目录
T5-Base Model for Summarization, Sentiment Classification, and Translation
Author: Pendo Abbo
Overview
This tutorial demonstrates how to use a pre-trained T5 Model for summarization, sentiment classification, and translation tasks. We will demonstrate how to use the torchtext library to:
  1. Build a text pre-processing pipeline for a T5 model
  2. Instantiate a pre-trained T5 model with base configuration
  3. Read in the CNNDM, IMDB, and Multi30k datasets and pre-process their texts in preparation for the model
  4. Perform text summarization, sentiment classification, and translation
Common imports
import torch
import torch.nn.functional as F
DEVICE = torch.device("cuda") if torch.cuda.is_available() else torch.device("cpu")
Data Transformation
The T5 model does not work with raw text. Instead, it requires the text to be transformed into numerical form in order to perform training and inference. The following transformations are required for the T5 model:
  1. Tokenize text
  2. Convert tokens into (integer) IDs
  3. Truncate the sequences to a specified maximum length
  4. Add end-of-sequence (EOS) and padding token IDs
T5 uses a SentencePiece model for text tokenization. Below, we use a pre-trained SentencePiece model to build the text pre-processing pipeline using torchtext’s T5Transform. Note that the transform supports both batched and non-batched text input (i.e. one can either pass a single sentence or a list of sentences), however the T5 model expects the input to be batched.
from torchtext.prototype.models import T5Transform
padding_idx = 0
eos_idx = 1
max_seq_len = 512
t5_sp_model_path = "https://download.pytorch.org/models/text/t5_tokenizer_base.model"
transform = T5Transform(
    sp_model_path=t5_sp_model_path,
    max_seq_len=max_seq_len,
    eos_idx=eos_idx,
    padding_idx=padding_idx,
Alternatively, we can also use the transform shipped with the pre-trained models that does all of the above out-of-the-box
from torchtext.prototype.models import T5_BASE_GENERATION
transform = T5_BASE_GENERATION.transform()
Model Preparation
torchtext provides SOTA pre-trained models that can be used directly for NLP tasks or fine-tuned on downstream tasks. Below we use the pre-trained T5 model with standard base configuration to perform text summarization, sentiment classification, and translation. For additional details on available pre-trained models, please refer to documentation at https://pytorch.org/text/main/models.html
t5_base = T5_BASE_GENERATION
transform = t5_base.transform()
model = t5_base.get_model()
model.eval()
model.to(DEVICE)
Sequence Generator
We can define a sequence generator to produce an output sequence based on the input sequence provided. This calls on the model’s encoder and decoder, and iteratively expands the decoded sequences until the end-of-sequence token is generated for all sequences in the batch. The generate method shown below uses a beam search to generate the sequences. Larger beam sizes can result in better generation at the cost of computational complexity, and a beam size of 1 is equivalent to a greedy decoder.
from torch import Tensor
from torchtext.prototype.models import T5Model
def beam_search(
    beam_size: int,
    step: int,
    bsz: int,
    decoder_output: Tensor,
    decoder_tokens: Tensor,
    scores: Tensor,
    incomplete_sentences: Tensor,
    probs = F.log_softmax(decoder_output[:, -1], dim=-1)
    top = torch.topk(probs, beam_size)
    # N is number of sequences in decoder_tokens, L is length of sequences, B is beam_size
    # decoder_tokens has shape (N,L) -> (N,B,L)
    # top.indices has shape (N,B) - > (N,B,1)
    # x has shape (N,B,L+1)
    # note that when step == 1, N = batch_size, and when step > 1, N = batch_size * beam_size
    x = torch.cat([decoder_tokens.unsqueeze(1).repeat(1, beam_size, 1), top.indices.unsqueeze(-1)], dim=-1)
    # beams are first created for a given sequence
    if step == 1:
        # x has shape (batch_size, B, L+1) -> (batch_size * B, L+1)
        # new_scores has shape (batch_size,B)
        # incomplete_sentences has shape (batch_size * B) = (N)
        new_decoder_tokens = x.view(-1, step + 1)
        new_scores = top.values
        new_incomplete_sentences = incomplete_sentences
    # beams already exist, want to expand each beam into possible new tokens to add
    # and for all expanded beams beloning to the same sequences, choose the top k
    else:
        # scores has shape (batch_size,B) -> (N,1) -> (N,B)
        # top.values has shape (N,B)
        # new_scores has shape (N,B) -> (batch_size, B^2)
        new_scores = (scores.view(-1, 1).repeat(1, beam_size) + top.values).view(bsz, -1)
