目录
Forced Alignment with Wav2Vec2
Author: Moto Hira
This tutorial shows how to align transcript to speech with torchaudio, using CTC segmentation algorithm described in CTC-Segmentation of Large Corpora for German End-to-end Speech Recognition.
import torch
import torchaudio
print(torch.__version__)
print(torchaudio.__version__)
device = torch.device("cuda" if torch.cuda.is_available() else "cpu")
print(device)
1.13.0
0.13.0
cpu
Overview
The process of alignment looks like the following.
  1. Estimate the frame-wise label probability from audio waveform
  2. Generate the trellis matrix which represents the probability of labels aligned at time step.
  3. Find the most likely path from the trellis matrix.
In this example, we use torchaudio’s Wav2Vec2 model for acoustic feature extraction.
Preparation
First we import the necessary packages, and fetch data that we work on.
# %matplotlib inline
from dataclasses import dataclass
import IPython
import matplotlib
matplotlib.rcParams["figure.figsize"] = [16.0, 4.8]
torch.random.manual_seed(0)
SPEECH_FILE = torchaudio.utils.download_asset("tutorial-assets/Lab41-SRI-VOiCES-src-sp0307-ch127535-sg0042.wav")
Generate frame-wise label probability
The first step is to generate the label class porbability of each aduio frame. We can use a Wav2Vec2 model that is trained for ASR. Here we use torchaudio.pipelines.WAV2VEC2_ASR_BASE_960H().
torchaudio provides easy access to pretrained models with associated labels.
Note
In the subsequent sections, we will compute the probability in log-domain to avoid numerical instability. For this purpose, we normalize the emission with torch.log_softmax().
bundle = torchaudio.pipelines.WAV2VEC2_ASR_BASE_960H
model = bundle.get_model().to(device)
labels = bundle.get_labels()
with torch.inference_mode():
    waveform, _ = torchaudio.load(SPEECH_FILE)
    emissions, _ = model(waveform.to(device))
    emissions = torch.log_softmax(emissions, dim=-1)
emission = emissions[0].cpu().detach()
Visualization
print(labels)
plt.imshow(emission.T)
plt.colorbar()
plt.title("Frame-wise class probability")
plt.xlabel("Time")
plt.ylabel("Labels")
plt.show()
('-', '|', 'E', 'T', 'A', 'O', 'N', 'I', 'H', 'S', 'R', 'D', 'L', 'U', 'M', 'W', 'C', 'F', 'G', 'Y', 'P', 'B', 'V', 'K', "'", 'X', 'J', 'Q', 'Z')
Generate alignment probability (trellis)
From the emission matrix, next we generate the trellis which represents the probability of transcript labels occur at each time frame.
Trellis is 2D matrix with time axis and label axis. The label axis represents the transcript that we are aligning. In the following, we use \(t\) to denote the index in time axis and \(j\) to denote the index in label axis. \(c_j\) represents the label at label index \(j\).
To generate, the probability of time step \(t+1\), we look at the trellis from time step \(t\) and emission at time step \(t+1\). There are two path to reach to time step \(t+1\) with label \(c_{j+1}\). The first one is the case where the label was \(c_{j+1}\) at \(t\) and there was no label change from \(t\) to \(t+1\). The other case is where the label was \(c_j\) at \(t\) and it transitioned to the next label \(c_{j+1}\) at \(t+1\).
The follwoing diagram illustrates this transition.
https://download.pytorch.org/torchaudio/tutorial-assets/ctc-forward.png
Since we are looking for the most likely transitions, we take the more likely path for the value of \(k_{(t+1, j+1)}\), that is
\(k_{(t+1, j+1)} = max( k_{(t, j)} p(t+1, c_{j+1}), k_{(t, j+1)} p(t+1, repeat) )\)
where \(k\) represents is trellis matrix, and \(p(t, c_j)\) represents the probability of label \(c_j\) at time step \(t\). \(repeat\) represents the blank token from CTC formulation. (For the detail of CTC algorithm, please refer to the Sequence Modeling with CTC [distill.pub])
transcript = "I|HAD|THAT|CURIOSITY|BESIDE|ME|AT|THIS|MOMENT"
dictionary = {c: i for i, c in enumerate(labels)}
tokens = [dictionary[c] for c in transcript]
print(list(zip(transcript, tokens)))
def get_trellis(emission, tokens, blank_id=0):
    num_frame = emission.size(0)
    num_tokens = len(tokens)
