目录
SST-2 Binary text classification with XLM-RoBERTa model
Author: Parmeet Bhatia
Overview
This tutorial demonstrates how to train a text classifier on SST-2 binary dataset using a pre-trained XLM-RoBERTa (XLM-R) model. We will show how to use torchtext library to:
  1. build text pre-processing pipeline for XLM-R model
  2. read SST-2 dataset and transform it using text and label transformation
  3. instantiate classification model using pre-trained XLM-R encoder
Common imports
import torch
import torch.nn as nn
DEVICE = torch.device("cuda") if torch.cuda.is_available() else torch.device("cpu")
Data Transformation
Models like XLM-R cannot work directly with raw text. The first step in training these models is to transform input text into tensor (numerical) form such that it can then be processed by models to make predictions. A standard way to process text is:
  1. Tokenize text
  2. Convert tokens into (integer) IDs
  3. Add any special tokens IDs
XLM-R uses sentencepiece model for text tokenization. Below, we use pre-trained sentencepiepce model along with corresponding vocabulary to build text pre-processing pipeline using torchtext’s transforms. The transforms are pipelined using torchtext.transforms.Sequential() which is similar to torch.nn.Sequential() but is torchscriptable. Note that the transforms support both batched and non-batched text inputs i.e, one can either pass a single sentence or list of sentences.
import torchtext.transforms as T
from torch.hub import load_state_dict_from_url
padding_idx = 1
bos_idx = 0
eos_idx = 2
max_seq_len = 256
xlmr_vocab_path = r"https://download.pytorch.org/models/text/xlmr.vocab.pt"
xlmr_spm_model_path = r"https://download.pytorch.org/models/text/xlmr.sentencepiece.bpe.model"
text_transform = T.Sequential(
    T.SentencePieceTokenizer(xlmr_spm_model_path),
    T.VocabTransform(load_state_dict_from_url(xlmr_vocab_path)),
    T.Truncate(max_seq_len - 2),
    T.AddToken(token=bos_idx, begin=True),
    T.AddToken(token=eos_idx, begin=False),
Alternately we can also use transform shipped with pre-trained model that does all of the above out-of-the-box
text_transform = XLMR_BASE_ENCODER.transform()
Dataset
torchtext provides several standard NLP datasets. For complete list, refer to documentation at https://pytorch.org/text/stable/datasets.html. These datasets are build using composable torchdata datapipes and hence support standard flow-control and mapping/transformation using user defined functions and transforms. Below, we demonstrate how to use text and label processing transforms to pre-process the SST-2 dataset.
from torchtext.datasets import SST2
from torch.utils.data import DataLoader
batch_size = 16
train_datapipe = SST2(split='train')
dev_datapipe = SST2(split='dev')
# Transform the raw dataset using non-batched API (i.e apply transformation line by line)
train_datapipe = train_datapipe.map(lambda x: (text_transform(x[0]), x[1]))
train_datapipe = train_datapipe.batch(batch_size)
train_datapipe = train_datapipe.rows2columnar(["token_ids", "target"])
train_dataloader = DataLoader(train_datapipe, batch_size=None)
dev_datapipe = dev_datapipe.map(lambda x: (text_transform(x[0]), x[1]))
dev_datapipe = dev_datapipe.batch(batch_size)
dev_datapipe = dev_datapipe.rows2columnar(["token_ids", "target"])
dev_dataloader = DataLoader(dev_datapipe, batch_size=None)
Alternately we can also use batched API (i.e apply transformation on the whole batch)
train_datapipe = train_datapipe.batch(batch_size).rows2columnar(["text", "label"])
train_datapipe = train_datapipe.map(lambda x: {"token_ids": text_transform(x["text"]), "target": label_transform(x["label"])})
dev_datapipe = dev_datapipe.batch(batch_size).rows2columnar(["text", "label"])
dev_datapipe = dev_datapipe.map(lambda x: {"token_ids": text_transform(x["text"]), "target": label_transform(x["label"])})
Model Preparation
torchtext provides SOTA pre-trained models that can be used to fine-tune on downstream NLP tasks. Below we use pre-trained XLM-R encoder with standard base architecture and attach a classifier head to fine-tune it on SST-2 binary classification task. We shall use standard Classifier head from the library, but users can define their own appropriate task head and attach it to the pre-trained encoder. For additional details on available pre-trained models, please refer to documentation at https://pytorch.org/text/main/models.html
num_classes = 2
input_dim = 768
from torchtext.models import RobertaClassificationHead, XLMR_BASE_ENCODER
classifier_head = RobertaClassificationHead(num_classes=num_classes, input_dim=input_dim)
model = XLMR_BASE_ENCODER.get_model(head=classifier_head)
model.to(DEVICE)
Training methods
Let’s now define the standard optimizer and training criteria as well as some helper functions for training and evaluation
import torchtext.functional as F
from torch.optim import AdamW
learning_rate = 1e-5
optim = AdamW(model.parameters(), lr=learning_rate)
criteria = nn.CrossEntropyLoss()
def train_step(input, target):
    output = model(input)
    loss = criteria(output, target)
    optim.zero_grad()
    loss.backward()
    optim.step()
def eval_step(input, target):
    loss = criteria(output, target).item()
    return float(loss), (output.argmax(1) == target).type(torch.float).sum().item()
def evaluate():
    model.eval()
    total_loss = 0
    correct_predictions = 0
    total_predictions = 0
    counter = 0
    with torch.no_grad():
        for batch in dev_dataloader:
            input = F.to_tensor(batch['token_ids'], padding_value=padding_idx).to(DEVICE)
            target = torch.tensor(batch['target']).to(DEVICE)
            loss, predictions = eval_step(input, target)
            total_loss += loss
            correct_predictions += predictions
            total_predictions += len(target)
            counter += 1
    return total_loss / counter, correct_predictions / total_predictions
Train
Now we have all the ingredients to train our classification model. Note that we are able to directly iterate on our dataset object without using DataLoader. Our pre-process dataset shall yield batches of data already, thanks to the batching datapipe we have applied. For distributed training, we would need to use DataLoader to take care of data-sharding.
num_epochs = 1
for e in range(num_epochs):
    for batch in train_dataloader:
    loss, accuracy = evaluate()
    print("Epoch = [{}], loss = [{}], accuracy = [{}]".format(e, loss, accuracy))
Output
100%|██████████|5.07M/5.07M [00:00<00:00, 40.8MB/s]
Downloading: "https://download.pytorch.org/models/text/xlmr.vocab.pt" to /root/.cache/torch/hub/checkpoints/xlmr.vocab.pt
100%|██████████|4.85M/4.85M [00:00<00:00, 16.8MB/s]
Downloading: "https://download.pytorch.org/models/text/xlmr.base.encoder.pt" to /root/.cache/torch/hub/checkpoints/xlmr.base.encoder.pt
100%|██████████|1.03G/1.03G [00:26<00:00, 47.1MB/s]
Epoch = [0], loss = [0.2629831412637776], accuracy = [0.9105504587155964]
Total running time of the script: ( 0 minutes 0.000 seconds)
Gallery generated by Sphinx-Gallery
文档
访问 PyTorch 的全面开发人员文档
查看文档
教程
获取面向初学者和高级开发人员的深入教程
查看教程
资源
查找开发资源并解答您的问题
查看资源