        # v, i have shapes (batch_size, B)
        v, i = torch.topk(new_scores, beam_size)
        # x has shape (N,B,L+1) -> (batch_size, B, L+1)
        # i has shape (batch_size, B) -> (batch_size, B, L+1)
        # new_decoder_tokens has shape (batch_size, B, L+1) -> (N, L)
        x = x.view(bsz, -1, step + 1)
        new_decoder_tokens = x.gather(index=i.unsqueeze(-1).repeat(1, 1, step + 1), dim=1).view(-1, step + 1)
        # need to update incomplete sentences in case one of the beams was kicked out
        # y has shape (N) -> (N, 1) -> (N, B) -> (batch_size, B^2)
        y = incomplete_sentences.unsqueeze(-1).repeat(1, beam_size).view(bsz, -1)
        # now can use i to extract those beams that were selected
        # new_incomplete_sentences has shape (batch_size, B^2) -> (batch_size, B) -> (N, 1) -> N
        new_incomplete_sentences = y.gather(index=i, dim=1).view(bsz * beam_size, 1).squeeze(-1)
        # new_scores has shape (batch_size, B)
        new_scores = v
    return new_decoder_tokens, new_scores, new_incomplete_sentences
def generate(encoder_tokens: Tensor, eos_idx: int, model: T5Model, beam_size: int) -> Tensor:
    # pass tokens through encoder
    bsz = encoder_tokens.size(0)
    encoder_padding_mask = encoder_tokens.eq(model.padding_idx)
    encoder_embeddings = model.dropout1(model.token_embeddings(encoder_tokens))
    encoder_output = model.encoder(encoder_embeddings, tgt_key_padding_mask=encoder_padding_mask)[0]
    encoder_output = model.norm1(encoder_output)
    encoder_output = model.dropout2(encoder_output)
    # initialize decoder input sequence; T5 uses padding index as starter index to decoder sequence
    decoder_tokens = torch.ones((bsz, 1), dtype=torch.long) * model.padding_idx
    scores = torch.zeros((bsz, beam_size))
    # mask to keep track of sequences for which the decoder has not produced an end-of-sequence token yet
    incomplete_sentences = torch.ones(bsz * beam_size, dtype=torch.long)
    # iteratively generate output sequence until all sequences in the batch have generated the end-of-sequence token
    for step in range(model.config.max_seq_len):
        if step == 1:
            # duplicate and order encoder output so that each beam is treated as its own independent sequence
            new_order = torch.arange(bsz).view(-1, 1).repeat(1, beam_size).view(-1)
            new_order = new_order.to(encoder_tokens.device).long()
            encoder_output = encoder_output.index_select(0, new_order)
            encoder_padding_mask = encoder_padding_mask.index_select(0, new_order)
        # causal mask and padding mask for decoder sequence
        tgt_len = decoder_tokens.shape[1]
        decoder_mask = torch.triu(torch.ones((tgt_len, tgt_len), dtype=torch.float64), diagonal=1).bool()
        decoder_padding_mask = decoder_tokens.eq(model.padding_idx)
        # T5 implemention uses padding idx to start sequence. Want to ignore this when masking
        decoder_padding_mask[:, 0] = False
        # pass decoder sequence through decoder
        decoder_embeddings = model.dropout3(model.token_embeddings(decoder_tokens))
        decoder_output = model.decoder(
            decoder_embeddings,
            memory=encoder_output,
            tgt_mask=decoder_mask,
            tgt_key_padding_mask=decoder_padding_mask,
            memory_key_padding_mask=encoder_padding_mask,
        )[0]
        decoder_output = model.norm2(decoder_output)
        decoder_output = model.dropout4(decoder_output)
        decoder_output = decoder_output * (model.config.embedding_dim ** -0.5)
        decoder_output = model.lm_head(decoder_output)
        decoder_tokens, scores, incomplete_sentences = beam_search(
            beam_size, step + 1, bsz, decoder_output, decoder_tokens, scores, incomplete_sentences
        # ignore newest tokens for sentences that are already complete
        decoder_tokens[:, -1] *= incomplete_sentences
        # update incomplete_sentences to remove those that were just ended
        incomplete_sentences = incomplete_sentences - (decoder_tokens[:, -1] == eos_idx).long()
        # early stop if all sentences have been ended
        if (incomplete_sentences == 0).all():
            break
    # take most likely sequence
    decoder_tokens = decoder_tokens.view(bsz, beam_size, -1)[:, 0, :]
    return decoder_tokens
Datasets
torchtext provides several standard NLP datasets. For a complete list, refer to the documentation at https://pytorch.org/text/stable/datasets.html. These datasets are built using composable torchdata datapipes and hence support standard flow-control and mapping/transformation using user defined functions and transforms.
