目录
Distributed
For distributed training, TorchX relies on the scheduler’s gang scheduling capabilities to schedule n copies of nodes. Once launched, the application is expected to be written in a way that leverages this topology, for instance, with PyTorch’s DDP. You can express a variety of node topologies with TorchX by specifying multiple torchx.specs.Role in your component’s AppDef. Each role maps to a homogeneous group of nodes that performs a “role” (function) in the overall training. Scheduling-wise, TorchX launches each role as a sub-gang.
A DDP-style training job has a single role: trainers. Whereas a training job that uses parameter servers will have two roles: parameter server, trainer. You can specify different entrypoint (executable), num replicas, resource requirements, and more for each role.
DDP Builtin
DDP-style trainers are common and easy to templetize since they are homogeneous single role AppDefs, so there is a builtin: dist.ddp. Assuming your DDP training script is called main.py, launch it as:
# locally, 1 node x 4 workers
$ torchx run -s local_cwd dist.ddp -j 1x4 --script main.py
# locally, 2 node x 4 workers (8 total)
$ torchx run -s local_cwd dist.ddp -j 2x4 --script main.py
# remote (optionally pass --rdzv_port to use a different master port than the default 29500)
$ torchx run -s kubernetes -cfg queue=default dist.ddp \
    -j 2x4 \
    --script main.py
# remote -- elastic/autoscaling with 2 minimum and max 5 nodes with 8
# workers each
$ torchx run -s kubernetes dist.ddp -j 2:5x8 --script main.py
Note that the only difference compared to the local launch is the scheduler (-s). The dist.ddp builtin uses torchelastic (more specifically torch.distributed.run) under the hood. Read more about torchelastic here.
Components APIs
torchx.components.dist.ddp(*script_args: str, script: Optional[str] = None, m: Optional[str] = None, image: str = 'ghcr.io/pytorch/torchx:0.6.0', name: str = '/', h: Optional[str] = None, cpu: int = 2, gpu: int = 0, memMB: int = 1024, j: str = '1x2', env: Optional[Dict[str, str]] = None, max_retries: int = 0, rdzv_port: int = 29500, rdzv_backend: str = 'c10d', mounts: Optional[List[str]] = None, debug: bool = False) → AppDef[source]
Distributed data parallel style application (one role, multi-replica). Uses torch.distributed.run to launch and coordinate PyTorch worker processes. Defaults to using c10d rendezvous backend on rendezvous_endpoint $rank_0_host:$rdzv_port. Note that rdzv_port parameter is ignored when running on single node, and instead we use port 0 which instructs torchelastic to chose a free random port on the host.
Note: (cpu, gpu, memMB) parameters are mutually exclusive with h (named resource) where
h takes precedence if specified for setting resource requirements. See registering named resources.
Parameters:
  • script_args – arguments to the main module
  • script – script or binary to run within the image
  • m – the python module path to run
  • image – image (e.g. docker)
  • name – job name override in the following format: {experimentname}/{runname} or {experimentname}/ or /{runname} or {runname}. Uses the script or module name if {runname} not specified.
  • cpu – number of cpus per replica
  • gpu – number of gpus per replica
  • memMB – cpu memory in MB per replica
  • h – a registered named resource (if specified takes precedence over cpu, gpu, memMB)
  • j – [{min_nnodes}:]{nnodes}x{nproc_per_node}, for gpu hosts, nproc_per_node must not exceed num gpus
  • env – environment varibles to be passed to the run (e.g. ENV1=v1,ENV2=v2,ENV3=v3)
  • max_retries – the number of scheduler retries allowed
  • rdzv_port – the port on rank0’s host to use for hosting the c10d store used for rendezvous. Only takes effect when running multi-node. When running single node, this parameter is ignored and a random free port is chosen.
  • rdzv_backend – the rendezvous backend to use. Only takes effect when running multi-node.
  • mounts – mounts to mount into the worker environment/container (ex. type=<bind/volume>,src=/host,dst=/job[,readonly]). See scheduler documentation for more info.
  • debug – whether to run with preset debug flags enabled
torchx.components.dist._TORCH_DEBUG_FLAGS
These are commonly set environment variables to debug PyTorch execution.
  • CUDA_LAUNCH_BLOCKING: Read more here.
  • NCCL_DESYNC_DEBUG
  • TORCH_DISTRIBUTED_DEBUG: Read more here.
  • TORCH_SHOW_CPP_STACKTRACES: Read more here.
文档
访问 PyTorch 的全面开发人员文档
查看文档
教程
获取面向初学者和高级开发人员的深入教程
查看教程
资源
查找开发资源并解答您的问题
查看资源
