuncy to another, you can use
torchaudio.transforms.Resample
or
torchaudio.functional.resample()
transforms.Resample
precomputes and caches the kernel used for resampling,
while functional.resample
computes it on the fly, so using
will result in a speedup when resampling
multiple waveforms using the same parameters (see Benchmarking section).
Both resampling methods use bandlimited sinc interpolation to compute signal values at arbitrary time steps. The implementation involves convolution, so we can take advantage of GPU / multithreading for performance improvements.
Note
When using resampling in multiple subprocesses, such as data loading
with multiple worker processes, your application might create more
threads than your system can handle efficiently.
Setting torch.set_num_threads(1)
might help in this case.
Because a finite number of samples can only represent a finite number of frequencies, resampling does not produce perfect results, and a variety of parameters can be used to control for its quality and computational speed. We demonstrate these properties through resampling a logarithmic sine sweep, which is a sine wave that increases exponentially in frequency over time.
The spectrograms below show the frequency representation of the signal, where the x-axis corresponds to the frequency of the original waveform (in log scale), y-axis the frequency of the plotted waveform, and color intensity the amplitude.
sample_rate = 48000
waveform = get_sine_sweep(sample_rate)
plot_sweep(waveform, sample_rate, title="Original Waveform")
Audio(waveform.numpy()[0], rate=sample_rate)
Now we resample (downsample) it.
We see that in the spectrogram of the resampled waveform, there is an artifact, which was not present in the original waveform. This effect is called aliasing. This page has an explanation of how it happens, and why it looks like a reflection.
resample_rate = 32000
resampler = T.Resample(sample_rate, resample_rate, dtype=waveform.dtype)
resampled_waveform = resampler(waveform)
plot_sweep(resampled_waveform, resample_rate, title="Resampled Waveform")
Audio(resampled_waveform.numpy()[0], rate=resample_rate)
Controling resampling quality with parameters¶
Lowpass filter width¶
Because the filter used for interpolation extends infinitely, the
lowpass_filter_width
parameter is used to control for the width of
the filter to use to window the interpolation. It is also referred to as
the number of zero crossings, since the interpolation passes through
zero at every time unit. Using a larger lowpass_filter_width
provides a sharper, more precise filter, but is more computationally
expensive.
sample_rate = 48000
resampled_waveform = F.resample(waveform, sample_rate, resample_rate, lowpass_filter_width=6)
plot_sweep(resampled_waveform, resample_rate, title="lowpass_filter_width=6")
resampled_waveform = F.resample(waveform, sample_rate, resample_rate, lowpass_filter_width=128)
plot_sweep(resampled_waveform, resample_rate, title="lowpass_filter_width=128")
Rolloff¶
The rolloff
parameter is represented as a fraction of the Nyquist
frequency, which is the maximal frequency representable by a given
finite sample rate. rolloff
determines the lowpass filter cutoff and
controls the degree of aliasing, which takes place when frequencies
higher than the Nyquist are mapped to lower frequencies. A lower rolloff
will therefore reduce the amount of aliasing, but it will also reduce
some of the higher frequencies.
sample_rate = 48000
resampled_waveform = F.resample(waveform, sample_rate, resample_rate, rolloff=0.99)
plot_sweep(resampled_waveform, resample_rate, title="rolloff=0.99")
resampled_waveform = F.resample(waveform, sample_rate, resample_rate, rolloff=0.8)
plot_sweep(resampled_waveform, resample_rate, title="rolloff=0.8")
Window function¶
By default, torchaudio
’s resample uses the Hann window filter, which is
a weighted cosine function. It additionally supports the Kaiser window,
which is a near optimal window function that contains an additional
beta
parameter that allows for the design of the smoothness of the
filter and width of impulse. This can be controlled using the
resampling_method
parameter.
sample_rate = 48000
resampled_waveform = F.resample(waveform, sample_rate, resample_rate, resampling_method="sinc_interp_hann")
plot_sweep(resampled_waveform, resample_rate, title="Hann Window Default")
resampled_waveform = F.resample(waveform, sample_rate, resample_rate, resampling_method="sinc_interp_kaiser")
plot_sweep(resampled_waveform, resample_rate, title="Kaiser Window Default")
Comparison against librosa¶
torchaudio
’s resample function can be used to produce results similar to
that of librosa (resampy)’s kaiser window resampling, with some noise
sample_rate = 48000
kaiser_best¶
waveform,
sample_rate,
resample_rate,
lowpass_filter_width=64,
rolloff=0.9475937167399596,
resampling_method="sinc_interp_kaiser",
beta=14.769656459379492,
plot_sweep(resampled_waveform, resample_rate, title="Kaiser Window Best (torchaudio)")
librosa_resampled_waveform = torch.from_numpy(
librosa.resample(waveform.squeeze().numpy(), orig_sr=sample_rate, target_sr=resample_rate, res_type="kaiser_best")
).unsqueeze(0)
plot_sweep(librosa_resampled_waveform, resample_rate, title="Kaiser Window Best (librosa)")