Below, we demonstrate how to pre-process the CNNDM dataset to include the prefix necessary for the model to indentify the task it is performing. The CNNDM dataset has a train, validation, and test split. Below we demo on the test split.
The T5 model uses the prefix “summarize” for text summarization. For more information on task prefixes, please visit Appendix D of the T5 Paper at https://arxiv.org/pdf/1910.10683.pdf
Note
Using datapipes is still currently subject to a few caveats. If you wish to extend this example to include shuffling, multi-processing, or distributed learning, please see this note for further instructions.
from functools import partial
from torch.utils.data import DataLoader
from torchtext.datasets import CNNDM
cnndm_batch_size = 5
cnndm_datapipe = CNNDM(split="test")
task = "summarize"
def apply_prefix(task, x):
    return f"{task}: " + x[0], x[1]
cnndm_datapipe = cnndm_datapipe.map(partial(apply_prefix, task))
cnndm_datapipe = cnndm_datapipe.batch(cnndm_batch_size)
cnndm_datapipe = cnndm_datapipe.rows2columnar(["article", "abstract"])
cnndm_dataloader = DataLoader(cnndm_datapipe, batch_size=None)
Alternately we can also use batched API (i.e apply the prefix on the whole batch)
def batch_prefix(task, x):
 return {
     "article": [f'{task}: ' + y for y in x["article"]],
     "abstract": x["abstract"]
task = 'summarize'
cnndm_datapipe = cnndm_datapipe.batch(cnndm_batch_size).rows2columnar(["article", "abstract"])
cnndm_datapipe = cnndm_datapipe.map(partial(batch_prefix, task))
We can also load the IMDB dataset, which will be used to demonstrate sentiment classification using the T5 model. This dataset has a train and test split. Below we demo on the test split.
The T5 model was trained on the SST2 dataset (also available in torchtext) for sentiment classification using the prefix “sst2 sentence”. Therefore, we will use this prefix to perform sentiment classification on the IMDB dataset.
from torchtext.datasets import IMDB
imdb_batch_size = 3
imdb_datapipe = IMDB(split="test")
task = "sst2 sentence"
labels = {"neg": "negative", "pos": "positive"}
def process_labels(labels, x):
    return x[1], labels[x[0]]
imdb_datapipe = imdb_datapipe.map(partial(process_labels, labels))
imdb_datapipe = imdb_datapipe.map(partial(apply_prefix, task))
imdb_datapipe = imdb_datapipe.batch(imdb_batch_size)
imdb_datapipe = imdb_datapipe.rows2columnar(["text", "label"])
imdb_dataloader = DataLoader(imdb_datapipe, batch_size=None)
Finally, we can also load the Multi30k dataset to demonstrate English to German translation using the T5 model. This dataset has a train, validation, and test split. Below we demo on the test split.
