目录
Audio Feature Augmentation
Author: Moto Hira
# When running this tutorial in Google Colab, install the required packages
# with the following.
# !pip install torchaudio librosa
import torch
import torchaudio
import torchaudio.transforms as T
print(torch.__version__)
print(torchaudio.__version__)
2.1.1
2.1.0
Preparation
import librosa
from IPython.display import Audio
from torchaudio.utils import download_asset
In this tutorial, we will use a speech data from VOiCES dataset, which is licensed under Creative Commos BY 4.0.
SAMPLE_WAV_SPEECH_PATH = download_asset("tutorial-assets/Lab41-SRI-VOiCES-src-sp0307-ch127535-sg0042.wav")
def _get_sample(path, resample=None):
    effects = [["remix", "1"]]
    if resample:
        effects.extend(
                ["lowpass", f"{resample // 2}"],
                ["rate", f"{resample}"],
    return torchaudio.sox_effects.apply_effects_file(path, effects=effects)
def get_speech_sample(*, resample=None):
    return _get_sample(SAMPLE_WAV_SPEECH_PATH, resample=resample)
def get_spectrogram(
    n_fft=400,
    win_len=None,
    hop_len=None,
    power=2.0,
    waveform, _ = get_speech_sample()
    spectrogram = T.Spectrogram(
        n_fft=n_fft,
        win_length=win_len,
        hop_length=hop_len,
        center=True,
        pad_mode="reflect",
        power=power,
    return spectrogram(waveform)
SpecAugment
SpecAugment is a popular spectrogram augmentation technique.
torchaudio implements torchaudio.transforms.TimeStretch(), torchaudio.transforms.TimeMasking() and torchaudio.transforms.FrequencyMasking().
TimeStretch
spec = get_spectrogram(power=None)
stretch = T.TimeStretch()
spec_12 = stretch(spec, overriding_rate=1.2)
spec_09 = stretch(spec, overriding_rate=0.9)
Visualization
def plot():
    def plot_spec(ax, spec, title):
        ax.set_title(title)
        ax.imshow(librosa.amplitude_to_db(spec), origin="lower", aspect="auto")
    fig, axes = plt.subplots(3, 1, sharex=True, sharey=True)
    plot_spec(axes[0], torch.abs(spec_12[0]), title="Stretched x1.2")
    plot_spec(axes[1], torch.abs(spec[0]), title="Original")
    plot_spec(axes[2], torch.abs(spec_09[0]), title="Stretched x0.9")
    fig.tight_layout()
plot()
Stretched x1.2, Original, Stretched x0.9
Audio Samples
def preview(spec, rate=16000):
    ispec = T.InverseSpectrogram()
    waveform = ispec(spec)
    return Audio(waveform[0].numpy().T, rate=rate)
preview(spec)
preview(spec_12)
preview(spec_09)
Time and Frequency Masking
torch.random.manual_seed(4)
time_masking = T.TimeMasking(time_mask_param=80)
freq_masking = T.FrequencyMasking(freq_mask_param=80)
spec = get_spectrogram()
time_masked = time_masking(spec)
freq_masked = freq_masking(spec)
def plot():
        ax.set_title(title)
        ax.imshow(librosa.power_to_db(spec), origin="lower", aspect="auto")
    plot_spec(axes[0], spec[0], title="Original")
    plot_spec(axes[1], time_masked[0], title="Masked along time axis")
    plot_spec(axes[2], freq_masked[0], title="Masked along frequency axis")
    fig.tight_layout()
plot()
Original, Masked along time axis, Masked along frequency axis
Total running time of the script: ( 0 minutes 2.231 seconds)
Gallery generated by Sphinx-Gallery
文档
访问 PyTorch 的全面开发人员文档
查看文档
教程
获取面向初学者和高级开发人员的深入教程
查看教程
资源
查找开发资源并解答您的问题
查看资源