mse = torch.square(resampled_waveform - librosa_resampled_waveform).mean().item()
print("torchaudio and librosa kaiser best MSE:", mse)
torchaudio and librosa kaiser best MSE: 2.0806901153660115e-06
kaiser_fast¶
waveform,
sample_rate,
resample_rate,
lowpass_filter_width=16,
rolloff=0.85,
beta=8.555504641634386,
plot_sweep(resampled_waveform, resample_rate, title="Kaiser Window Fast (torchaudio)")
librosa.resample(waveform.squeeze().numpy(), orig_sr=sample_rate, target_sr=resample_rate, res_type="kaiser_fast")
).unsqueeze(0)
plot_sweep(librosa_resampled_waveform, resample_rate, title="Kaiser Window Fast (librosa)")
print("torchaudio and librosa kaiser fast MSE:", mse)
torchaudio and librosa kaiser fast MSE: 2.5200744248601437e-05
Performance Benchmarking¶
Below are benchmarks for downsampling and upsampling waveforms between
two pairs of sampling rates. We demonstrate the performance implications
that the lowpass_filter_width
, window type, and sample rates can
have. Additionally, we provide a comparison against librosa
’s
kaiser_best
and kaiser_fast
using their corresponding parameters
in torchaudio
print(f"torchaudio: {torchaudio.__version__}")
print(f"librosa: {librosa.__version__}")
print(f"resampy: {resampy.__version__}")
torchaudio: 2.1.0
librosa: 0.10.0
resampy: 0.2.2
def benchmark_resample_functional(
waveform,
sample_rate,
resample_rate,
lowpass_filter_width=6,
rolloff=0.99,
resampling_method="sinc_interp_hann",
beta=None,
iters=5,
return (
timeit.timeit(
stmt="""
waveform,
sample_rate,
resample_rate,
lowpass_filter_width=lowpass_filter_width,
rolloff=rolloff,
resampling_method=resampling_method,
beta=beta,
setup="import torchaudio",
number=iters,
globals=locals(),
* 1000
/ iters
def benchmark_resample_transforms(
waveform,
sample_rate,
resample_rate,
rolloff=0.99,
beta=None,
iters=5,
return (
timeit.timeit(
stmt="resampler(waveform)",
setup="""
import torchaudio
resampler = torchaudio.transforms.Resample(
sample_rate,
resample_rate,
rolloff=rolloff,
dtype=waveform.dtype,
beta=beta,
resampler.to(waveform.device)
number=iters,
globals=locals(),
* 1000
/ iters
def benchmark_resample_librosa(
waveform,
sample_rate,
resample_rate,
res_type=None,
iters=5,
waveform_np = waveform.squeeze().numpy()
return (
timeit.timeit(
stmt="""
librosa.resample(
waveform_np,
res_type=res_type,
setup="import librosa",
number=iters,
globals=locals(),
* 1000
/ iters
def benchmark(sample_rate, resample_rate):
times, rows = [], []
waveform = get_sine_sweep(sample_rate).to(torch.float32)
args = (waveform, sample_rate, resample_rate)
# sinc 64 zero-crossings
f_time = benchmark_resample_functional(*args, lowpass_filter_width=64)
t_time = benchmark_resample_transforms(*args, lowpass_filter_width=64)
times.append([None, f_time, t_time])
rows.append("sinc (width 64)")
# sinc 6 zero-crossings
f_time = benchmark_resample_functional(*args, lowpass_filter_width=16)
t_time = benchmark_resample_transforms(*args, lowpass_filter_width=16)
rows.append("sinc (width 16)")
# kaiser best
kwargs = {
"lowpass_filter_width": 64,
"rolloff": 0.9475937167399596,
"resampling_method": "sinc_interp_kaiser",
"beta": 14.769656459379492,
lib_time = benchmark_resample_librosa(*args, res_type="kaiser_best")
f_time = benchmark_resample_functional(*args, **kwargs)
t_time = benchmark_resample_transforms(*args, **kwargs)
times.append([lib_time, f_time, t_time])
rows.append("kaiser_best")
# kaiser fast
kwargs = {
"lowpass_filter_width": 16,
"rolloff": 0.85,
"beta": 8.555504641634386,
lib_time = benchmark_resample_librosa(*args, res_type="kaiser_fast")
rows.append("kaiser_fast")
df = pd.DataFrame(times, columns=["librosa", "functional", "transforms"], index=rows)
return df
def plot(df):
print(df.round(2))
ax = df.plot(kind="bar")
plt.ylabel("Time Elapsed [ms]")
plt.xticks(rotation=0, fontsize=10)
for cont, col, color in zip(ax.containers, df.columns, mcolors.TABLEAU_COLORS):
label = ["N/A" if v != v else str(v) for v in df[col].round(2)]
ax.bar_label(cont, labels=label, color=color, fontweight="bold", fontsize="x-small")
Downsample (48 -> 44.1 kHz)¶
df = benchmark(48_000, 44_100)
plot(df)
librosa functional transforms
sinc (width 64) NaN 0.87 0.38
sinc (width 16) NaN 0.76 0.35
kaiser_best 81.05 1.28 0.37
kaiser_fast 7.88 0.93 0.34
Downsample (16 -> 8 kHz)¶
df = benchmark(16_000, 8_000)
plot(df)
sinc (width 64) NaN 1.28 1.09
sinc (width 16) NaN 0.52 0.37
kaiser_best 11.25 1.38 1.16
kaiser_fast 3.12 0.58 0.39
Upsample (44.1 -> 48 kHz)¶
df = benchmark(44_100, 48_000)
plot(df)
sinc (width 64) NaN 0.85 0.37
sinc (width 16) NaN 0.68 0.34
kaiser_best 32.63 1.10 0.37
kaiser_fast 7.82 0.91 0.33
Upsample (8 -> 16 kHz)¶
df = benchmark(8_000, 16_000)
plot(df)
sinc (width 64) NaN 0.66 0.48
sinc (width 16) NaN 0.36 0.21
kaiser_best 11.19 0.70 0.48
kaiser_fast 2.95 0.40 0.23
Summary¶
To elaborate on the results:
a larger
results in a larger resampling kernel, and therefore increases computation time for both the kernel computation and convolutionusing
sinc_interp_kaiser
results in longer computation times than the defaultsinc_interp_hann
because it is more complex to compute the intermediate window valuesa large GCD between the sample and resample rate will result in a simplification that allows for a smaller kernel and faster kernel computation.
Total running time of the script: ( 0 minutes 3.322 seconds)