The T5 model uses the prefix “translate English to German” for this task.
from torchtext.datasets import Multi30k
multi_batch_size = 5
language_pair = ("en", "de")
multi_datapipe = Multi30k(split="test", language_pair=language_pair)
task = "translate English to German"
multi_datapipe = multi_datapipe.map(partial(apply_prefix, task))
multi_datapipe = multi_datapipe.batch(multi_batch_size)
multi_datapipe = multi_datapipe.rows2columnar(["english", "german"])
multi_dataloader = DataLoader(multi_datapipe, batch_size=None)
Generate Summaries
We can put all of the components together to generate summaries on the first batch of articles in the CNNDM test set using a beam size of 3.
batch = next(iter(cnndm_dataloader))
input_text = batch["article"]
target = batch["abstract"]
beam_size = 3
model_input = transform(input_text)
model_output = generate(model=model, encoder_tokens=model_input, eos_idx=eos_idx, beam_size=beam_size)
output_text = transform.decode(model_output.tolist())
for i in range(cnndm_batch_size):
    print(f"Example {i+1}:\n")
    print(f"prediction: {output_text[i]}\n")
    print(f"target: {target[i]}\n\n")
Summarization Output
Example 1:
prediction: the Palestinians become the 123rd member of the international criminal
court . the accession was marked by a ceremony at the Hague, where the court is based .
the ICC opened a preliminary examination into the situation in the occupied
Palestinian territory .
target: Membership gives the ICC jurisdiction over alleged crimes committed in
Palestinian territories since last June . Israel and the United States opposed the
move, which could open the door to war crimes investigations against Israelis .
Example 2:
prediction: a stray pooch has used up at least three of her own after being hit by a
car and buried in a field . the dog managed to stagger to a nearby farm, dirt-covered
and emaciated, where she was found . she suffered a dislocated jaw, leg injuries and a
caved-in sinus cavity -- and still requires surgery to help her breathe .
target: Theia, a bully breed mix, was apparently hit by a car, whacked with a hammer
and buried in a field . "She's a true miracle dog and she deserves a good life," says
Sara Mellado, who is looking for a home for Theia .
Example 3:
prediction: mohammad Javad Zarif arrived in Iran on a sunny friday morning . he has gone
a long way to bring Iran in from the cold and allow it to rejoin the international
community . but there are some facts about him that are less well-known .
target: Mohammad Javad Zarif has spent more time with John Kerry than any other
foreign minister . He once participated in a takeover of the Iranian Consulate in San
Francisco . The Iranian foreign minister tweets in English .
Example 4:
prediction: five americans were monitored for three weeks after being exposed to Ebola in
west africa . one of the five had a heart-related issue and has been discharged but hasn't
left the area . they are clinicians for Partners in Health, a Boston-based aid group .
target: 17 Americans were exposed to the Ebola virus while in Sierra Leone in March .
Another person was diagnosed with the disease and taken to hospital in Maryland .
National Institutes of Health says the patient is in fair condition after weeks of
treatment .
Example 5:
prediction: the student was identified during an investigation by campus police and
the office of student affairs . he admitted to placing the noose on the tree early
Wednesday morning . the incident is one of several recent racist events to affect
college students .
target: Student is no longer on Duke University campus and will face disciplinary
review . School officials identified student during investigation and the person
admitted to hanging the noose, Duke says . The noose, made of rope, was discovered on
campus about 2 a.m.
Generate Sentiment Classifications
Similarly, we can use the model to generate sentiment classifications on the first batch of reviews from the IMDB test set using a beam size of 1.
batch = next(iter(imdb_dataloader))
input_text = batch["text"]
target = batch["label"]
beam_size = 1
for i in range(imdb_batch_size):
    print(f"input_text: {input_text[i]}\n")
Sentiment Output
Example 1:
input_text: sst2 sentence: I love sci-fi and am willing to put up with a lot. Sci-fi
movies/TV are usually underfunded, under-appreciated and misunderstood. I tried to like
this, I really did, but it is to good TV sci-fi as Babylon 5 is to Star Trek (the original).
Silly prosthetics, cheap cardboard sets, stilted dialogues, CG that doesn't match the
background, and painfully one-dimensional characters cannot be overcome with a 'sci-fi'
setting. (I'm sure there are those of you out there who think Babylon 5 is good sci-fi TV.