    # Trellis has extra diemsions for both time axis and tokens.
    # The extra dim for tokens represents <SoS> (start-of-sentence)
    # The extra dim for time axis is for simplification of the code.
    trellis = torch.empty((num_frame + 1, num_tokens + 1))
    trellis[0, 0] = 0
    trellis[1:, 0] = torch.cumsum(emission[:, 0], 0)
    trellis[0, -num_tokens:] = -float("inf")
    trellis[-num_tokens:, 0] = float("inf")
    for t in range(num_frame):
        trellis[t + 1, 1:] = torch.maximum(
            # Score for staying at the same token
            trellis[t, 1:] + emission[t, blank_id],
            # Score for changing to the next token
            trellis[t, :-1] + emission[t, tokens],
    return trellis
trellis = get_trellis(emission, tokens)
[('I', 7), ('|', 1), ('H', 8), ('A', 4), ('D', 11), ('|', 1), ('T', 3), ('H', 8), ('A', 4), ('T', 3), ('|', 1), ('C', 16), ('U', 13), ('R', 10), ('I', 7), ('O', 5), ('S', 9), ('I', 7), ('T', 3), ('Y', 19), ('|', 1), ('B', 21), ('E', 2), ('S', 9), ('I', 7), ('D', 11), ('E', 2), ('|', 1), ('M', 14), ('E', 2), ('|', 1), ('A', 4), ('T', 3), ('|', 1), ('T', 3), ('H', 8), ('I', 7), ('S', 9), ('|', 1), ('M', 14), ('O', 5), ('M', 14), ('E', 2), ('N', 6), ('T', 3)]
Visualization
plt.imshow(trellis[1:, 1:].T, origin="lower")
plt.annotate("- Inf", (trellis.size(1) / 5, trellis.size(1) / 1.5))
plt.colorbar()
plt.show()
forced alignment tutorial
In the above visualization, we can see that there is a trace of high probability crossing the matrix diagonally.
Find the most likely path (backtracking)
Once the trellis is generated, we will traverse it following the elements with high probability.
We will start from the last label index with the time step of highest probability, then, we traverse back in time, picking stay (\(c_j \rightarrow c_j\)) or transition (\(c_j \rightarrow c_{j+1}\)), based on the post-transition probability \(k_{t, j} p(t+1, c_{j+1})\) or \(k_{t, j+1} p(t+1, repeat)\).
Transition is done once the label reaches the beginning.
The trellis matrix is used for path-finding, but for the final probability of each segment, we take the frame-wise probability from emission matrix.
@dataclass
class Point:
    token_index: int
    time_index: int
    score: float
def backtrack(trellis, emission, tokens, blank_id=0):
    # Note:
    # j and t are indices for trellis, which has extra dimensions
    # for time and tokens at the beginning.
    # When referring to time frame index `T` in trellis,
    # the corresponding index in emission is `T-1`.
    # Similarly, when referring to token index `J` in trellis,
    # the corresponding index in transcript is `J-1`.
    j = trellis.size(1) - 1
    t_start = torch.argmax(trellis[:, j]).item()
    path = []
    for t in range(t_start, 0, -1):
        # 1. Figure out if the current position was stay or change
        # Note (again):
        # `emission[J-1]` is the emission at time frame `J` of trellis dimension.
        # Score for token staying the same from time frame J-1 to T.
        stayed = trellis[t - 1, j] + emission[t - 1, blank_id]
        # Score for token changing from C-1 at T-1 to J at T.
        changed = trellis[t - 1, j - 1] + emission[t - 1, tokens[j - 1]]
        # 2. Store the path with frame-wise probability.
        prob = emission[t - 1, tokens[j - 1] if changed > stayed else 0].exp().item()
