(beta) .torchxconfig file¶
You can store the scheduler run cfg (run configs) for your project
by storing them in the .torchxconfig
file. Currently this file is only read
and honored when running the component from the CLI.
CLI Usage¶
cd
into the directory where you want the.torchxconfig
file to be dropped. The CLI only picks up.torchxconfig
files from the current-working-directory (CWD) so chose a directory where you typically runtorchx
from. Typically this is the root of your project directory.Generate the config file by running
$ torchx configure -s <comma,delimited,scheduler,names> # -- or for all registered schedulers -- $ torchx configure
If you specified
-s local_cwd,kubernetes
, you should see a.torchxconfig
file as shown below:$ cat .torchxconfig [local_cwd] [kubernetes] queue = #FIXME:(str) Volcano queue to schedule job in
.torchxconfig
in in INI format and the section names map to the scheduler names. Each section contains the run configs for the scheduler as$key = $value
pairs. You may find that certain schedulers have empty sections, this means that the scheduler defines sensible defaults for all its run configs hence no run configs are required at runtime. If you’d like to override the default you can add them. TIP: To see all the run options for a scheduler usetorchx runopts <scheduler_name>
.The sections with
FIXME
placeholders are run configs that are required by the scheduler. Replace these with the values that apply to you.IMPORTANT: If you are happy with the scheduler provided defaults for a particular run config, you should not redundantly specity them in
.torchxconfig
with the same default value. This is because the scheduler may decide to change the default value at a later date which would leave you with a stale default.Now you can run your component without having to specify the scheduler run configs each time. Just make sure the directory you are running
torchx
cli from actually has.torchxconfig
!$ ls .torchxconfig .torchxconfig $ torchx run -s local_cwd ./my_component.py:train
Programmatic Usage¶
Unlike the cli, .torchxconfig
file is not picked up automatically
from CWD
if you are programmatically running your component with torchx.runner.Runner
You’ll have to manually specify the directory containing .torchxconfig
Below is an example
from torchx.runner import get_runner
from torchx.runner.config import apply
import torchx.specs as specs
def my_component(a: int) -> specs.AppDef:
# <... component body omitted for brevity ...>
pass
scheduler = "local_cwd"
cfg = {"log_dir": "/these/take/outmost/precedence"}
apply(scheduler, cfg, dirs=["/home/bob"]) # looks for /home/bob/.torchxconfig
get_runner().run(my_component(1), scheduler, cfg)
You may also specify multiple directories (in preceding order) which is useful when you want to keep personal config overrides on top of a project defined default.
Config API Functions¶
- torchx.runner.config.apply(scheduler: str, cfg: Dict[str, Optional[Union[str, int, float, bool, List[str]]]], dirs: Optional[List[str]] = None) → None[source]¶
Loads a
.torchxconfig
INI file from the specified directories in preceding order and applies the run configs for the scheduler onto the givencfg
.If no
dirs
is specified, then it looks for.torchxconfig
in the current working directory. If a specified directory does not have.torchxconfig
then it is ignored.Note that the configs already present in the given
cfg
take precedence over the ones in the config file and only new configs are added. The same holds true for the configs loaded in list order.For instance if
cfg={"foo":"bar"}
and the config file is:# dir_1/.torchxconfig [local_cwd] foo = baz hello = world # dir_2/.torchxconfig [local_cwd] hello = bob
Then after the method call,
cfg={"foo":"bar","hello":"world"}
- torchx.runner.config.load(scheduler: str, f: TextIO, cfg: Dict[str, Optional[Union[str, int, float, bool, List[str]]]]) → None[source]¶
loads the section
[{scheduler}]
from the given configfilef
(in .INI format) into the providedruncfg
, only adding configs that are NOT currently in the givenruncfg
(e.g. does not override existing values inruncfg
). If no section is found, does nothing.
- torchx.runner.config.dump(f: TextIO, schedulers: Optional[List[str]] = None, required_only: bool = False) → None[source]¶
Dumps a default INI-style config template containing the :py:class:torchx.specs.runopts for the given scheduler names into the file-like object specified by
f
. If noschedulers
are specified dumps all known registered schedulers.Optional runopts are pre-filled with their default values. Required runopts are set with a
FIXME: ...
placeholder. To only dump required runopts passrequired_only=True
.Each scheduler’s runopts are written in the section called
[{scheduler_name}]
.For example:
[kubernetes] namespace = default queue = #FIXME (str)Volcano queue to schedule job in
- Raises
ValueError – if given a scheduler name that is not known
