目录
torchtext.data.metrics
bleu_score
torchtext.data.metrics.bleu_score(candidate_corpus, references_corpus, max_n=4, weights=[0.25, 0.25, 0.25, 0.25])[source]
Computes the BLEU score between a candidate translation corpus and a references translation corpus. Based on https://www.aclweb.org/anthology/P02-1040.pdf
Parameters:
  • candidate_corpus – an iterable of candidate translations. Each translation is an iterable of tokens
  • references_corpus – an iterable of iterables of reference translations. Each translation is an iterable of tokens
  • max_n – the maximum n-gram we want to use. E.g. if max_n=3, we will use unigrams, bigrams and trigrams
  • weights – a list of weights used for each n-gram category (uniform by default)
Examples
>>> from torchtext.data.metrics import bleu_score
>>> candidate_corpus = [['My', 'full', 'pytorch', 'test'], ['Another', 'Sentence']]
>>> references_corpus = [[['My', 'full', 'pytorch', 'test'], ['Completely', 'Different']], [['No', 'Match']]]
>>> bleu_score(candidate_corpus, references_corpus)
    0.8408964276313782
文档
访问 PyTorch 的全面开发人员文档
查看文档
教程
获取面向初学者和高级开发人员的深入教程
查看教程
资源
查找开发资源并解答您的问题
查看资源
APP信息