        # Return token index and time index in non-trellis coordinate.
        path.append(Point(j - 1, t - 1, prob))
        # 3. Update the token
        if changed > stayed:
            j -= 1
            if j == 0:
                break
    else:
        raise ValueError("Failed to align")
    return path[::-1]
path = backtrack(trellis, emission, tokens)
for p in path:
    print(p)
Point(token_index=0, time_index=30, score=0.9999842643737793)
Point(token_index=0, time_index=31, score=0.9846959710121155)
Point(token_index=0, time_index=32, score=0.9999706745147705)
Point(token_index=0, time_index=33, score=0.15398800373077393)
Point(token_index=1, time_index=34, score=0.9999173879623413)
Point(token_index=1, time_index=35, score=0.6080105900764465)
Point(token_index=2, time_index=36, score=0.9997721314430237)
Point(token_index=2, time_index=37, score=0.9997127652168274)
Point(token_index=3, time_index=38, score=0.9999358654022217)
Point(token_index=3, time_index=39, score=0.9861598610877991)
Point(token_index=4, time_index=40, score=0.9238577485084534)
Point(token_index=4, time_index=41, score=0.9257409572601318)
Point(token_index=4, time_index=42, score=0.01566212624311447)
Point(token_index=5, time_index=43, score=0.9998378753662109)
Point(token_index=6, time_index=44, score=0.9988443851470947)
Point(token_index=6, time_index=45, score=0.10147196799516678)
Point(token_index=7, time_index=46, score=0.9999427795410156)
Point(token_index=7, time_index=47, score=0.9999943971633911)
Point(token_index=8, time_index=48, score=0.9979604482650757)
Point(token_index=8, time_index=49, score=0.03603758662939072)
Point(token_index=8, time_index=50, score=0.06163697689771652)
Point(token_index=9, time_index=51, score=4.3358733819331974e-05)
Point(token_index=10, time_index=52, score=0.9999799728393555)
Point(token_index=10, time_index=53, score=0.9967100620269775)
Point(token_index=10, time_index=54, score=0.9999256134033203)
Point(token_index=11, time_index=55, score=0.9999983310699463)
Point(token_index=11, time_index=56, score=0.9990687966346741)
Point(token_index=11, time_index=57, score=0.9999996423721313)
Point(token_index=11, time_index=58, score=0.9999996423721313)
Point(token_index=11, time_index=59, score=0.8457656502723694)
Point(token_index=12, time_index=60, score=0.9999996423721313)
Point(token_index=12, time_index=61, score=0.9996013045310974)
Point(token_index=13, time_index=62, score=0.999998927116394)
Point(token_index=13, time_index=63, score=0.0035240992438048124)
Point(token_index=13, time_index=64, score=1.0)
Point(token_index=13, time_index=65, score=1.0)
Point(token_index=14, time_index=66, score=0.9999915361404419)
Point(token_index=14, time_index=67, score=0.9971572160720825)
Point(token_index=14, time_index=68, score=0.9999990463256836)
Point(token_index=14, time_index=69, score=0.9999992847442627)
Point(token_index=14, time_index=70, score=0.9999997615814209)
Point(token_index=14, time_index=71, score=0.9999998807907104)
Point(token_index=14, time_index=72, score=0.9999880790710449)
Point(token_index=14, time_index=73, score=0.011424383148550987)
Point(token_index=15, time_index=74, score=0.9999977350234985)
Point(token_index=15, time_index=75, score=0.9996136426925659)
Point(token_index=15, time_index=76, score=0.999998927116394)
Point(token_index=15, time_index=77, score=0.9727645516395569)
Point(token_index=16, time_index=78, score=0.999998927116394)
Point(token_index=16, time_index=79, score=0.9949339032173157)
Point(token_index=16, time_index=80, score=0.999998927116394)
Point(token_index=16, time_index=81, score=0.9999121427536011)
Point(token_index=17, time_index=82, score=0.9999774694442749)
Point(token_index=17, time_index=83, score=0.6575831770896912)
Point(token_index=17, time_index=84, score=0.9984298348426819)
Point(token_index=18, time_index=85, score=0.9999876022338867)
Point(token_index=18, time_index=86, score=0.9993745684623718)
Point(token_index=18, time_index=87, score=0.9999988079071045)
Point(token_index=18, time_index=88, score=0.10426424443721771)
Point(token_index=19, time_index=89, score=0.9999969005584717)
Point(token_index=19, time_index=90, score=0.39782625436782837)
Point(token_index=20, time_index=91, score=0.9999932050704956)
Point(token_index=20, time_index=92, score=1.6989914684018004e-06)
Point(token_index=20, time_index=93, score=0.986134946346283)