It's not. It's clichéd and uninspiring.) While US viewers might like emotion and character
development, sci-fi is a genre that does not take itself seriously (cf. Star Trek). It may
treat important issues, yet not as a serious philosophy. It's really difficult to care about
the characters here as they are not simply foolish, just missing a spark of life. Their
actions and reactions are wooden and predictable, often painful to watch. The makers of Earth
KNOW it's rubbish as they have to always say "Gene Roddenberry's Earth..." otherwise people
would not continue watching. Roddenberry's ashes must be turning in their orbit as this dull,
cheap, poorly edited (watching it without advert breaks really brings this home) trudging
Trabant of a show lumbers into space. Spoiler. So, kill off a main character. And then bring
him back as another actor. Jeeez. Dallas all over again.
prediction: negative
target: negative
Example 2:
input_text: sst2 sentence: Worth the entertainment value of a rental, especially if you like
action movies. This one features the usual car chases, fights with the great Van Damme kick
style, shooting battles with the 40 shell load shotgun, and even terrorist style bombs. All
of this is entertaining and competently handled but there is nothing that really blows you
away if you've seen your share before.<br /><br />The plot is made interesting by the
inclusion of a rabbit, which is clever but hardly profound. Many of the characters are
heavily stereotyped -- the angry veterans, the terrified illegal aliens, the crooked cops,
the indifferent feds, the bitchy tough lady station head, the crooked politician, the fat
federale who looks like he was typecast as the Mexican in a Hollywood movie from the 1940s.
All passably acted but again nothing special.<br /><br />I thought the main villains were
pretty well done and fairly well acted. By the end of the movie you certainly knew who the
good guys were and weren't. There was an emotional lift as the really bad ones got their just
deserts. Very simplistic, but then you weren't expecting Hamlet, right? The only thing I found
really annoying was the constant cuts to VDs daughter during the last fight scene.<br /><br />
Not bad. Not good. Passable 4.
target: negative
Example 3:
input_text: sst2 sentence: its a totally average film with a few semi-alright action sequences
that make the plot seem a little better and remind the viewer of the classic van dam films.
parts of the plot don't make sense and seem to be added in to use up time. the end plot is that
of a very basic type that doesn't leave the viewer guessing and any twists are obvious from the
beginning. the end scene with the flask backs don't make sense as they are added in and seem to
have little relevance to the history of van dam's character. not really worth watching again,
bit disappointed in the end production, even though it is apparent it was shot on a low budget
certain shots and sections in the film are of poor directed quality.
target: negative
Generate Translations
Finally, we can also use the model to generate English to German translations on the first batch of examples from the Multi30k test set using a beam size of 4.
batch = next(iter(multi_dataloader))
input_text = batch["english"]
target = batch["german"]
beam_size = 4
for i in range(multi_batch_size):
Translation Output
Example 1:
input_text: translate English to German: A man in an orange hat starring at something.
prediction: Ein Mann in einem orangen Hut, der an etwas schaut.
target: Ein Mann mit einem orangefarbenen Hut, der etwas anstarrt.
Example 2:
input_text: translate English to German: A Boston Terrier is running on lush green grass in front of a white fence.
prediction: Ein Boston Terrier läuft auf üppigem grünem Gras vor einem weißen Zaun.
target: Ein Boston Terrier läuft über saftig-grünes Gras vor einem weißen Zaun.
Example 3:
input_text: translate English to German: A girl in karate uniform breaking a stick with a front kick.
prediction: Ein Mädchen in Karate-Uniform bricht einen Stöck mit einem Frontkick.
target: Ein Mädchen in einem Karateanzug bricht ein Brett mit einem Tritt.
Example 4:
input_text: translate English to German: Five people wearing winter jackets and helmets stand in the snow, with snowmobiles in the background.
prediction: Fünf Menschen mit Winterjacken und Helmen stehen im Schnee, mit Schneemobilen im Hintergrund.
target: Fünf Leute in Winterjacken und mit Helmen stehen im Schnee mit Schneemobilen im Hintergrund.
Example 5:
input_text: translate English to German: People are fixing the roof of a house.
prediction: Die Leute fixieren das Dach eines Hauses.
target: Leute Reparieren das Dach eines Hauses.
Total running time of the script: ( 0 minutes 0.000 seconds)
Gallery generated by Sphinx-Gallery
文档
访问 PyTorch 的全面开发人员文档
查看文档
教程
获取面向初学者和高级开发人员的深入教程
查看教程
资源
查找开发资源并解答您的问题
查看资源