Point(token_index=21, time_index=94, score=0.9999960660934448)
Point(token_index=21, time_index=95, score=0.9992731213569641)
Point(token_index=21, time_index=96, score=0.9993410706520081)
Point(token_index=22, time_index=97, score=0.9999983310699463)
Point(token_index=22, time_index=98, score=0.9999971389770508)
Point(token_index=22, time_index=99, score=0.9999998807907104)
Point(token_index=22, time_index=100, score=0.9999995231628418)
Point(token_index=23, time_index=101, score=0.9999732971191406)
Point(token_index=23, time_index=102, score=0.9983221888542175)
Point(token_index=23, time_index=103, score=0.9999991655349731)
Point(token_index=23, time_index=104, score=0.9999996423721313)
Point(token_index=23, time_index=105, score=0.9999998807907104)
Point(token_index=23, time_index=106, score=1.0)
Point(token_index=23, time_index=107, score=0.9998629093170166)
Point(token_index=24, time_index=108, score=0.9999980926513672)
Point(token_index=24, time_index=109, score=0.9988582134246826)
Point(token_index=25, time_index=110, score=0.9999798536300659)
Point(token_index=25, time_index=111, score=0.8573304414749146)
Point(token_index=26, time_index=112, score=0.9999847412109375)
Point(token_index=26, time_index=113, score=0.9870284795761108)
Point(token_index=26, time_index=114, score=1.9046094166697003e-05)
Point(token_index=27, time_index=115, score=0.9999794960021973)
Point(token_index=27, time_index=116, score=0.9998254776000977)
Point(token_index=28, time_index=117, score=0.9999990463256836)
Point(token_index=28, time_index=118, score=0.9999732971191406)
Point(token_index=28, time_index=119, score=0.0009001801954582334)
Point(token_index=29, time_index=120, score=0.999347984790802)
Point(token_index=29, time_index=121, score=0.9975457787513733)
Point(token_index=29, time_index=122, score=0.00030502272420562804)
Point(token_index=30, time_index=123, score=0.9999344348907471)
Point(token_index=30, time_index=124, score=6.078777914808597e-06)
Point(token_index=31, time_index=125, score=0.9833180904388428)
Point(token_index=32, time_index=126, score=0.9974581599235535)
Point(token_index=32, time_index=127, score=0.0008237161673605442)
Point(token_index=33, time_index=128, score=0.996515154838562)
Point(token_index=33, time_index=129, score=0.017463242635130882)
Point(token_index=34, time_index=130, score=0.9989172220230103)
Point(token_index=35, time_index=131, score=0.9999697208404541)
Point(token_index=35, time_index=132, score=0.9999842643737793)
Point(token_index=36, time_index=133, score=0.9997640252113342)
Point(token_index=36, time_index=134, score=0.5097627639770508)
Point(token_index=37, time_index=135, score=0.9998301267623901)
Point(token_index=37, time_index=136, score=0.08528485894203186)
Point(token_index=37, time_index=137, score=0.00407379399985075)
Point(token_index=38, time_index=138, score=0.9999815225601196)
Point(token_index=38, time_index=139, score=0.012051556259393692)
Point(token_index=38, time_index=140, score=0.9999980926513672)
Point(token_index=38, time_index=141, score=0.0005778882768936455)
Point(token_index=39, time_index=142, score=0.9999067783355713)
Point(token_index=39, time_index=143, score=0.9999960660934448)
Point(token_index=39, time_index=144, score=0.9999980926513672)
Point(token_index=40, time_index=145, score=0.9999916553497314)
Point(token_index=40, time_index=146, score=0.9971166849136353)
Point(token_index=40, time_index=147, score=0.9981802701950073)
Point(token_index=41, time_index=148, score=0.9999310970306396)
Point(token_index=41, time_index=149, score=0.98795086145401)
Point(token_index=41, time_index=150, score=0.9997627139091492)
Point(token_index=42, time_index=151, score=0.9999535083770752)
Point(token_index=43, time_index=152, score=0.9999715089797974)
Point(token_index=44, time_index=153, score=0.6811069846153259)
Visualization
def plot_trellis_with_path(trellis, path):
    # To plot trellis with path, we take advantage of 'nan' value
    trellis_with_path = trellis.clone()
    for _, p in enumerate(path):
        trellis_with_path[p.time_index, p.token_index] = float("nan")
    plt.imshow(trellis_with_path[1:, 1:].T, origin="lower")
plt.title("The path found by backtracking")
plt.show()
Looking good. Now this path contains repetations for the same labels, so let’s merge them to make it close to the original transcript.
When merging the multiple path points, we simply take the average probability for the merged segments.
# Merge the labels
@dataclass
class Segment:
    label: str
    start: int
    end: int
    score: float
    def __repr__(self):
        return f"{self.label}\t({self.score:4.2f}): [{self.start:5d}, {self.end:5d})"
    @property
    def length(self):
        return self.end - self.start
def merge_repeats(path):
    i1, i2 = 0, 0
    segments = []
    while i1 < len(path):
        while i2 < len(path) and path[i1].token_index == path[i2].token_index:
            i2 += 1
        score = sum(path[k].score for k in range(i1, i2)) / (i2 - i1)
        segments.append(
            Segment(
                transcript[path[i1].token_index],
                path[i1].time_index,
                path[i2 - 1].time_index + 1,
                score,
        i1 = i2
    return segments
segments = merge_repeats(path)
for seg in segments:
    print(seg)
I       (0.78): [   30,    34)
|       (0.80): [   34,    36)
H       (1.00): [   36,    38)
A       (0.99): [   38,    40)
D       (0.62): [   40,    43)
|       (1.00): [   43,    44)
T       (0.55): [   44,    46)
H       (1.00): [   46,    48)
A       (0.37): [   48,    51)
T       (0.00): [   51,    52)
|       (1.00): [   52,    55)
C       (0.97): [   55,    60)
U       (1.00): [   60,    62)
R       (0.75): [   62,    66)
I       (0.88): [   66,    74)
O       (0.99): [   74,    78)
S       (1.00): [   78,    82)
I       (0.89): [   82,    85)
T       (0.78): [   85,    89)
Y       (0.70): [   89,    91)
|       (0.66): [   91,    94)
B       (1.00): [   94,    97)
E       (1.00): [   97,   101)
S       (1.00): [  101,   108)
I       (1.00): [  108,   110)
D       (0.93): [  110,   112)
E       (0.66): [  112,   115)
|       (1.00): [  115,   117)
M       (0.67): [  117,   120)
E       (0.67): [  120,   123)
|       (0.50): [  123,   125)
A       (0.98): [  125,   126)
T       (0.50): [  126,   128)
|       (0.51): [  128,   130)
T       (1.00): [  130,   131)
H       (1.00): [  131,   133)
I       (0.75): [  133,   135)
S       (0.36): [  135,   138)
|       (0.50): [  138,   142)
M       (1.00): [  142,   145)
O       (1.00): [  145,   148)
M       (1.00): [  148,   151)
E       (1.00): [  151,   152)
N       (1.00): [  152,   153)
T       (0.68): [  153,   154)
Visualization
def plot_trellis_with_segments(trellis, segments, transcript):
    for i, seg in enumerate(segments):
        if seg.label != "|":
            trellis_with_path[seg.start + 1 : seg.end + 1, i + 1] = float("nan")
    fig, [ax1, ax2] = plt.subplots(2, 1, figsize=(16, 9.5))
    ax1.set_title("Path, label and probability for each label")
    ax1.imshow(trellis_with_path.T, origin="lower")
    ax1.set_xticks([])
            ax1.annotate(seg.label, (seg.start + 0.7, i + 0.3), weight="bold")
            ax1.annotate(f"{seg.score:.2f}", (seg.start - 0.3, i + 4.3))
    ax2.set_title("Label probability with and without repetation")
    xs, hs, ws = [], [], []
            xs.append((seg.end + seg.start) / 2 + 0.4)
            hs.append(seg.score)
            ws.append(seg.end - seg.start)
            ax2.annotate(seg.label, (seg.start + 0.8, -0.07), weight="bold")
    ax2.bar(xs, hs, width=ws, color="gray", alpha=0.5, edgecolor="black")
    xs, hs = [], []
    for p in path:
        label = transcript[p.token_index]
        if label != "|":
            xs.append(p.time_index + 1)
            hs.append(p.score)
    ax2.bar(xs, hs, width=0.5, alpha=0.5)
    ax2.axhline(0, color="black")
    ax2.set_xlim(ax1.get_xlim())
    ax2.set_ylim(-0.1, 1.1)
plt.tight_layout()
plt.show()
Path, label and probability for each label, Label probability with and without repetation
Looks good. Now let’s merge the words. The Wav2Vec2 model uses '|' as the word boundary, so we merge the segments before each occurance of '|'.
Then, finally, we segment the original audio into segmented audio and listen to them to see if the segmentation is correct.
# Merge words
def merge_words(segments, separator="|"):
    words = []
    i1, i2 = 0, 0
    while i1 < len(segments):
        if i2 >= len(segments) or segments[i2].label == separator:
            if i1 != i2:
                segs = segments[i1:i2]
                word = "".join([seg.label for seg in segs])
                score = sum(seg.score * seg.length for seg in segs) / sum(seg.length for seg in segs)
                words.append(Segment(word, segments[i1].start, segments[i2 - 1].end, score))
            i1 = i2 + 1
            i2 = i1
        else:
            i2 += 1
    return words
word_segments = merge_words(segments)
for word in word_segments:
    print(word)
I       (0.78): [   30,    34)
HAD     (0.84): [   36,    43)
THAT    (0.52): [   44,    52)
CURIOSITY       (0.89): [   55,    91)
BESIDE  (0.94): [   94,   115)
ME      (0.67): [  117,   123)
AT      (0.66): [  125,   128)
THIS    (0.70): [  130,   138)
MOMENT  (0.97): [  142,   154)
Visualization
def plot_alignments(trellis, segments, word_segments, waveform):
    ax1.imshow(trellis_with_path[1:, 1:].T, origin="lower")
    ax1.set_xticks([])
    ax1.set_yticks([])
        ax1.axvline(word.start - 0.5)
        ax1.axvline(word.end - 0.5)
            ax1.annotate(seg.label, (seg.start, i + 0.3))
            ax1.annotate(f"{seg.score:.2f}", (seg.start, i + 4), fontsize=8)
    # The original waveform
    ratio = waveform.size(0) / (trellis.size(0) - 1)
    ax2.plot(waveform)
        x0 = ratio * word.start
        x1 = ratio * word.end
        ax2.axvspan(x0, x1, alpha=0.1, color="red")
        ax2.annotate(f"{word.score:.2f}", (x0, 0.8))
            ax2.annotate(seg.label, (seg.start * ratio, 0.9))
    xticks = ax2.get_xticks()
    plt.xticks(xticks, xticks / bundle.sample_rate)
    ax2.set_xlabel("time [second]")
    ax2.set_yticks([])
    ax2.set_ylim(-1.0, 1.0)
    ax2.set_xlim(0, waveform.size(-1))
plot_alignments(
    trellis,
    segments,
    word_segments,
    waveform[0],
plt.show()
# A trick to embed the resulting audio to the generated file.
# `IPython.display.Audio` has to be the last call in a cell,
# and there should be only one call par cell.
def display_segment(i):
    ratio = waveform.size(1) / (trellis.size(0) - 1)
    word = word_segments[i]
    x0 = int(ratio * word.start)
    x1 = int(ratio * word.end)
    print(f"{word.label} ({word.score:.2f}): {x0 / bundle.sample_rate:.3f} - {x1 / bundle.sample_rate:.3f} sec")
    segment = waveform[:, x0:x1]
    return IPython.display.Audio(segment.numpy(), rate=bundle.sample_rate)
# Generate the audio for each segment
print(transcript)
IPython.display.Audio(SPEECH_FILE)
display_segment(0)
I (0.78): 0.604 - 0.684 sec
display_segment(1)
HAD (0.84): 0.724 - 0.865 sec
display_segment(2)
THAT (0.52): 0.885 - 1.046 sec
display_segment(3)
CURIOSITY (0.89): 1.107 - 1.831 sec
display_segment(4)
BESIDE (0.94): 1.891 - 2.314 sec
display_segment(5)
ME (0.67): 2.354 - 2.474 sec
display_segment(6)
AT (0.66): 2.515 - 2.575 sec
display_segment(7)
THIS (0.70): 2.615 - 2.776 sec
display_segment(8)
MOMENT (0.97): 2.857 - 3.098 sec
Conclusion
In this tutorial, we looked how to use torchaudio’s Wav2Vec2 model to perform CTC segmentation for forced alignment.
Total running time of the script: ( 0 minutes 2.589 seconds)
Gallery generated by Sphinx-Gallery
文档
访问 PyTorch 的全面开发人员文档
查看文档
教程
获取面向初学者和高级开发人员的深入教程
查看教程
资源
查找开发资源并解答您的问题
查看资源
APP信息
